Question about Motorola Mobility L6 Cellular Phone
Blue tooth how can i activate bluetooth in my L6i model. it is saying device not found
  • 66 Answers
Turn Bluetooth power on or off
Find it: Press -> Settings > Connection > Bluetooth Link > Setup
> Power > On
If Bluetooth Power is On, your phone can automatically pair with
the handsfree device you have used before. Just turn on the
device or move it near the phone.
Posted on Dec 08, 2007
When the bluetooth is off press it's button and keep it presed until the led is lighting red. Then the bluetooth is in pairing mode. Relase the botton and start the search for devices on your blackberry and use pin 0000 to connect. Good luck.
Jan 27, 2011 | Jwin BLUETOOTH HEADSET Wireless Headset
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
Blue tooth buton not active does it have blue tooth or is that just a button
Try installing the bluetooth driver from the driver disc that you should get when you bought the laptop. If it says bluetooth device is not found, push the bluetooth button once and try again. If it still says that the device is not found, then most probably your laptop have no bluetooth.
This is true for some Acer laptops that I've meddled with. I did what I said, assumed that there's no bluetooth device, only to have it confirmed by the owner that the seller already mentioned that his model have no bluetooth.
Apr 11, 2010 | Acer Aspire 4730-4947 Notebook
Bluetooth is not found in the control panel of my laptop
goto start and type bluetooth in search...if bluetooth drivers are installed ull get some icons like bluetooth, bluetooth devices etc.....try clickin bluetooth devices.....n u can try to connect with ur mobile.....if it doesnt show anythin u may have to install bluetooth drivers....hope this helps...
Mar 07, 2010 | Lenovo ThinkPad R61i 14 inch widescreen...
I dont know if i have bluetooth device in my laptop acer 5220 extensa. There is a button dedicated for it though. when i slide it to activate it gives me a message '' No Bluetooth Device Found''....I tried...
This might sound stupid, but did you activate the blue tooth on a other device so that there is a device to scan for? I am saying this, because my pc gives that message when it does not find any other devices to connect with, although the blue tooth on my pc works fine.
Really hope this can help you.
Best regards
Oct 18, 2009 | Computers & Internet
Is Acer Aspire 4720z equipped with a built in blue tooth device
The quickest and easiest way i have found is to press the Fn button + the one that turns on your wireless networking if you have one.
But i looked up your system and it says it comes with blue tooth.
"Communications Intel® Wireless WiFi Link 4965AGN network connection supporting 802.11a/b/g/Draft N wireless LAN, Acer® SignalUp technology for enhanced antenna efficiency
Intel® PRO/Wireless 3945ABG network connection supporting 802.11a/b/g wireless LAN, WI-FI CERTIFIED™, Acer® SignalUp technology for enhanced antenna efficiency
Bluetooth® 2.0 + EDR (enhanced data rate) wireless PAN (select models only)
Gigabit LAN, Wake-on-LAN ready
V.92 56Kbps* data/fax modem, PTT (postal, telegraph, telephone) certified in select countries, Wake-on-Ring ready
Acer® Video Conference with integrated Acer® Crystal Eye webcam supporting Acer® PrimaLite technology, which consists of a premium sensor, firmware and lenses to provide superior video performance under low-light conditions (select models only) "
I found this here
Feb 27, 2009 | Acer Aspire 4720 Notebook
Acer aspire 6920
go into control pannel, blue tooth devices look through the fomats and if you have bloue tooth it will show up. set up and go. is it 6920G its there
Jan 10, 2009 | Acer Aspire 6920 Notebook PC
How do I disconnect my phone from another Blue Tooth device?
Go to active devices menu in the bluetooth menu and delete any devices listed there and start find new device ... it should work fine ...
Oct 08, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Samsung SGH-D820 bluetooth static problem
find somebody else with blue tooth on their phone or get a device that is blue tooth ie hands free kit then on your phone select search for bluetooth devices if it finds any then select the item you want ie a friends phone or blue tooth if it says it is active then your blue tooth is working but to use the item with bluetooth you have to select the item it should come up as a list of items select the one you want then this should pick it up and this should solve your problem if not post back and i will try again hope this is some help.........................
Nov 01, 2007 | Samsung SGH-D820 Cellular Phone
Motorola Mobility L6 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
