I have a Mitsubishi Black Diamond HS MX1 VCR (serial # MX1NZ13566) that I havent used in 6 months. I have just gone to use it and the power wont turn on at all. It has been sitting in the corner of the room in the middle of winter and may have got a little moisture in it. I am guessing it is the power supply. What can I do to fix it?
SOURCE: Mitsubishi HS-U447 VCR in Lock or "Loc" mode
Hopefully you still the VCR. Your's is stuck in "CHILDLOCK" mode. To release the lock you have to have the remote and press the DISPLAY for 8 to 10 seconds.
The purpose of the CHILDLOCK is to prevent others from using your VCR. If you want to set the VCR back on Lock you again press the DISPLAY for 8 to 10 seconds.
This solution is from the owner manual for HS-U448, so I figure your model is the same.
SOURCE: Mitsubishi HS-U61 SVHS
When a tape won't eject, the problem can be caused by several things. The most common problem is that the belt that operates the eject mechanism is slipping and not allowing it to eject the tape. This can be fixed by either using a re-grip solution on the belt or have the belt replaced. Belts are inexpensive but sometimes difficult to get to. Most of the repair expense will be in the labor. Unplug the unit and take the cover off. Hopefully there will be enough clearance so you can get to the tape. Try to find the motor and belt that is responsible for operating the eject mechanism. The motor will look like a shiny cylinder, about the diameter of a quarter and will have a plastic pulley attched to the shaft. You can rotate the pulley and belt with your fingers and manually eject the tape. If the tape is around the spindles and video head, you will need to manually move the mechansim that retracts the spindles and returns the tape to the cartridge. While you may be successful in getting the tape out, you need to find out what caused the problem in the first place. Putting in another tape will most like become stuck again unless the problem is identified and resolved. Also look for a broken spring or cracked gear (missing teeth) in the eject mechanism. Please let me know if I can be of further assistance Good luck! - Jim
SOURCE: Error E3 on Mitsubishi HS-U795
Try this :
If your VCR malfunctions, try the following steps prior to contacting your Mitsubishi Dealer:
1 Check the Trouble Checks below to see if there is a solution to the current problem that you are
experiencing.
2 If the problem is not addressed on the Trouble Checks, the safety circuits in the VCR may be in
operation, thus please try the following: (the clock setting and the timer recording will be deleted.)
1 If possible, press EJECT on the front panel and remove the tape.
2 Press TIMER RESET on the rear panel with a pencil or a ball point pen.
3 If a tape is not loaded, press POWER to turn the power on. If a tape is loaded, wait about 1 minute
until the tape protecting function is completed, then press POWER.
3 You may also try the following procedure if the above steps did not resolve the problem (All settings will
be reset to the default settings.).
1 Press POWER on the front panel continuously for about 8 seconds until the current time display on
the front panel shows "- : - -."
2 If a tape is not loaded, press POWER to turn the power on. If a tape is loaded, the tape protecting
function will work and "99" will appear on the front panel display to begin count down. Wait about 1
minute until it reaches "00" to show the tape protecting function is completed, then press POWER.
If the problem with your VCR persists, contact your Mitsubishi dealer for assistance.
Im looking for error codes.
SOURCE: AIWA VCR model HV-MX1problem
with the unit unplugged take the case off and look on both sides of where the front of the tape would set, you will see two towers, one is a light and the other a receiver,check to see they are plugged in and not obstructed.Also there is a switch that the tape pushes when its all the way in which might be stuck,click it a couple times with your finger.This might help, there are other more complicated things which could cause this problem but mechanical problems are more likely.
