Question about Radio Communications
Bmw 523i wont start
When my bmw 523i auto heats up to normal temparture the car will loose power and cut out.she will not start untill the car cools down,but now it wont start at all.can you help me please.the car drives normal untill it reaches its normal temp.
  • 4 Answers
I had the same problem in a 1992 mercedes 300E.....several diagnostic tests were useless. After several trips to the dealer, they replaced the crankcase sensor. This seemed to solve the problem. Also, make sure your oil is good (old oil may cause the engine to overheat and trip a sensor?????)...when I changed the oil, my car ran cooler.
Posted on Dec 11, 2007
Why is it that after diving my 06 bmw 528i about 5 min cut car off it restartes drive again for about 15 min cut car off if I try to restart the car I have nothing no start but if I wait for half hour
Have the wiring to the starter checked and tightened. Seems as though the starter has become heat soaked, binds and does not start until it has cooled down..did you install it correctly replace any heat shield that may have been in place? Be sure you have the correct starter...Some will fit but if the torque if not correct it can put strain on the starter.
Feb 12, 2015 | BMW Cars & Trucks
At time of starting when car (chevrolet optra LS 2005) temperature is cool RPM goes down and car is off
cars have 2 things.
engine coolant temp
and HVAC temp
can tell what you are talking.
car is off state?
do you mean the engine stalls.?
try to talk in terms of what system in car is failing
HVAC (heating or cooling of passengers)
engine issues, stalls , misfire, lost power.
transmission issues, wont shift or slips or messes up some of 100 ways. as a/t love to do.?
Jun 11, 2014 | 2007 Chevrolet Optra 1.6
I have a 1997 BMW 525 tds when iturn the steering wheele it cut off
There is a short in your wiring harness under the plastic cover that surrounds your column. remove the cover crank the auto then wiggle all the wires there until you hit the sweet spot and it dies then look threw that area very well for loose or frayed wires loose connectors anything not normal. also follow your steering column to the floor board continuing the process you will find the problem.
Apr 07, 2012 | BMW Cars & Trucks
Cant find the top up plug on my 523i 1999 transmission auto
If my notes are right a 1999 523I filled through the transmission dipstick with a funnel. The only other fill was if the transmission is removed.
Jun 23, 2011 | BMW 525 Cars & Trucks
BMW 523i - The Steering Wheel is locked, absolutely no movement & the normal jiggle doesn't work & I have no movemnt on the Key so unable to start. Any ideas?
Hi if this is an auto, sometimes if it is not in parck correctly or the pack saftey switch is not working correctly this will lock the wheel untill it is put in park , try moving the stick from p to n a few times that might get it to work, if it is a manual type transmission, normally a few sharp pull downs one way should free it, this will be the security system not releasing the stearing lock "bolt" also if that does not work, try removing the couling from arround the wheel, using a small hammer ( smaller the better, we are not trying to knock it into next week ) and a couple of small light taps near and arround the middle of the barrel while pulling on the wheel and turning key ( help will be required unless you have 3 hands lol ) to do this...hope this helps...
Dec 03, 2010 | 2001 BMW 5 Series
Ford mondeo mk3, intermitent dumping of water from cooing system,found crack in header tank, changed same,ran car at idle, temp guage at normal & heater blowing hot , took car for run , temp guage off...
You may have an air pocket in your system which some times happens.  One way to get rid of it is to take the upper hose off on the engine side,  fill your system with water until it runs out from your engine block, replace the hose, start your car turn you heater on and set to hi keep the radiator cap loose until the temp start to rise then close tight.  Once the air pocket had been remover you can drain some of the water from the radiator using the lower drain plug and add antifreeze.
Mar 09, 2009 | 2001 Ford Taurus
Bmw 523i se heater blows hot and cold
Sounds like a thermostat sticking. Some things to do. First check coolant level is up and moving. Second (most likely), change thermostat. Very easy fix for backyard mechanic. Make sure to put thermostat in so water flow is correct direction. Look for arrow on side of thermostat. Next, is belt to water pump loose. Another easy fix in most cars.
Jan 10, 2018 | 2001 BMW 5 Series
I have a bmw 523i se and the windscreen wipers wont work have tried changing the fuse in the glove compartment but still wont work
it's normal, windshield wipers in bmws are connected to the speedometer since the old E36 3series, so they stop whenever you stop your car. If they start again once the car moves there's nothing wrong with your car!
Aug 25, 2008 | BMW 525 Cars & Trucks
Radio Communications Logo
242 people viewed this question
Top Radio Communications Experts
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
