Question about Ricoh Aficio 1035 Copier
Fusing lamp of my Ricoh Aficio 1035 was broken 230V 650W red
Where to buy in Cebu City
Elite Business Machine. They have branch in Cebu
Posted on Sep 10, 2009
  • Ricoh Master
  • 1,294 Answers
Measurement the countinously of the heater lamp,check the thermistor and thermofuses nad reset the error code.
Posted on Sep 05, 2009
Err cod 542 Ricoh 1035
replace the thermostat & reset 107 turn off & on the the main switch. sometimes the body of the fusing unit that hold upper roller bushing get damage. if u reset it will be ok, and at certain time the code will appear again. if the body of fusing unit got broken then u got to replace it. once more, check the thermostat, normally 1 of them got broken.
Aug 25, 2011 | Ricoh Aficio 1035 Copier
SC542 on Ricoh Aficio 1035 - I replaced both thermistors with new ones. I did the service code thing yellow button 1,0,7 then red and hold and shut the machine down. It copied for a little while and the...
You only change the thermistors????
What about the hot roller???? If there is crusted toner in the hot roller the thermistor cant read the temperature. Also see if the thermistor are in good position (they have to touch the surface of the drum).
I advise you to also check the thermostats and the fusing lamp (see if they have continuity)
Feb 24, 2011 | Ricoh Aficio 1035 Copier
Sc541 ricoh 1060
Verify the fusing unit contacts,thermistors and thermalfuses,heater lamps continuity.If is OK enter in the service mode:press yellow key -1-0-7 and press and hold 4 seconds the C red key.When appaire to the touch pannel service menu or copy sp press the windows,open the front door,close the copier machine on the main button and wait 10 seconds.Press ON the main switch close the front door and make a copy.If anywhere is replaced the heaters lamp,check the contact in the back side Orange wire to Orange wire,and the Red wire to Red wire contacts.
Dec 02, 2010 | Ricoh Aficio 1035 Copier
Code error SC 541 ricoh aficio mp2550
SC541 is a Fusing thermistor open (center) The temperature of the hot roller remained below 0oC for 5 sec at the center of the hot roller. Fusing thermistor out of its position because of incorrect installation. Fusing thermistor disconnected or defective power supply not within rated range (15% or more below rating). Try cleaning or replacing the thermistors and reset code in service mode.
Jan 30, 2010 | Ricoh Aficio 1035 Copier
Codigo sc546 aficio 1035 ricoh
SC546: Unstable fusing temperature
Symptom: The fusing temperature does not rise
3 °C or more within 5 seconds after the
fusing lamp has been on over 8
seconds.
Possible Cause: • Thermistor defective
• Power supply unit defective
Dec 11, 2009 | G-Technology WWD-91500101 G Speed 1500GB...
Gives code sc541 on Ricoh 1035
Clean the fuser thermistors.For reset enter in the service mode : press total clear (yellow)key-107-clear(red)key,touch SP mode,open the front door and turn OFF the power switch.Unplugged the machine,wait 10 sec.,plugged the cords,close the front door amd turn ON the power switch.
Nov 21, 2009 | Ricoh Aficio 1035 Copier
Ricoh aficio 1035 error code SC121
sc 121 is related to optics section of your machine.check the lamp is glowing .if so check the connection from optics to main board.
Jun 15, 2009 | Ricoh Aficio 1035 Copier
Error 52 on ricoh FT3213.
error code 52 on ricoh ft3213, that's mean heating element burn out , such as heater lamp, thermister , thermo fuse.
Dec 09, 2008 | Ricoh Aficio 1035 Copier
E1 ERROR ON RICOH FT4022
E1 Exposure Lamp problem. (sensor, lamp, lamp stabilizer)Either the lamp is blown, the board is bad or the sensor is bad.
Nov 11, 2008 | Ricoh Aficio 1035 Copier
Ricoh Aficio 1035 Copier Logo
134 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
