Question about Cell Phones
My HTC touch 6900 won't charge or turn on. When i plug it up to the wall charger or the usb it displays a constant red light? I really need help because there are very important pics on here of my mother. She just passed away and i don't want to lose the pics.
    Problem Solver:
  • 5 Answers
Sounds like you have a bad battery. I would recommend getting a replacement battery and charge it to full. If that is not the problem, you bave a screen out.
Posted on Aug 11, 2010
Nikon s6300 won't turn on
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
May 08, 2017 | Nikon COOLPIX Cameras
My HTC mobile not going to on after pressing power button and on connection of charger it is showing red LED. Same there here. I woke up this morning and my phones just dead. Even if i connect the charger...
Remove the battery then connect the charger without the battery. Then hold down the power button for a few seconds. The red light may come up for a quick second during this process.
Don't remove the charger. After the red light goes off then insert the battery and check if the light turns amber or orange.
Leave it in orange or amber light state for about 2 minutes. After that, try to turn it on. If it turns on then it is resolved. If not then there is a hardware problem with your phone and it needs to be checked at any HTC Service Center.
Jan 28, 2011 | HTC Touch P3450 Smartphone
Battery discharge quickly, I have replaced new batteries and module control and problem still exist.
Don your charger is probably not charging the batteries. When you charge your chair overnite the charger should have a red and green light showing charge complete. When you first plug it in the lights should be red and yellow. If you are getting a red and green light when you first plug it in then there is a problem with the charger or with the charging circuit to the batteries. You should have a charger port on the battery box try plugging the charger into that port and see if you can get the batteries charged. When you do you should have a red and yellow light on the charger changing to red and green when fully charged. Hope this helps
Nov 07, 2010 | Pride Go Chair Travel Power Chair
I have a HTC Touch and he stoped working. and
seems like the battery is deeply discharged or drained off.. try putting the charger for a long time & see if the red light turns orange after a couple of hours.. if not, you need to change your battery..
Mar 10, 2010 | HTC Touch P3450 Smartphone
I have a Verizon XV6900 or (htc) 6900 and all
Did you try plugging another charger or connecting it to your pc by usb cable if it shows charging its the power button
Dec 10, 2009 | Computers & Internet
I see red light instead of orange
did you try the following?
1. disconect you phone from power supply.
2. take the battery out
3. connect the phone back to the charger
4. place the battery back
if it does start charging (after 3 seconds you see the orange light) just leave it for about 60 minutes to charge. if you still get the red light, try again the 1-4 steps one or two times.
if it does not help you, you might need to replace the backup battery in the motherboard. this is a small CMOS battery, very close to the mini USB connector onboard. I think you should send the device to an HTC service center to do this kind of repair, since electronics ans soldering skills will be required for that job.
Aug 22, 2009 | HTC Touch P3450 Smartphone
Upon power up, 3 red LEDs flashing rapidly continously, no power.
The control systems on power mobility equipment have a "prevent" circuit that immobilizes the equipment while it is plugged into a charger, so folks won't take off with it plugged into the wall outlet. When you turn it on when plugged into a charger, the display will flash constantly, or sweep constantly, depending on the manufacturer. This is normal. Your off-board charger should have a red light to indicate power to the charger, and another light for the charge status. Yellowish means it is charging, when it turns green, you are fully charged. If the status light is green all the time, that is an indication that the charger is not functioning properly, or that the batteries are below a chargeable state. Check charger output, which should be 26-28 volts dc, and each battery should show at least a 12 volt reading, but around 13.5 volts with a full charge. If one or both of the batteries drops below 12 volts after a short period of time, it's time for a fresh pair. Fully charge new ones before using the chair.
May 31, 2009 | Pride New Jazzy 600 Power Wheelchair by...
My Mambo- Mano MP4-MP3 does no charge
it does not seems to charge / or turn ON either from the computer or when plugged to an electrical outlet to the wall. Red light is still ON after the whole night . What's wrong ?? Can you please HELP - CODY STELLER MINE IS A 4 GIGA BITE MP4 PLEASE HELP ONLY
Sep 01, 2008 | Kaser Corporation Mambo Mano Digital Media...
Cell Phones Logo
251 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
