Question about LG enV VX9900 Cellular Phone
Front screen i filled up my memory, and then my front screen isnt working anymore, it sometimes will work but will cut off again shortly after, i deleted most of my stuff.
    Sniper:
  • 51 Answers
First try turning it off...... pulling the battery and the memory card if you have one.........then replace the battery and turn it back on without the memory card present....if your display still does not work....consider taking it back to verizon for repair or replacement.....i have this phone and it breaks easily
Posted on Dec 09, 2007
My nokia 3110c is switched off again &again work for 3 minutes only help me
If you have a memory cars remove it and restart your phone.It usually works.Now,back up your data in memory card and format it.Fill the memory card only to its half the space.Try working the phone after inserting the memory card.If the problem is still there, then,you have to stop using your memory card or reinstall phone firmware.
If you don't have a memory card then, delete all the messages( Inbox ,Sent item etc).Clear the phone memory(delete images,themes etc).You may backup these things before deleting.
Now restart the phone.
If the phone doesn't stay long enough to do these things then,connect to a computer and do it.
May 08, 2010 | Nokia 3110 Cellular Phone
I put my 1GB memory card into the camera and it didnt work
iput 1gb card in cam i delete allpic?again i want takepic but not working
Dec 30, 2009 | Digital Blue EasyShare MD1063 Digital...
How can I delete more than 1 photo at a time from photo starter 3.0
Select the first pic by selecting it with your mouse, then press the ctrl key and hold it in. After you press that key, add the other pics you want to delete by placing your cursor over them and clicking each one.
When you release the ctrl key, all will stay highlighted. Press the delete button. Make sure that you don't click anything else before pressing delete. If you highlight something by accident, click it again to deselect it. Don't click on anything once the ctrl button is released, or everything will deselect.
If you would like to delete a row, or an entire page, select the first pic, and then select the last picture you want to delete. Push the shift key and all of the files will highlight. Release shift, and push delete.
These short cuts don't just work in Photoshop. They work in most PC based programs and folders to select text, files, etc. Mac has the same short cuts, the keys are just called different names.
Short cuts make things so much easier, you will love them once you learn how to do it. So don't give up if it takes a few tries. Anytime you drop a menu, there are a letter(s) and sometimes numbers next to the action such as "cut" or "paste".
These are the keys to use as a short cut instead of going to the menu. For instance, instead of going to edit and selecting copy, just press ctrl and then C, and it will copy whatever you have selected. Wonderful, yes? This is true for Mac and PC's
I hope this helped, you can let me know by rating the answer. You can also leave follow up questions or comments. Thanks for visiting Fixya.
Dec 28, 2009 | Adobe Photoshop Album 2.0 for PC
The tv is plugged in but the power isn't cutting on.. I used to cut it on with my old cable remote but now I moved.. and do not have it anymore. I tried to do it manually but it isnt working. Thanks
well, yew can try and pull out the cord 1st...then, wait at LEAST 12 hours and plug it back in! If it turns on, and cuts off 3 seconds later, try to pull tha cord out AGAIN and plug it BACK IN and it SHOULD work! :D :3 i have had multipe problems with my RCA television set, and this was one of them!!
Dec 05, 2009 | RCA TruFlat 27F520T 27" TV
4 short beeps
4 short beeps indicates memory problems. Either the RAM modules are incompatible or they are faulty.
Are you trying to increase the total RAM if so use the same modules from the original manufacturer but larger capacity but the same speed.
Sep 14, 2009 | EliteGroup K7VMM Motherboard
Opens for a short period of time only and then turns off again.
The problem is already solved. I bought a new battery and changed it.
Feb 02, 2009 | HP Pavilion dv1000 Notebook
Memory card not being picked up by phone
try this.....
type 277634# * # (no spaces)
click port setting
click mass storage
click mass storage remove
go back to main screen and check again for memory
if this doesnt work,take out memory card and try without the memory card.
Dec 23, 2007 | LG CU500 Cellular Phone
Memory full is being displayed when i try to go to a new destination and when i try to delete a favourite the unit turns off.
Garmin nuvi 610 T
memory full was being displayed on screen whilst on destination ,sometimes followed by route waypoint memory full .
I found by turning unit off , then holding finger on top left of screen ,and at the same time turning back on again the unit would go into maintenance mode.
Follow prompts on screen to reset waypoint memory.
Mine works as good as gold now,hope this helps!
Nov 13, 2007 | Garmin Nuvi 660 GPS Receiver
Phone saying memory full when its not
is your phone set to save photos to the phone memory or to the memory card..? that might be the reason why it is saying memory full. due to the phone memory being full. normally on symbian phones, there is an option settings to change the default location for saving photos and video. if you make it the memory card, then hopefully that will solve your problem. cheers
Jul 23, 2007 | Sony Ericsson K800i Cellular Phone
LG enV VX9900 Cellular Phone Logo
60 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
