Question about Cell Phones
Flashing and vibrating won't start
Battery was low this afternoon and now this evening the phone won't come on and it has a white screen and is flashing the light on the back of the phone and vibrating. I finally got it the restart and it is on the charger and did sinc but now it is on vibrate contiuously and lit with a white screen. Please help.
My my touch 4g slide won't turn on. when i start it i feel a vibration but screen will not turn on. Help?
Dear:
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Dec 11, 2012 | Cell Phones
Phone keep flashing screen on and off and won't stay on
I've had the same problem. Best solution is to put it on charge, face down for a few days. For some reason, overheating the phone by charging it for too long helps. My has this problem, that solves it but it'll come back again....
Sep 18, 2012 | HTC Radar 4G Windows 7.5 Smartphone...
My Nokia 5800 is not turning on...I have tried all the mentioned solutions.But nothing worked.yesterday i have installed some apps from OVI stores.Today afternoon while deleting one of my messages it got...
Some appl could not delete after we have install in our phone because some files of the phone(c drive)might defect when delete.So contact your nearest mobile tech to flash it.
Aug 11, 2010 | Nokia 5800 XpressMusic Smartphone
My BB pearl won`t turn on, first the screen went white
You can re-charge your battery fully by the provide electrical charger for 6 hr , then you can try and send me status.
Jul 22, 2010 | RIM BlackBerry Pearl 8100
K800i will not charge
Possible to rectify with Wotan Server to repair the EROM which is checked before firmware is flashed. You will have to buy credits and a data cable. Follow instructions pressing key 2 and 5 together. You may as well update the firmware after this process. Google around you will find this is an issue
Nov 20, 2009 | Sony Ericsson K800i Cellular Phone
White screen on my phone
Its WSOD (White Screen of Death)
The Most Common Problem for SE-Walkman Phones.
There are tested/working ways to work it out.
You have to flash your Firmware, BUT read the full procedure first and ask me if you got any problem, before proceeding.
The Tutorial goes here
Note: This solution will ONLY work if your Phone shows a pulse of vibration when turned on.
Regards, Waqar.
Sep 23, 2009 | Sony Ericsson Walkman W810i Cellular Phone
K810i wont turn on
its a ghost
in YOUR PHONE
Sep 05, 2009 | Lands Phones
What is going on with my phone?
you can try reflashing the firmware on the phone but i think the mainboard needs replacing to correct this issue............
Dec 26, 2008 | Motorola Mobility RAZR V3
Home page
I was talking on phone in the car. Made a quick call. Everything work fine. Than the screen went blank white. I can't see the screen of any application. I take the battery out to see if it would reset the phone and turn it back on. It went straight back to the blank white screen. I try another solution. I use my home phone. Call my phone. It signal as it was off mode. Straight to answering machine. Red light flashes....I then, hold #1 to get voicemail. It did work. So my service is good. So my problem is how can I solve the blank screen issue? Has it happen to anyone before. Battery strong and it's not low on battery level. Thanks for any suggestions.
Dec 10, 2008 | Verizon Communications BlackBerry Pearl...
My phone won't turn on...
You need to take the phone to a mobile service center and have them fix it for you....it needs a new battery and have the mainboard diagnosed
Nov 30, 2008 | Sony Ericsson K800i Cellular Phone
Cell Phones Logo
94 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
