Question about Bosch & Tankless LP Hot Water Heater
My Bosh minimaxx 16 works fine, but in order to
My Bosh minimaxx 16 water heater works fine, but in order to get the right water temperature I need to fully open the faucet. I don´t want to waist to much water. Is there a way tune up the gas flow to get full gas flow from the begining?. Thanks
  • Anonymous Mar 23, 2014
    Minimaxx 13 water not heating
  • 54 Answers
No, you can adjust the water temp though.
Posted on Sep 14, 2009
TF 400 Bosh water heater stops heating
More information is needed.
Is this new installation? Or old installation that has stopped working?
What is the product-type and model number?
Add a comment, and I can look up possible manual.
Apr 24, 2013 | Water Heaters
Will not ignite
Before calling service technician, open following link for troubleshooting resources.
Manual is best place to start, open manual and word search 'troubleshoot'
Bosh also has troubleshoot page for most/some models
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Suggest that you read manual for required maintenance.
Service technician can also give tips and information for keeping your unit working.
Apr 15, 2011 | Bosch & Tankless LP Hot Water Heater
The Noritz HW Heater has been tripping out some (usually whenever the shower is running, and someone turns on cold water). LED flashing three times. Any Ideas
This is probably a 16 error code. This code indicates the outlet water spiked above the set temperature for an extended period. It usually means the heater needs to be descaled or the manifold pressures need to be adjusted.
Mar 10, 2011 | Noritz 6.3 Gallon Residential Tankless...
Hot water tank does not work when shower is on, it does however work when the faucet in bathroom is on. It quit working in the shower about a month ago.
  1. COLD MIX, HEATER DEACTIVATES
    If inlet water temperature is over 70°F due to geographic location, water maybe very hot out of the tap. This requires a lot of cold water to be added with it in order to attain a useable hot water temperature. The addition of too much cold water will overpower hot water demand from the tankless water heater. This slows the flow within the tankless water heater, decreasing it below activation point, which shuts off the heater. The end result is nothing but cold water coming out of the outlet. See: TWH E2-04 Overcoming fluctuating temperatures [PDF].
  2. FLUCTUATING WATER PRESSURE
    If the water pressure in the home is erratic and the water flow is not consistent while a tap is opened, then the temperature of hot water will fluctuate. The minimum water pressure for the home should be 30psi or greater. For people on well systems the minimum pressure range is 30-50psi. The use of a pressure reducing/regulating valve is an effective way to maintain constant water pressure to the water heater. Watts brand 25AUB- ¾" or N35B-¾" pressure reducing/regulating valves or equivalent is suggested.
  3. CHANGING FLOW RATE
    Major changes in flow rate can adversely affect the output water temperature of the heater. Increases from one major fixture running to multiple fixtures running at one time can cause the temperature to fluctuate. Stay within the heater's specifications. See: TWH E2-03 Outlet temperature vs. flow rate [PDF].
From the Bosch website.
Good Luck,
Gary
Dec 16, 2010 | Bosch PowerStar AE125 AE125 Whole House...
I have a 16h Bosh hydropower hot water heater . The unit suddenly has no spark .I have taken off the little generater cap and thouroughly cleaned it and the internal turbine . With no improvement . All...
sounds like the generator has packed up. check water flow and clean any filters on the water line. you will need a service agent to check milli volts on generator and power pack
Dec 15, 2010 | Bosch 1600H-LP Liquid Propane AquaStar...
Whirlpool Energy Smart Water heater - light is solid green then every now and then blink a couple of times then go solid again.What does this mean?
2 flashes = high water temperature (the water heater comes set at 120, and you can set it lower or higher)
3 flashes = sensor failure (temperature sensor similar to a thermostat on regular water heater)
4 flashes = upper element
5 flashes = lower element
Links below are for Whirlpool manuals
http://www.whirlpoolwaterheaters.com/support/Manuals.aspx
http://waterheatertimer.org/pdf/Whirlpool-energy-smart-electric-manual.pdf
The water heater is working right now.
If the elements go out, they are available at any hardware store.
The temperature sensor is easily replaced and can be ordered from Whirlpool.
You might want an extra temperature sensor on-hand so repairs are not delayed.
Link below shows the product in detail.
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
Let the water heater do its job until it fails.
Oct 22, 2010 | Water Heaters
My o69m flashes a 16 and says priority
The 16 error code occurs when the outlet temperature exceeds the set temperature of the unit. Typically this occurs when the unit has developed scale in the heat exchanger. I would initially recommend performing a descale on the unit to remove any scale deposits from the HEX.
Aug 31, 2010 | Noritz 6.9 Gallon Residential Direct Vent...
Bosch & Tankless LP Hot Water Heater  Logo
442 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
