Question about Gateway FPD2275W LCD Monitor
USB ports on monitor not working. I have the Monitor hooked up to my HP laptop?
    Scholar:
  • 96 Answers
You will need to install the drivers for the monitor on your laptop. The CD will come with the Gateway monitor.
Posted on Sep 05, 2009
What is the use of rear usb ports
The USB ports on the monitor will work only if you connect the monitor via a USB cable to your PC/Laptop's USB port. Sounds awkward. Doesn't it? There must be a USB cable with flat socket on one end and trapezium shape jack on one end. It should be in the box which the monitor came in. The USB ports in the monitor are just another extended USB ports for your PC/Laptop. If you can't find the cable mentioned above, it is the same cable you connect to a printer, scanner,........ In some cases you might need to install a driver which should also come along with monitor. Mostly you don't need to install.
Good luck.
Sep 13, 2013 | Dell UltraSharp 1905FP LCD Monitor
Hook up to home pc
Today's laptops and desktop computers are more user-friendly. As more people start use computers, operating systems, software and hardware accessories are coming with better instruction manuals and streamlined interfaces. Here are a few basic steps to hook up your computer no matter which brand you bought.
Connect the power cable to the back of the computer tower. The male end of this plug is often on the computer, but it is recessed into the casing. Once this power plug is connected, you don't want to plug it into an outlet until the entire computer is set up. Attach the monitor cables to the back of the monitor and then to the back of the computer tower. This cable will probably be the VGA type, which has a wide set of prongs in the middle and two screws on the outside. Be sure to twist the screws in to ensure the cable has a solid connection. Secure the monitor's power cable to the back of the monitor and then plug it into an outlet or power strip. Attach the mouse to the USB port on the back of your keyboard. The keyboard then plugs into another USB port on the back of the computer tower. Turn on the computer and the monitor.
If the computer powers up but the monitor doesn't display anything, make sure the VGA monitor cable is secured. If the status light on your monitor doesn't turn on, check the power cable connection. Check that the mouse and keyboard work once the computer turns on. Now you can hook up other devices, such as a printer or a web cam. A printer often can connect to a USB port and also may have its own power cable; a web cam usually just plugs into a USB or firewire port.
b>
Jan 21, 2013 | Acer Aspire 5535-5050 Notebook
My usb port on monitor isn't working. how can i fix this?
Good luck.
Apr 13, 2012 | NEC MultiSync 1770NX 17" LCD Monitor
None of my USB ports on my p2210 monitor are working How do I fix. Thanks
be sure that you connect usb cable between pc usb port and monitor usb port and try its usb
good luck sir
Apr 01, 2011 | Dell P2210 Monitor
Permenent removal of lcd & lid from HP mod dv9000 17in laptop. Hindge broken..do not want to replace. Want to hook uo 20in monitor. But another problem with VGA port on laptop. No screw-in's on laptop...
Buy a usb to vga connector. This will allow you to plug in your monitor. I can sell you one for $50.00 + shipping and taxes if you email me your email. I have those in my store.
Mar 18, 2010 | HP Pavilion dv9000z Notebook
The monitor has 2 USB ports on the left side of
It is basically 2-port USB powered HUB built into the monitor, did you hook up the USB cable from the monitor USB Input port to the USB port on the PC?
Jan 08, 2010 | HP w2207 Monitor
I just hooked up my HP Pavilion 9000 Laptop to my Vizio TV and put the TV on correct setting. It is not working on the TV, any ideas? I went on Display setup and kept trying to connect but it says the...
If your laptop has a VGA port, your Vizio needs to have a VGA port too so you can use a standard VGA monitor cable.
If your laptop has a DVI port, you hook it up to the Vizio using a DVI-to-HDMI cable.
And if your laptop has an HDMI port, you hook it up using a standard HDMI cable.
Hope this helps.
Oct 16, 2009 | HP Pavilion dv9000z Notebook
Monitor warning pc enter power saving mode
Are you using usb keyboard and muse. if so your usb ports are dead
Jun 16, 2009 | HP Pavilion a450n PC Desktop
Usb ports on side of monitor HP w2228h not working?
the two usb ports on the side of my hp 2207 h monitor stopped working?
Mar 21, 2009 | HP Computers & Internet
Computer won't recognize monitor driver
Its the usb, if u connect the monitor via the standard port, the vga port, it will work. If your monitor only have an dvi cable you can fix that by an adapter. That adapter should be an DVI to VGA.
Good luck to you
Dec 11, 2008 | Acer AL2016W 20" LCD Monitor
Gateway FPD2275W LCD Monitor Logo
232 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
