Question about Sony Ericsson R306 RADIO Cellular Phone
No service centre number for my telstra phone it got wipped
What is the Phone number for telsta faults
Gloria,
Most faults with a fixed home phone service can be resolved using the troubleshooting tool. Telstra Home Phone customers connected to the NBN, please call 1800 834 273. Telstra Business customers, please call 13 29 99. Telstra Enterprise and Government customers, please contact your Customer Care team on 1800 730 053.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Feb 24, 2016 | Cell Phones
HI could somebody please help me unblock my IMEI number -358354050069128 its a nokia lumina 1020 on telstra in australia ,
Unlock Telstra Australia Nokia Lumia 1020
to use any where in the world with any supported service provider likeAT&T, Straight talk, T-mobile, Vodafone, Personal, Claro, O2, Digicel, Telcel, Orange, Telenor, Optus, Tele2, MTN Rogers, Fido, Chatr, Bell, Virgin, Sasktel, MTS, PC telecom, Tbaytel, Telus, Koodo
You can request the code by submitting your imei
@http://www.WorldGSMCodes.com
Your phone will also keep working with your current lock to service provider.
Take Your Telstra Australia Nokia Lumia 1020 with you on vacations and use the local service provider sim card in your phone and save roaming fees.
Telstra Australia Nokia Lumia 1020 Unlocking Instructions
1: Turn on phone with Not Accepted SIM card.
2: A menu will pop up to Insert the code.
3: Insert the provided code and press OK
4: Device is now unlocked.
After Unlocking Telstra Australia Nokia Lumia 1020 will work with
Also any where in the world with any Supported Carrier
*Supported carriers can vary based on your locked to carrier and your region, please confirm with your service provider, before placing order
Your phone will be permanently Unlocked,it will not erase your contacts or any data from your phone.
Nov 19, 2014 | Nokia Cell Phones
Any text message i send goes to the out box and is either resending (to no avail) or listed as failed. I got the phone 3 days ago. It is a work phone with telstra. Nokia C%
The problem might be with "Message Center Number" which is different for different service providers.
You should call you service provider "Telstra" and ask them that number. You can then enter it in your mobile as mentioned below.
(Please rate the solution if helpful, Thank you)
Press "Menu"
Scroll to Messaging, press "Open"
Press "Options", scroll to Settings, press "Select"
Scroll to Text message, press "Open"
Scroll to Message centres, press "Open"
Scroll to SIM message centre, press "Open"
Scroll to Message centre name, press "Change"
Enter (your provider's name), press "OK"
Scroll to Message centre number, press "Change"
Enter (number provided), press "OK"
Press "Back" twice
Scroll to Message centre in use, press "Change"
Scroll to (provider's name you entered), press "OK".
Jun 17, 2011 | Nokia C5 Cell Phone
My daughter dropped her 2 day old Telstra glide T870 & screen now gone blank. Is it ruined? Is this a common problem?
Depending how the mobile phone hit the grounf, the screen could be cracked or the electronics in the phone can be destroyed.
Take it to a mobile phone repairer to assess the damage and they can advise if it is worth repairing.
May 01, 2011 | Cell Phones
My phone can't write text messages (they are converted straight to MMS and when i convert it to text it still dosen't work), nobody can receive them, i can't reply to anything (it keeps expecting me to...
Problems sending or receiving SMS may be caused by no or incorrect SMS settings. To set up your phone to use SMS, you need a message centre number, which is provided by your network operator. This is often set up automatically when inserting a new SIM card to a phone. Whiteout the message centre number, you are not able to send or receive SMS.
To edit the service centre number:
  1. Select Menu > Settings > Connectivity >Message settings.
  2. Select Text message.
  3. Highlight Service centre and select Edit.
  4. Highlight a service centre number and selectOptions > Edit > Continue.
  5. Enter the service centre number and selectSave > Yes.
  6. Highlight the service centre number and selectSelect to use the defined service centre number.
To add a service centre number provided by your network operator:
  4. Select Add to add a new service centre number.
  5. Enter the service centre number and selectSave.
This should help you.
any further questions feel free to ask.
Thanks.
Nov 19, 2010 | Sony Lands Phones
Cant send or receive mms on phone. still wants telstra but im optus now
Depending on what type of fone you have there is a setting in:
Messages/Message Settings/SMS-MMS
In here you will find a command called MMS Centre.
Simply change this to that of your service provider and activate.
Rgrds,
May 28, 2010 | Cell Phones
Help phone not working
try going to message settings then text messages then service centre number should be +61418706700 depends if your with telstra
Apr 05, 2010 | Motorola Mobility Clutch i465 Cell Phone
I have an i9 phone. I live in Australia and I am with Telstra. GPRS not subscribed keeps coming up when I try and go onto the internet. Need help please
I'm with telstra and used these settings. If you get stuck go to
www.i9forum.co.uk and register then go to the mms & sms section some phone do use a slight variation on this below.
Step 1 – WAP DATA Account Setup
1. Go to the following menu “MENU > SERVICES > DATA ACCOUNT > GPRS >
Select an empty Account”
2. Edit the following parameters in the account
a. Account Name=Telstra WAP GPRS
b. APN=Telstra.internet
c. User name=[blank]
d. Password=[blank]
e. Auth. Type=Normal
Exit back to MAIN SCREEN.
Step 2 – WAP Setup
1. Go to the following menu “MENU > SERVICES > WAP > SETTINGS > EDIT
PROFILE > SIM 1 or 2 > Select an empty PROFILE > EDIT PROFILE”
2. EDIT the following parameters in the account
a. Rename Profile=Telstra WAP
b. Homepage=http://wap.telstra.com/wap
c. Data Account=Telstra WAP GPRS
d. Connection Type=HTTP
Proxy Address = 010.001.001.181
Proxy Port = 80
e. User Name=[blank]
f. Password=[blank]
3. BACK then ACTIVATE PROFILE and exit back to the MAIN SCREEN.
4. Your Phone is ready to access WAP and MMS services.
Step 3 – MMS DATA Account Setup
1. Go to the following menu “MENU > SERVICES > DATA ACCOUNT > GPRS > Select
an empty Account”
a. Account Name=Telstra MMS GPRS
d. Password=[blank]
3. Exit back to MAIN SCREEN.
Step 4 – MMS Setup
1. Go to the following menu “MENU > MESSAGES > MMS > MMS SETTINGS >
SERVER PROFILE > SIM 1 or 2 > Select an empty Account”
a. Rename Profile=Telstra MMS
b. Homepage=http://mmsc.telstra.com:8002
c. Data Account=Telstra MMS GPRS
Proxy Address = 010.001.001.180
Proxy Port = 80
f. Password=[blank]
Feb 12, 2010 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Network settings
I have this problem on Telstra when I restart the F480T.
To fix in Australia on Telstra:
- Widget->Messages
- Settings->Text messages
- Text message centre settings
- Edit Text message centre 1
- Centre address = +6141706700
Save.
You can get the centre address from anybody on the same network as you.
Nov 02, 2008 | Samsung Tocco F480 - Pay Monthly Cellular...
Telstra prepaid mobile unlock
hello there....well its quite simple...to unlock the phone to any network you need to call the customer care of your original network provider( Telstra) ....just keep the model number of your phone number handy (you will find that on the box in which you got the phone)...or the IMEI number (15 digits mostly) by dialing *#06# on your phone or beneath the battery or on the box near bar code....this is a paid service and charges differ from network to network
that should solve the problem.....you will be able to use any sim in your phone of any service around the world
hope this help
Aug 06, 2008 | Cell Phones
Sony Ericsson R306 RADIO Cellular Phone Logo
67 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
