Question about SanDisk 2GB microSD Memory Card
My computer doesnt read my sd memory card..it
My computer doesnt read my 4 g sd memory card..it tells me to format it, i do and it still says the same thing... i payed heaps for this card and i dont want to throw it out..please help!
    President:
  • 392 Answers
Unfortunately your memory card is damaged. you need to get it replaced. If u have warranty better you go for it.
Posted on Sep 05, 2009
Testimonial: "thank-you. also thanks for fast reply"
I have an Akai DC6371 digital camera and the card I have in it is a Kodak 128mb SD card. However, the camera will only let me save 4 pics to the SD card. I tried putting a different card in it that's...
Hi I can tell that sometime you have to format within computer using external memory card reader, not from camera. It is not recommend switching around one sd card to another camera. It cause card error. If you want to use it, then you have to save pictures somewhere in other storage or computer, and format the one you want to use in computer using external memory card reader. And then one more time format in camera (you have to insert memory card into camera) These method very helpful on like your problem. If not working, then you have either camera defective or memory defective. Thanks and best regard!
May 25, 2011 | Akai DC6371 Digital Camera
I removed my SD card without turning the power off and now I can't read the card. Can the images be recovered?
Dont worry, a good SD card recovery program can help you. you can recover your images from SD card with asoftech photo recovery program.You can see
http://www.asoftech.com/apr/
It tells the steps how to perform picture recovery.
If above does not work, you may have to format the memory card (use quick format), and then use above mentioned software to scan again the memory card and recover your files.
Mar 26, 2011 | Canon Powershot A1000IS Digital Camera
C190 does not read the sd card even when sd card format is ok . it is giving a message 'memory card requires formatting' 'please format memory card or insert another card' however inserting a new...
Hi sir
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • May 20, 2010 | Kodak Easyshare C190 12MP Digital Camera...
    I am trying to format a micro sd card card for my psp. i read that i could format it as fat 32 but it doesnt work. i also read that i can save a game on my computer from an already formatted sd card and...
    I don't know if this helps, but the PSP does not use SD or micro SD cards, it uses Pro Duo cards only, to format one all you need to do is put it in the PSP and choose Format Memory Stick from the System Information tab of the Options menu.
    I hope this helps in some way.
    Feb 26, 2010 | Sony PlayStation Portable (PSP) Console
    My micro sd wont read on my computer or phone & when i put it in the camera it says ''memory card error'' help!
    1. If your Micro SD memory card can be detected on your computer, then try to completely format the card.
    2. Goto Start >> My Computer >> Right-Click the memory card icon >> Format >> Uncheck the Quick Format option >> Start >> OK / Yes (confirm the request!).
    3. If the memory card cannot be detected / readed by your PC, phone, and camera, then that card has become corrupt / unrepairable,
    4. You should replace that memory card with a compatible one!
    please rate this advice if it helps...tc! :)
    Jan 14, 2010 | Electronics - Others
    PNY Optima SD HC 8GB isnt working on laptop
    Youll have to get updates for your laptop card reader or get a new one which may have to be installed. Another method you may want to try would be to put the card back into the device you used it in and then hook the device up to the computer, most likely through the USB slot....good luck
    Jun 05, 2009 | PNY Optima Pro 2GB Secure Digital Memory...
    Memory card micro sd cannot format
  • Mar 11, 2009 | Samsung Eternity Cell Phone
    8gb micro sd card does not work. lg vu cu920. is there a fix
    I HAD THE SAME PROBLEM AND KEPT ON MESSING WITH THE 4G MEMORY CARD AND FOUND OUT THAT I HAD TO FORMAT THE MEMORY CARD ON MY COMPUTER AND NOW IT READS THE CARD..ON THE SIDE OF THE SD ADAPTER HAS A SLIDING PIECE THAT SAVES YOU FROM DELETING THINGS ACCIDENTALLY BUT IF YOU SLIDE IT INTO THE MIDDLE POSITION THEN IT WILL ALLOW YOU TO FORMAT THE MEMORY CARD BUT YOU WILL LOSE WHATEVER THAT IS ON THE MEMORY CARD AND WILL HAVE TO DOWNLOAD IT ALL OVER AGAIN..I HOPE THIS IS CLEAR ENOUGH FOR EVERYBODY TO UNDERSTAND BUT THIS IS HOW I GOT MY MUSIC AND PICS ON THE MEMORY CARD
    Jan 26, 2009 | LG Vu CU920 Cellular Phone
    New sd memory card 8 gb keep formating
  • Aug 31, 2008 | JVC Everio GZ-MC200 Camcorder
    Memory Card
    The DATA on your SD card has become corrupt or the SD card itself has become damaged / faulty. ..... Hopefully , some time back , you backed up your SD card to your computer ? . All you need do is format the card and then reload the files from your PC . If the tomtom still doesnt load up then you would need to purchase a NEW BLANK SD card and reload your backup onto it. If that doesnt solve your problem and if unfortunatly you didn't back up the original card then you will need to purchase a NEW TOMTOM SD card with activation code . Bad news and a learning process , always back up your tomtom card !
    Feb 04, 2008 | Tomtom ONE GPS Receiver
    SanDisk 2GB microSD Memory Card Logo
    391 people viewed this question
    Top SanDisk Electronics - Others Experts
    Piyal Perera
    Piyal Perera
    Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
