Question about HP LaserJet M1120 MFP All-In-One Printer
Can anybody tell me how to solve plug and play error?
All my USB ports function very well, but neither of them works to install laserjet m 1120 mfp
  • tzovuk2009 Sep 05, 2009
    I have just changed my printer cable with a new one. With both old one and new one it doesn't work.
  • gagan dhingra May 11, 2010
    It seem that if your usb ports are woring fine may be printer cable is faulty. Please let me know when it was woring fine ?
Hp laserjet 1132 mfp e8 error code, how do i solve this
Hi Abu Bakarr.
The e8 error is refering to problems with the CIS Scanner. I have attached a link to the product service manual. Read page 122 about the e8 error and perform the 4 steps in the manual to fix the problem. If no luck, the CIS Scanner needs to be replaced. Good luck. http://www.feedroller.com/store/Service%20Manual/HP_LJ_M1130_M1210_Manual.pdf
Jan 10, 2014 | Canon PIXMA MP150 All-In-One InkJet...
HP Printer Software hangs during install CM2320series-win7-full-solution-AM-EMEA1-v3.1 HP Color Laserjet CM2320nf MFP Saturday 09 November 2013 - 06:09 PM ( Local Time CET , GMT / UTC + 02:00 )...
On my HP i discovered that where i was plugging in the usb at the back wasn't a usb port. Look at the back carefully to see that it is the right port.
Nov 09, 2013 | Office Equipment & Supplies
My HP Laserjet m1005 mfp is showing error 6, please provide support and help us in solving the error
Jan 24, 2011 | HP LaserJet M1005 Printer
Hp laserjet m1120 installing error plug and play so he stop installing and ask for reinstall
1. Plug the 2.0 Usb to the computer but not to the printer. 2. When the setup program ask you to plug the device, do it. (the part into the printer, which is not connected according to 1.) - nothing happens- 3. Go to your control panel; printers and devices; find the printer and select controller, properties, update controller, browse and give it the location of the installing program. This must not be zipped.4. then the original installation program will tell you that the process is complete.
Oct 20, 2009 | HP LaserJet M1120 MFP All-In-One Printer
Plug and play problme :(
Unplug the printer, run the software again to set it up, wait until it tells you to put the USB cable into the printer and then do it, not before...and so that it doesn't carry over from the first install put it in a different USB port the second time.
When infected with the Vista virus it's all about doing things in exactly the right order for them to work.
Oct 02, 2009 | HP LaserJet M1120 MFP All-In-One Printer
I have HP 3390 Laserjet MFP. The USB port no longer works
What is the exact error message you receive?You don't mention what OS you're using, but have you seen this article? Also make sure you have a good power supply to the printer. (refer here.) Possibly update your printer drivers.
Also check through these steps. Check here. And make sure you can ping the printer. ( see here).
Here's a list of resources for troubleshooting xp printer issues. There are similar available for vista here.
Finally, HP has a lot of resources available online for your printer, including parts. See here.
If you can't seem to resolve the issue with that info, write back with more details and we'll be happy to help you get it sorted out...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 24, 2009 | HP LaserJet 3030 All-In-One Printer
SCANNER ERROR 12
it is a physical brocken piece that supports scanner mechanism.
if you open that plate /scanner mechanism and if you drill that plastic sheet and try some manufactureed alluminium or metal projection and place it in the hole drilled by you and put washer and screew so that that supports ;the scanner mechanism and your scanner /printer works . the scanner mechanism may costs you around 3,000-00 rupees.
Mar 19, 2009 | HP LaserJet M1005 All-In-One Printer
Hp laserjet m2727nf mfp - fax errors - sending and receiving. comm error 350, and comm error 232. Dedicated fax line. Any advice?
Check if you have the latest firmware for this multifunctional on www.hp.com, installing newer firmware fixed communication problem for us.
Apr 17, 2008 | Office Equipment & Supplies
HP LaserJet M1120 MFP All-In-One Printer Logo
422 people viewed this question
Seeker5211
Seeker5211
