Question about EliteGroup ECS P4M800-M Socket 478/P4M800/FSB800/A&V&L/M-ATX Motherboard (MOTEC18)
No display on monitor
Hi gurus. the power turns on, and the monitor is on, but there is no display. can not find the MOBO';s gpu plug, and therefore am using the videocard that is already pugged in. Can not tell if there is an error, as the MOBO does not beep as if the MOBO has recognised a problem
Hey there, my computer wont boot at all, there is no monitor display and there is no beeping sound, as if there is no signal flowing to different peripherals. the only thing that is working when i turn on the power is the hard disk led that lights all the time. All fan are working and i think this not the problem of power supply..
Is my motherboard dead already..
  • Reynante Manriquez
    Reynante Manriquez Dec 10, 2007
    thank you for giving a tip for my problem.. but it still didnt work i have tried that already..
    I have connected it already to the onboard display plug but still the problem remains.
    I have also tried to disassemble everythig by removing them on the motherboard and tried if the motherboard has the error. I tried removing all the add on cards including memory and the processor itself and the result.. the same error. No sound on the motherboard as i turn it on and no signal to the monitor. And the misterious light of the red LED(hard disk led that is lit and not blinking at all times.
    Hope to have some more suggestions
  • 209 Answers
No, its working as you said. try to uninstall your video if you installed to expansion slot (agp) then use the on board. that is one of the most common problems of pc specially when you're moving this from one place to another. if it boots from your onboard vga clean your uninstalled video card then reinstall to your agp. i hope that this helps you
Posted on Dec 08, 2007
    JOSE BAUTISTA Dec 08, 2007
    what i mean is that your video card to be uninstall if this is just from expansion slot or agp then use the onboard vga to check if the problem is your vdeo card
Computer not always showing up on monitor after reboot. It only works after I turn pc off by button and psu off and on but only randomly. I am not sure if it is the mobo or psu or gpu - a gtx 960.
It might just be worth double checking that its not in fact your monitor at fault.
you said the the monitor isn't always displaying the picture, but you can hear that the computer is on?
You also say you are turning your computer off and on to cure the problem, which of course also power cycles your monitor.
When it happens again, power cycle your monitor by turning it off and on to see if the image reappears?
Apr 24, 2016 | Gigabyte Computers & Internet
Mainboard: g31 m7 te - power: antec hcg750 - gpu: gtx560ti
No the mobo is compatible with the Power Supply, and GPU.
And vice-versa.
Mainboard fan???????
You mean the Processor (CPU) fan?
I'm guessing I guess, because computer case fans aren't on the motherboard/mainboard/mobo.
You're getting power to the mobo, but the question is how much?
1) IF ALL of the LED lights were on at once, they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use from 51 to 125 Watts of power.
Just depends on what Processor it is.
The mobo will support Intel Core2 Quad-Core processors. Depending on which one, you may be talking about Up To 105 Watts of power,
This is why LED's can light, and fans may spin, but the Processor isn't getting enough power, so the computer will not turn on. (Processor isn't turning on)
1) Just because that Power Supply is new, doesn't mean it is good.
Sometimes you get a bad one. Test the three main voltages coming out, with a multimeter set to DC Voltage.
Need guidance post back in a Comment.
(An economical multimeter can be purchased, for as little as $8 to $12. I have seen cheaper. Available in a multitude of stores. An auto parts store is but one example )
2) You don't have the 4-pin ATX +12 Volt power cable plugged in.
Goes to the white square 4-socket hole connector, to the left top corner of the Processor socket.
(Motherboard installed in computer case)
3) REQUIRES -> TWO 6-pin PCI-Express power cables, for the Nvidia GTX560Ti graphics card.
The Antec HCG750 PSU has 4 of them, so no problem there, IF you have two of them plugged into the graphics card.
Both connectors of the 20 + 4-pin ATX main power cable's connector, need to be used. Biostar mobo requires a 24-pin ATX main power cable.
Post back in a Comment as to power cables plugged in, and DC Voltage test on PSU.
Aug 06, 2012 | Biostar G31-M7 TE Motherboard
Hi when I try to install vtx radeon hd 5450 graphics card no display is shown on monitor and all fans run fast computer appears to be booting but can't tell. compaq sr1519uk with MSI MS-7184 mbo,...
Hi Dave,
1. Have you ever tried testing your VTX HD5450 GPU to another system or try bringing it to the store where you purchased it.
2. After removing the VTX HD5450 GPU, did your Nvidia 8400GS worked? - If it works there might be a compatibility issue between your MOBO and HD5450 GPU if the card is good.
3. I think there is nothing to configure on your bios regarding Graphics setting because your Nvidia 8400GS worked without any problems.
4. Did you check the VGA/ DVI cable and power cable if it is plugged to the proper ports. There are times that even tough we are that good we miss something.
Hopefully this information helps.
Thank you for using FixYa.
Aug 20, 2011 | Computers & Internet
Computer does not display any boot screen, although it turns on. no USB ports work, not do any other inputs on the rear of the machine. this was done after migration of parts to a new case for the...
DC5000MT (i think you left off the"T" right?) MT=mini-tower then.
they at SFF then too.
old old desktop pentium 4, with pata hard drive?
no monitor stated, make nor model #
no vga card stated.
migrating? oops.. why do that? nor if PC ran before?
NO OS stated,? windows XP what? (it came with XP)
ok the mobo turns on with case power button?
and the CPU fan spins fast, as does PSU fan?
what does USB ports mean>? using what there?
PS/2 keyboard. using that? or pS2/mouse?
does it beep:?
are you sure the monitor is ok?
if monitor is ok ?
and PSU and 1 stick of ram is ok
the BIOS screens work.
or the PSU
does this mobo have onboard VGA jack GPU:>
if yes, try both it and PCI video card.
and 1 stick of ram at a time. slot1, bank 0
Aug 12, 2017 | HP DC5000M PC Desktop
Hi, My Hp Elitebook 6930p display sometimes just goes progressively blank...the image freezes and then it goes from white to a lot of different colors (every pixel different color) and then just black...
easy, plug in any external display (vga first)
work now.?
also my elite book has a removable video card
also run free temp monitor software, as CPU core heat and GPU
if GPU overheats, fix that first.
mine has the 15p vga rear
and a video port left that i connect to my HDMI adaptor to TV
so i can watch screen on huge 60" tv if want.
why not use the external displays?
the hot key on top row turns this on..
the manual is free to read 24/7
page 16 in your manual shows
"VGA (Dsub 15-pin) supporting 1600 ×
1200 external resolution at 75-GHz (hot
plug/unplug with auto-detect)"
mines set to auto detect. per same book.
my 8540w has "DISPLAY" port left side and works with HDMI
so mines more ELITE, nana nana.....LOL
Mar 02, 2017 | HP EliteBook 6930p Notebook PC
Is the msi 650i mobo compatible w/ the 260 gtx sc vid card ?
your gpu might of overheated and burned out, you might want to flip the computer over,, and right next to the RAM there is like some type of card, which is your GPU, you might want to look into pulling it and replacing that.....
another way of doing this that might work is connect the laptop to another COMPUTER Monitor, and see if anything is displayed if nothing is displayed it might be b/c your GPU did burn out....
i hope this helps please let me know what happens...
Apr 11, 2009 | Intel Motherboard
Nvidia geforce 9500 gt gpu work on asus p5n73-am
Hi! can use that gpu with that mobo, but i wouldent recomend it. The GPU - Requires NVIDIA HybridPower™- enabled motherboard, and that mobo dosent have that. It might work but you cant use the full power of that gpu on that mobo. And beside that, that gpu is bigger then the mobo itself
I sugest you to buy another mobo, the gpu you looking at is a good one but your mobo isent that good.
Here is the spec for the GPU:
And here are the spec for that mobo:
Good luck
Mar 03, 2009 | Computers & Internet
My Monitor turns off randomly
First check to make sure your drivers are up to date and the card is seated properly. Then If your graphics card is still under warranty take it back and get a new one. For some reason it is cutting out the signal to the monitor.
Dec 11, 2008 | Acer Aspire 9300 Notebook
3870x2 GPU issue
I read your other comment posted on the other topic, and yes I have to agree, I think your GPU has blown.
I write this, because I had the same problem about a year ago. The power switch on my old tower case had broken, so I bought a new one. Swapped everything over, turned it on, and, wham! Everytime I tried to boot, I got either the Blue Screen Of Death, or nothing. I tried everything. I swapped my GPU, as I had a spare one, but the still nothing. So I thought I had blown Mobo. Bought a new one, but still the same. In the end I gave up and paid for an egineer to have a look.
Basically, when I swapped cases, I blew the Mobo (and I'm a systems builder, lol), this in-turn blew my GPU (which is why it didn't work on new Mobo). I replaced GPU on new board, and would you believe it, it worked.
Replace your GPU (but if you can, test with a spare one, just in case it's your Mobo that's blown).
Cost me a bomb, but I hope my mistake saves you money.
Dec 09, 2008 | Computers & Internet
no video and no post beep suggest a serious fault, most likely in CPU or mainbard, but occasionaly ive seen that really bad ram can prevent a system from booting, start with changing the ram, and CPU if needed, if either of those dont work, mainboard sounds shot
Dec 07, 2007 | Gigabyte GA-6VTXE Motherboard
EliteGroup ECS P4M800-M Socket 478/P4M800/FSB800/A&V&L/M-ATX Motherboard (MOTEC18) Logo
188 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
