Door lock broken on Ariston Washing machine . How do i open teh door?
  • Washing Mach... Master
  • 3,463 Answers
Remove top cover, tilt washer backwards, and force door lock from inside with a long screwdriver or similar, you will break the lock, so have a new one ready to fit
Please rate my solution.
Thanks.
Posted on Sep 05, 2009
Door locked,cant open
just get an old door from any ariston..hotpoint or indersit machine make sure it is the same size
Jan 12, 2014 | Ariston Technologies Ariston AWD12 Front...
Constant clicking of door lock
Suggestion: Try a little WD40 spray on the door, not on the machine. Close and open 2 or 3 times while plug is off the wall mains.
Click if helped.
Apr 14, 2013 | Ariston Technologies Ariston AWD12 Front...
Door handle on ariston awd12s has broken how i can i get the door open
open the table top of the machine and release the door switch by any flat screw driver
Jun 06, 2010 | Ariston Technologies Ariston AWD12 Front...
Broken door handle on washing machine
You can purchase any of the parts individually for the door handle.
If you go on line and enter Ariston door handle in search box, you shuold be able to locate the part/s you require.
Good luck.
Jan 06, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
My ariston washing machine door not locking
I recommend replacing the door latch. It is a fairly common problem. You can get one at repairclinic.com or partselect.com
Jan 02, 2010 | Ariston Technologies AWD121WH
ARISTON WASHING MACHINE DOOR PROBLEM SO ON/OFF BUTTON DOESNT WORK
Well it depends on how old your machine is, if eveything else is fine then replace it. The cost will vary depending where you buy your part from. It could cost but worth it if machine is reliable. try
www.lpdlpd.co.uk
Aug 09, 2009 | Ariston Technologies AWD120 13 lb. Washer...
We have the Ariston Margherita front loader washing machine and cannot get the door open
if the machine is full of water pump blocked or broken if machine empty needs new door interlock or pressure switch blocked or broken
FIRST switch off and unplug.
Pull machine out and remove lid by undoing self tapping screws at the top back. May have to slide lid back a bit to lift off.
Internal catch mechanism will be reachable from top for manual release. You may need someone to push door inwards while you release catch.
Good luck
May 17, 2009 | Ariston Technologies Ariston AWD12 Front...
Cant open door of washing machine
I plugged it out. Left it for 15 minutes. When I went back the door could be opened and it also started to wash.
Jan 20, 2009 | Ariston Technologies AWD121WH
Door Stuck after wash completed
You will have remove top cover, and release door latch from inside the front, with a screw driver pushing against the latch to open door.
It does mean that you probably have a faulty door lock, or broken door handle.
Please rate my fixya solution.
Thanks
Jan 11, 2009 | Ariston Technologies Ariston AWD12 Front...
Closed door
Dear babmat: just now got your question. We are very satisfied with our ARISTON Washing Machine. I trust that that is what you are inquired about? I had the same problem the first time. This locking occurs when one opens or tries to open the washing machine door too soon!!!! It has to be left alone for a few minutes. When I waited and later tried again to open the machine, I did not have a problem.
Just wanted to leave this note for anyone who encountered the same problem. You, yourself, hopefully, might have gotten that answer and the problem fixed in the meantime!?
Greetings, handinovice
Sep 04, 2008 | Ariston Technologies AW129NA 16 Lbs Front...
Washing Machines Logo
527 people viewed this question
Top Washing Machines Experts
