Question about Epson RX620 All-In-One InkJet Photo Printer
Ink cartridge not moving
My printer - epson stylus photo c4700 was workin ok until a piece of paper got stuck and wasn't feeding in correctly. It came up ERROR - Printer error occurred. Please see documetation which reads general error - Delete all print jobs and turn the printer off. Remove foreign objects from inside the printer. after a few minutes turn the printer back on.
I cannot find any paper stuck but the ink cartridge carrier is not moving at all/
It is a problem of carrage motorneed to replace
Posted on Sep 05, 2009
My printer is not recognising the replacement ink cartridge although I've used these before many times
If you have just installed a new cartridge and you still see an ink related error, the cartridge may be incorrectly installed. Follow these steps to make sure the cartridges are correctly installed:
  1. Make sure the Epson Stylus is turned on.
  2. Do one of the following:
    • If your printer indicates that an ink cartridge is expended, press OK.
    • If your printer does not indicate that any ink cartridge is expended, press Setup, select Maintenace, and press OK. Then select Change Ink Cartridge and press OK.
  3. Open the scanner.
  4. Open the cartridge cover.
    Caution:
    Never attempt to open the cartridge cover while the print head is moving; wait until the cartridges have moved to the replacement position.
    To avoid damaging the Epson Stylus, never move the print head by hand.
  5. Press down all the ink cartridges until they click into place to make sure they are properly seated.
    Note:
    If a cartridge is properly seated already, you may not hear a click.
  6. Close the cartridge cover and press it until it clicks into place.
  7. Close the scanner.
  8. Press OK to begin charging the ink. This takes about 2 minutes.
    You see a message on the display screen when ink charging is finished.
    Caution:
    Never turn off the Epson Stylus while the ink is charging or you'll waste ink.
If the issue persists, it appears to be an issue with the cartridge(s). Contact Epson for further assistance.
Sep 25, 2014 | Epson Stylus DX8400 All-In-One InkJet...
EPSON Photo 1400 paper feed and ink replacement problem
Asit is only a couple of months old seek a replacement under guarantee/warranty.
Jun 29, 2010 | Epson Stylus 1400 InkJet Photo Printer
White lines on printed photos Epson Stylus NX400
You need to clean the print head on the cartridges , please follow these steps\
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Mar 15, 2009 | Epson Stylus NX400 InkJet Printer
Epson c42ux cartidge stuck, won't feed
Hi Sunny Shine
It's very difficult to help you if you don't respond to our questions! If you continue to maintain a mysterious silence, we will presume you no longer have a problem - Problem Solved!
Feb 18, 2009 | Epson Stylus C42UX InkJet Printer
Epson 1280 ink carriage making noise and not printing
hello there. try re-seating the cartridge. Take it out, then put it back in.
Nov 28, 2008 | Epson Stylus Photo 1280 InkJet Printer
Epson R320 carriage jammed
The ink cartridge is probably not inserted correctly.  Unplug the printer and manually move the carriage to a location where you can take the ink cartridge out.
Remove it and reinsert it, making sure that it is fully located, before applying the power.
Make sure that there is nothing blocking the carriage movement, such as some remnant of paper.
Oct 21, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson stylus photo r340 paper feeder
the friction feed roll might be dirty from paper lint, ink glazed or it might have something stuck in it ( a piece of paper from a jam etc.)
Jan 29, 2007 | Epson Stylus Photo R340 InkJet Printer
Epson RX620 All-In-One InkJet Photo Printer Logo
263 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
