Question about Epson Stylus Color 600 InkJet Printer
Epson stylus 600 won't print yellow
I know its old but its been a brilliant printer and I would love to keep it going. It just suddenly packed up printing yellow. Have bought a new set of catridges from a different supplier. Has had endless nozzle checks and cleans all to no avail. Is it time to change or can anything be done ?.
SOURCE: Epson 9600 suddendly stopped printing yellow
It's NOT a cartridge if this works... I had a similar problem with a 9600 I bought on eBay that had been inoperable over 18 months. Three colors would NOT clear up after multiple power cleanings. Epson support politely solved the issue at no charge on the phone... he had me drop a few drops of warm water on the pad the printhead rests on when not printing. You have to move the printhead to the left to do that by moving up the little lever near the cutter. The pad is easier to reach with a long eye dropper. I used very warm water- not boiling. I replaced the printhead over the warm water pad for an hour. Then I repeated the process and let it be for another 60 minutes. Then I did a nozzle check and what was gummed up yellow, cyan, and magenta nozzles became clear and it's worked fine since. Good luck!
Posted on Oct 28, 2007
SOURCE: Lines on prints
Hi kids! I decided to have another go at sorting out my 'lines' problem and have sorted it. See if this might work for you: I had previously done the head cleaning via the printer itself - holding the central ink/paper black button for 3 secs. This time I went to the Epson 1290 window on my Mac and clicked on the utility box. Though the Nozzle check print came out fine I went ahead and did the head cleaning in this box. The next print came out almost perfect so I ran the Head cleaning again and it printed a perfect print. Hope this might work for you. Keep on trying! All the best. Trant
Posted on Mar 28, 2008
issy2
  • 462 Answers
SOURCE: Color light will not go out
remove the cartridge close the printer, then again turn on printer and put the cartridge back effectively..
Posted on Sep 09, 2008
  • 7 Answers
SOURCE: Epson C88 communication error 600
yes you have to go to control panel and remove the drivers and install the drivrs again ok
Posted on Dec 09, 2008
gwbm
  • 353 Answers
SOURCE: to make my Epson printer, model "Epson stylus C42UX" work in India, with Indian ink catridges T038 & T039
This is a tricky one, but there are possibilities.
1. Buy a set of epson C42 cartridges from the cheapest source and keep refilling them - you will need a (very cheap) resetter.
2. Transfer the C42 chip to the C41 cartridge - they are only clipped in place. I don't know if this will work because I only have knowledge of C42 cartridges - the C41 cartridges may be keyed so they wont fit in a C42 cartridge carrier. You may be able to identify a clone manufacturer for which this is possible. You will also need the resetter for this solution.
3. Fit a Continuous ink system (CISS) see for example http://svp.co.uk/products-solo.php?pid=3569&prepg=1
Posted on Jan 31, 2009
I just replaced all four ink colors in my Epson 600 workforce and its not printing right. its all yellow and pink.
It appears that some ink nozzles are blocked or not seated properly.
Go to the Epson support site below and enter Epson WorkForce 600 as your model. Then go to Troubleshooting Guide in the list on the right of the web page
Welcome to Epson Support
Oct 03, 2014 | Epson WorkForce 600 All-In-One InkJet...
Epson Stylus C86 smearing
Your printer has ink build up inside it. This comes from cleaning cartridges and builds-up steadily over time. Remove top cover. Wet a cotton swab with isopropyl alcohol (available at drug stores) and clean the inside. use a cotton bud where the swab gets entangled.
Aug 07, 2009 | Epson Stylus Photo 1290 InkJet Printer
I have an epson stylus 4050 printer which loves to keep changing language to german,and it chooses what it wants to print. Tried uninstalling and re-install same problem keeps comming up?????
honestly i wish I could help you with this. but i am going through the same problem. With the printer deciding what it wants to print. Are you sure that it doesnt have any awaiting documents.
If that doesnt work. Then i think you should try restorting your computer and then try installing it from there
Jul 16, 2009 | Epson Stylus CX4800 All-In-One InkJet...
How do I change the a discharged cartridge in the printer Epson Stylus Office BX300F
pree menu on the printer > go to maintenance > go to ink cartridge > press ok > open the lid > the cartridge will be in installing position, pull and relaese the lock > pull the cartridge u want to change using the clip provided. > undo the plastic pack of the new cartridge, tear open the vaccum pack, pull out the yellow tape > keep the cartrigdge on the hoder straight and gently press the top until u hear it click ! !!
Mar 09, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Dec 09, 2008 | Epson Stylus C88 InkJet Photo Printer
Epson stylus 600 non stop flashing light nonstop printing
Flashing light may indicate that it's receiving data to print.
What is it printing?
Cancel all print jobs.
Nov 19, 2008 | Epson Stylus Color 600 InkJet Printer
Epson Stylus 600 printer Problem
remove you present printer driver and reinstalles driver.if problem not solved then change your data cable
Jun 27, 2008 | Epson Stylus Color 600 with GT-5500...
Colour printing
Check the following thread, it might apply to your problem. and just as a printer can be fooled to show a low level ink, I guess it can happen the other way around. http://www.fixya.com/problems-solutions/t103191,p342983/Epson-Stylus-Photo-R300-InkJet-Printer.aspx Good luck
May 19, 2006 | Epson Stylus C64 InkJet Printer
Epson Stylus Color 600 InkJet Printer Logo
71 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
