Question about Tamiya America High Speed Gear Box 11.6:1 and 18.0:1
I have a 1992 Nissan puslar sss. When i shift from first to 2nd it doesn't go into gear it just grinds, i have the same problem with 3rd and reverse. Can someone please help me??
  • 636 Answers
Is it grinding while the clutch is engaged? If so sounds like either the sincro gears are messed up in your transmission or your clutch is shot.
Posted on Sep 05, 2009
1996 Ford Ranger xlt manual transmission can"t shift into 3rd and 4th gear
If it grinds when trying to shift, it is the synchronizers. Rebuild. If it pops out of gear. there is a plastic part at the top of the transmission that wears out. It fits around the ball of the shifter. It is two pieces. You'll have to remove the floor plate and pull it up to access the bolts to remove the shifter and replace those plastic pieces.
Aug 04, 2016 | Ford Cars & Trucks
I'm hearing a grinding noise when shifting gears in my 97 nissan pathfinder. It's not a full blown grind but just a slight grinding noise. It does it in reverse 1st 2nd 3rd and just started doin it in 4th....
check and/or change the transmission oil. Clutch problems are noticeable in 1st and reverse but as all the rest are syncro controlled you really do not need to use the clutch to change them. just get the engine rpms to match road speed and they will slip in. I am thinking a oil viscosity problem because of the colder weather.
Dec 28, 2014 | Cars & Trucks
I was driving to work this morning and was in 3rd gear, went to down shift at a stop sign and its stuck in 3rd gear. 1988 jeep wrangler. It has been grinding the gear for a few weeks now everytime I change...
The 3rd Gear Synchro is worn or damaged, which is why it grinds when you try to upshift or downshift into 3rd gear. When it goes out completely you will have a very hard time shifting into 3rd gear, since the Synchro lines up the gears to make shifts smooth and easy.
Aug 24, 2011 | 1995 Jeep Wrangler
92 chevy s10 4x4 4.3L manual transmission no 3rd gear
Hi:
Your transmission has 3 shift rails...
1st - 2nd
3rd -4th
5th- Reverse
If your 3rd gear doesn't work , you have an internal transmission problem, such as a syncronizer, or similar fail... There is not much you can fix, without removeing the transmission.
Nov 30, 2009 | 1992 Chevrolet S-10
My 92 honda accord will not go into 1st 3rd or 5th gear
check shift fork adjustment. make sure you bleed the slave cylinder.also check shift cable adjustment.
Apr 11, 2009 | 1992 Honda Accord
Tamiya America High Speed Gear Box 11.6:1 and 18.0:1 Logo
269 people viewed this question
Top Tamiya America Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Tamiya America Toy Expert? Answer questions, earn points and help others
