Question about Canon Cameras
I have a one year old G 9 camera which has stopped , each time start it it says,Lense error re start , thlense has got stuck.
    Brigadier General:
  • 4,090 Answers
Works on all these type of cameras
OK you are probably going to think I am loony giving you this advise But No I am completely sane!
Get a can of compressed air OR acces to a compressor at your local garage Get them to fit the triggered air blower tool to it.
Blow around the lens in all the extension joins the firmly slap it in the palm of you hand with the side of the camera making contact with you palm. Do the procedure two or 3 times and inbetween the slaps turn it on to activate the lens mechanism. I have now fixed about 80 of these cameras with this method. I obtained the fix from Sony who charge $90 to do exactly the same. Keep at it as it will eventually work. One tip, make sure the battery is charged before you do this.
Please rate our help to keep the FREE service online ++++Thanks for using FIXYA
Posted on Sep 10, 2009
My camera lense is stuck and my camera wont turn on
hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u
rate me!!!
Jul 28, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
Lens are stuck out. screen says "lens error"
There could be two things causing this problem.
1- some dirt somehow got on the outside of side of the lense. So the lense could not fully retract or open out. As a result you can not take any picture. If the lense comes out even a little bit, try to pull it out NOT too hard a few times. If it does not retract, turn the camera off and push the lense in (up and down) NOT too hard for a few times. If the camera opened up 100% or retracted 100%, your camera should be back to normal. Make sure to clean the outside of the lense when fully open and keep it clean always. If this did not help, read 2.
2- If you dropped the camera, some mechanical part of the lense is broken or dislocated or the cable may have come loose. In this case you need to take out the lense from the camera and inspect it for broken pieces or loose cable. clean the outside of the lense and push the lense in and out a few times. Put the lense back on the camera and your camera would be back to normal.
Good luck!!!!!!
Jun 11, 2009 | Olympus FE-270 Digital Camera
Camera won't power on. Lense won't retract.
Pls check the batteries are they supplying full power to camera are they aged or old try replacing them with good power batts and Memory card try re formatting it on a PC card reader
lense is coming out at full length or there is a grinding noise or abnormal behavior in it pls check may be u dropped ur camera or any other incident broken its lense gear.
pls check and reply me for more help
Feb 27, 2009 | Olympus FE-220 Digital Camera
My canon SD850 IS digital camera is not even a year old and well taken care of. I thasnt been dropped and is already broken? What do i do...everytime i turn it on all of the sudden the lense is stuck poped...
Take a look at the suggestions at the top of page 122 of the Advanced Camera User Guide. The suggestion is that the cause may have been that the camera was still on when the memory card/battery cover was opened. Try closing the cover and then turning the camera off and then on again. Hope this helps.
Jack
Nov 26, 2008 | Canon PowerShot SD850 IS Digital Camera
Digital camera
I got a lense error 112 then the camera goes off
Jul 30, 2008 | Sanyo VPC-E760 Digital Camera
Lense error
send it in for repair. their is no easy fix for this sorry. www.digitalcamrepair.com can help.
Jul 07, 2008 | Casio Exilim EX-Z750 Digital Camera
Camera lense/power
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 18, 2008 | Canon PowerShot A510 Digital Camera
Cameras Logo
15 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
