Question about Nokia 5800 XpressMusic Smartphone
I cannot send business cards of my contacts via bluetooth from nokia 5800 to htc touch hd. The phones are connected via bluetooth. I get the msg "sending failed" on my 5800. Kindly help. I need to trf all my contacts to the htc hd.
No contacts in address book after pairing nokia C5 with Parrot CK3100. I find that my contacts are not available on the handsfree. I have used 2 other phones, with this same device, without a problem.
Your Parrot may need updating to work properly with a phone as new as the C5. but you can try the following,
To send a contact
* From the phone press MENU button and go to CONTACTS
* Select the contact you want to send and chose OPTIONS / SEND BUSINESS CARD / VIA BLUETOOTH / MORE DEVICES
* The phone will search for the available devices
* From the list select the Parrot Product
To send several contacts:
* Select the contact you want to send and choose OPTIONS / MARK/UNMARK / MARK
* Repeat procedure for several contacts
* Open the OPTIONS menu and chose SEND BUSINESS CARD / VIA BLUETOOTH / MORE DEVICES
Oct 01, 2011 | Parrot Hands-Free Car Kit with LCD Display...
Need to transfer all my contacts from noki's ovi to new doro 410 or from nokia 8120 with bluetooth to doro 410 with bluetooth
Welcome to Fixya
Standard procedure when transferring contacts to another phone via bluetooth is, go to the to the phone's contact list and and press options. If the phone has bluetooth capability, it will display there "send VIA Bluetooth" as options. Select that option and make sure that the blutetooth of the recipient phone is enable. Once the main phone have searched the new phone, just press send and then acknowledge the business card on the new phone.
Thank you for using Fixya!
Aug 31, 2011 | Cell Phones
Copy nokia contacts
Send via bluetooth or
copy all contact from sim - put that sim in to HTC - copy now from sim contact to phone
Mar 17, 2011 | HTC Touch HD Smartphone
I have a Nokia 6120 mobile that is connected to a parrot 3200ls car kit .When I turn to phone book nothing apears .I beleive it should sync the phonebook but it turns off the connection when I try
Try this from Parrot.com, cheers Dan
Performing object push process:
** On the Carkit go to Settings / Contacts Management / Receive Contacts
* For one contact sending:
* On the phone go to MENU / CONTACTS
* Select a contact to send by pressing OPTIONS / SEND BUSINESS CARD / VIA BLUETOOTH
* Select the 3200LS from the list, that will start the file transfer process
* To send all contacts:
* Select OPTIONS / MARK/UNMARK / MARK ALL / OPTIONS / SEND BUSINESS CARD / VIA BLUETOOTH
Nov 19, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
My nokia n95 will connect to my parrot hands free but no names transfer to the parrot what am i doing wrong?
Object Push: To send one contact:
* From your phone go to MENU / CONTACTS
* Select the desired contact to send and go to OPTIONS / SEND BUSINESS CARD / VIA BLUETOOTH
* The phone will start searching for available devices
* Select Parrot Product from the list of available devices
* The contact will be transferred
* Select the desired contacts to send with OPTIONS / MARK/UNMARK / MARK
* After the desired contacts are selected go to OPTIONS / SEND BUSINESS CARD / VIA BLUETOOTH
* The contacts will be transferred
Oct 04, 2009 | Parrot Hands-Free Car Kit with LCD Display...
Receive files via Bluetooth
I think that files received via bluetooth are saved in to the phones memory unless you have an option to choose location. Otherwise after receiving filr manually move from device to memocard.
May 30, 2009 | HTC Touch HD Smartphone
To send MMS and Music via Bluetooth from HTC Touch HD
Hi, you can't send MMS via BT. As for music just highlight the desired song(.mp3 file) and click on Beam file(or send file).
May 14, 2009 | HTC Touch HD Smartphone
How can i transfer my contacts from nokia phone to my HTC Touch
There are few tools to have. A usb cord, your PC has Bluetooth and pair with you N51 via bluetooth. Have the free software, "Nokia PC Suite". Download it from www.nokiausa.com/PCsuite. It's a free download. Once downloaded, restart your computer. (without the phone connected) Connect. It'll give you easy step by step instructions to transfer contacts to the computer. Plus, other multimedia you may have on your device. Very handy!! Then, just use Active Sync or any software you got with your HTC Touch HD. It can sync you contacts from Outlook onto the new phone. This is nice, in case your phone would crash, break, or the worse stolen. Your contacts are all backed up on the PC.
Always take a look at www.htcwiki.com for the best tips & tricks for your HTC device and software updates. A lot of times they will even post known issues and work arounds.
Feb 10, 2009 | HTC Touch HD Smartphone
Unable to send pic via HTC bluetooth
1. When someone sent file (photo, music..) to you, usually it is store at My document.
2. If you want to sent file: 1. open your bluetooth by start-setting-connection-bluetooth after check both checkbox. Then go to file explorer, select the file you want to sent by hold that file and choose beam. After waiting for device check for bluetooth and then click on your bluetooth name you want to sent.
enjoy it!!
Nov 17, 2008 | HTC Touch Cell Phone (Unlocked) - Soft...
Nokia 5800 XpressMusic Smartphone Logo
155 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
