Question about Dell Inspiron 1521 Notebook
My touchpad mouse skips
I calibrated the pad sensitivity (both ways) i calibrated it several ways. I have even switched operating systems completely. same problem!
  • bluechipvip Sep 21, 2009
    I have one of the same model...The skipping comes from the pressure of your hands, around the area. if (theoretically) you were able to pull up your palms while you write (Which is not practical) then the prob. would go away.
  • 733 Answers
Try cleaning it with a little alcohol. If that does not help, you might need to buy a new touch pad.
Posted on Sep 05, 2009
My cursor keeps jumping and moving the letters in my emails.
Step 1:
If you are a frequent user of a notebook or netbook computer, then you likely use a touchpad to navigate your computer's on-screen cursor. However, there are a number of issues that can cause your cursor to seem jumpy or unresponsive. To find what is causing these issues, you can troubleshoot both your hardware and your operating system and find a solution to the problem.
Turn your computer off and then clean your touchpad. Dampen a clean cloth with some isopropyl (rubbing) alcohol and then pat the pad dry with a paper towel. Even a small stain or sticky spot can throw off your touchpad's sensitivity, so it is vital that the pad remain clean of all extraneous substances. Re-calibrate your touchpad. Go to the hardware section of the "Mouse" utility (in the Control Panel) and find the device settings. There should be an "Advanced Settings" or "Calibration" utility under this tab. Follow the prompts to calibrate your touchpad for maximum efficiency. Use manual troubleshooting wizard. If you suspect that your computer's software or drivers are at fault, run the manual troubleshooting wizard. Go to the "Mouse" utility (in the Control Panel) and then go to the "Hardware" tab. Select your touchpad and then click on the "Troubleshoot..." button. Follow the prompts to troubleshoot software issues that could make your touchpad jumpy. Reduce cursor speed. In the "Mouse" utility, go to "Pointer options" and reduce the speed. This will prevent the cursor from going too fast when you move your finger on the touchpad, which could be the source of the "jumpy" effect.
Feb 15, 2013 | Toshiba Computers & Internet
Jumping cursors and letters
Step 1:
Feb 15, 2013 | Toshiba Satellite Computers & Internet
Lenovo essential mouse pad too sensitive
go to mouse settings in Control Panel, then choose your touchpad and change the sensitivity.
Feb 04, 2013 | Lenovo G580 Laptop Computer - 268938U -...
I have a Dell Inspiron 1545 which has three problems, the battery discharges faster than when used by another computer of the same make, the screen lighting often blinks severally before it completely goes...
http://download.cnet.com/ccleaner/
run crude cleaner to get the flicker and speed the laptop up
get a new battery... if discharges too fast.. like less than 45 minutes
cursor jumping around.. watch your touchpad..
commonly you are touching the mouse pad during some keystrokes
you can set the mouse pad sensitivity downward under control panel--> mouse---> synaptics mouse pad sensitivity also
Jan 21, 2011 | Computers & Internet
I have a TOSHIBA NB100.The mouse pad is too sensitive .I can even move the cursor hovering my finger above it without touching the pad .I thinlk it causes words and letters to come out as a jumble. Is...
control panel----Mouse----Should bring you to a screen with several tabs at the top-----pointer options tab---Select a pointer speed this should slow down the mouse movement----then go to the first tab (touchpad) and you can change the touchpad sensitivity. Hope this helps
Jan 07, 2011 | Computers & Internet
How do you reduce the touch pad sensitivity in an Acer One Aspire Notebook ZG5? Thank you very much
In order to reduce the Touchpad sensitivity you may follow the following troubleshooting steps:
1. Goto Start--->Control Panel--->Mouse and then change the mouse sensitivity accordingly. Some laptops (like HP) comes with a Synaptics program which you may find in the control panel.
2. Double click the Synaptics and in the user interface, select the Touchpad sensitivity as per your needs.
Thanks & Regards, techbuddy247
May 26, 2010 | Acer Computers & Internet
Touch pad problems
Dell has their own utility for the touch pad.. it may be its own icon in control panel
Feb 11, 2010 | Dell (6F858) Cooling Fan
When typing an email the keys skip back to the
When I have seen this happen, the touch pad was set overly sensitive. When you are typing, your palm may be moving the cursor. If this happens at other times, then this can be corrected in the control panel. Go there and click on touch pad. It will have settings to set the sensitivity for the mouse pad, speed, double click/single, etc. You can change the settings to be more suited to your hands.
FYI: Older laptops were more susceptible to touchpad errors and I have even seen the area on either side of the touchpad to cause the mouse cursor to move and jump.
Good Luck
Dec 16, 2009 | Toshiba Computers & Internet
You can change the sensitivity by entering Dell Touchpad utility (in Control Panel -> Mouse, if you DON'T have any external mice installed)
Maybe it is also enough to calibrate the mouse speed in Control Panel -> Mouse.
Oct 28, 2009 | Dell Inspiron E1505 Notebook
Dell Inspiron 1521 Notebook Logo
369 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
