Question about SanDisk Memory Media
Formatting sandisk 2gb
How do i format my new sandisk 2gb on my pc (windows xp). many thanks,
  • 2 more comments
  • elle243 Dec 09, 2007
    windows didn't ask me to format...
  • costasbrehm Dec 25, 2007
    My SanDisk 2GB card works on my camera and every computer I've tried except my laptop. When I try and open it there it says it's not formatted, and says it's unable to format it. Any suggestions to fix my laptop to I can add some things to the card?
  • rajbharmal Jan 03, 2008
    the drive letter comes when i plug the pendrive but it says no media present when i open the drive. I m not able to even format the pendrive
  • Anonymous Jan 13, 2008
    unable to format the 2gb sandisk card
When you insert a disk in drive windows automatically ask you to format a drive ok to proceed.
Posted on Dec 08, 2007
I just bought 2gb SanDisk Memory Card, a few days ago it requires to be formetted and I dont know why. When I intend it to format at my PC it just says "Windows can't format E:/". What should...
try using linux
then also try using your phone or whatever the disk was to be used if not then g to control panel and look for the administrative tool click it, go to computer management and try format it from there. If all this can't work then, return the product to the dealer
Sep 12, 2011 | SanDisk 2GB microSD Memory Card
2GB Micro SD needs format code that I never gave it
You can format your micro-SD Card using a software which you can download by clicking this link. I uploaded it to my FTP site for you and it will be there for a limited time. Download that file and save it to your PC. Then unzip that ".zip" file.
If you format micro SD card connecting it to your PC via USB port, it may not ask for password. (I think your phone asks password to format.)
To format your micro-sd card:
- First plug in your micro-sd card into you PC.
- Run the downloaded "HPUSBFW_2.2.3_MASTER.exe" file.
- In the program menu window, select the device (your memory card).
- Select FAT32 as file system,
- Confirm that all the format options unchecked. (Uncheck the quick format option)
- And click the "Start" button to begin formatting.
Hope this helps you.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
May 12, 2010 | SanDisk 2GB microSD Memory Card
Reformat sandisk reader card
1. If you have a usb cable to your reader connect it to 1 of usb ports on your PC.
2. Go "My computer or "computer " if Windows 7 then right click on the icon that show your SD memory ( it will show as another drive letter). You will then see a drop down menu with the word "format" click and follow the prompts. This should format your memory.
Mar 23, 2010 | SanDisk 2GB microSD Memory Card
Format 32mb smartmedia in FAT12
Hi friend,
ok you can try to format on windows xp.
Follow these steps:
1.Open Control panel
2.Open administrative tools
3.open computer management
4.then click disk management
select the drive and try to format as per you requirements . note that you can also delete the partition and create new..
ok
Regards
Uttam
Jan 13, 2010 | SanDisk 2GB microSD Memory Card
Formatting sandisk
try formathing the 2 GB card with fat.
May 06, 2009 | SanDisk 2GB microSD Memory Card
Format a 1 GB SanDisk
Plug Memory Card Into Memory Card reader. Make not of drive assignment. (EX: "E:")
Open my computer...
Right click on "E:", per example above...
Click on FORMAT.
Mar 12, 2009 | SanDisk 2GB microSD Memory Card
Sandisk microSD 2GB : well formatted on cellphone but...
its not the adaptor its the card hence it gives you the error means it can access it. is the card working 100% when you plug it back to the phone?
Mar 09, 2009 | SanDisk 2GB microSD Memory Card
How do u format sandisk microsd 2gb and microsdhc 4gb disks
You can only form sd Hc if your card reader is approved for SDHC use. It should tell you that on the outside of the card reader or in the documentation of the card reader.
If your drive isn't formatting 2gb, it could be that the driver was designed prior to 2gb cards being released. You could look for a new driver or replace it with a card reader that supports SD HC use as will as a 2 gb SD drive.
Nov 12, 2008 | SanDisk 2GB microSD Memory Card
Sd card format/volume problem
Its better to avoid using disk management to format to format the card.
Use this formatter to format(usually the memory cards are factory formatted in the FAT or FAT 3).
http://panasonic.jp/support/audio/sd/download/ftp/sdfv2003.exe
Or
ftp://ftp.vaio-link.com/pub/memstick/drivers/MSFMTINST250.exe
Usually its better to format the card using the phone only.
Good Luck.
Live, Love, Laugh.
May 04, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
2GB SD card no recognized
sir probably your 2gb is dead or not factory formatted... just take your receipts and take that back to where you bought it... if it is formatted probably its the same problems of those who formatted their SD with windows xp... that worsen your problem cause i think you just void the warranty of your SD card... try your SD to other card readers and if something pops like "your drive is not formatted... format i now... just click no"
Jan 20, 2008 | HP Compaq nx5000 Notebook
Electronics - Others Logo
49 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Carlos Calvo
Level 1 Expert
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
