Question about Saws
Standard setting for makita petrol grinder mixture screw?
  • 5,660 Answers
Your question is a little vague as you didn't list the model number, but I believe I can help.
Turn the mixture screw in all the way, BUT slow down, and use finesse as the screw comes close to bottoming out.
You can smash the tip of the mixture screw, or ruin the seat that the mixture screw tip touches!
Now turn the mixture screw out one full turn. Start from there. Adjust it in a little at a time, as the grinder is running, or out a little at a time.
Listen for where it runs best.
Posted on Sep 05, 2009
Manual required for Makita DPC6400 stone cutter
Go to the Makita home page at:
http://www.makitatools.com/en-us/Modules/Home/Default.aspx. Use the search box at the top right to look up your model. It will show it is discontinued but if you select it you will be able to view or download the parts breakdown and owner's manual.
Oct 27, 2012 | Makita Saws
Makita petrol stone cutter
Start by removing the wire from the cut out switch to rule out a problem with the switch, if still no spark with a new plug it will be a replacement ignition unit.
Feb 12, 2012 | Saws
How do you get to the inside of a makita 4.5"
there is a screw in the bottom of grinder next to the power cord, that's all you have to take.
(althought I don't know the model of your grinder, the most of makita brands have the screw right there) good luck!
Jul 02, 2011 | Makita Saws
What are the other two screws for above the idle screw?
The one closest to the engine is the idle mixture screw. Out is more gas=richer
The other is for high speed mixture. Again out ccw (counter clock wise) is richer
1/8 turn makes a huge difference. Temp of engine critical. Make sure it is up to operating temp before turning anything. If it won't run turn them out 1/4 turn at a
time and see if it will run without choke or even 1/2 choke.
Feb 06, 2011 | Makita DPC7311 73cc 14Inch Gas Powered...
Regarding makita petrol disc cutter dpc6410- how much oil do i need to add to a full tank?
Don't add oil to the fuel tank, it doesn't mix well in there and you'll almost always use too much oil. Mix your two-cycle oil and petrol in a gas can to get a 50:1 mixture. Read the directions on the two-cycle oil bottle for how much to use and put the oil in the can first so the petrol will mix well with it as you add it to the can.
Oct 11, 2010 | Makita DPC6410 64cc 12" Power Cutter
My Makita bench grinder has four holes to change the grinding wheel..how to I get the retaining nut off as I don't have a tool to fit the four holes?
Make your own wrench out of a piece of wood stock,with 2 screws or nails spaced out to 2 opposing holes in the retaining ring/nut.HarborFreight sells a 'spanning wrench' online .
Jun 30, 2010 | Makita Nip 5"(127mm) Bench Grinder Wheel...
Can you give me a schematic diagram of a makita grinder?
Not sure what model you are looking for. Here is a link with several Makita grinders with schematics.
http://www.toolpartsdirect.com/makita/makita-12.html
Hope this helps.
Jul 28, 2009 | Makita Angle Grinder 4.5" 9524NBX
How do i replace the brushes in 9557pb makita angle grinder?
Take apart the rear portion of the case -- the part the cord enters -- two halves -- screws in side -- you'll see the brushes -- they are in holders held in by springs and plug into the winding.
Apr 30, 2009 | Makita Usa Inc 9557PB 4 1/2" Angle Grinder
Saws Logo
77 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
