Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Kenmore refregerator lights on/burning even doors are closed
3 years old Kenmore elite french door bottom freezer refrigerator. When I opened the french doors - top door - this morning, I found the inside were warn and noticed specially light bulb area was very hot. After having investigated, I concluded that the internal lights must be "ON" even though the door was closed. There are on/off switch to be pushed in/out with the doors closed/opened, and it seemed this switch did not work ,i.e. even though I pushed both of them manually, the light are still on.
What is the way to fix this problem? Is it easy to fix? Can I fix it by my self?
  • Controlfrk
    Controlfrk May 11, 2010
    Look for the model number plate and provide model number from the plate in order to receive help. The number you have is incomplete.
  • 612 Answers
If I understand correctly, you have the bottom freezer with the two doors that open into the fresh food section. Also you have to open one of the two doors first in order to get into the fresh food section. If i ma correct. The switch on the door you have to open first to get into the fresh food section is bad. This is why it makes not difference if you hold both in. The switch on the second door does something else. You will need to replace the switch that the first. You can test this switch by, take the switch out. They are tricky to get out. Take a putty knife and slide it under one end of the switch, push in while you are prying outward. It should pop out. There should be three wires going to the switch. One of the wires is hot (110 Volts), one goes to the fan inside the fridge and the other goes to the light. (The switch operates like this. When you close the door, it turns the light off and the fan on. When you open the door, it turns the fan off and the light on.) Once you find out which one is hot, connect one of the others to it. If the fan comes on try connecting the hot to the other wire. The light in the fridge should turn off. If so replace the switch. I hope you can understand the way I tried to explain.
Please rate solution
Posted on Sep 05, 2009
Kenmore French door refrigerator will not start up, control panel will not light up, wont come on
Have you tested the outlet? The power cord itself could have a broken or burned wire. Even if boards are bad, there should be lights.
Oct 03, 2014 | Kenmore 2537031321 Stainless Steel 26.7 Cu...
How do I get the open door chime to stop on Kenmore Fridge?
I had this problem also. My problem was that the drainage tube that keeps the refrigerator compartment dry was plugged up with the foil backing used in the freezer compartment. This foil backing is used to line the closed cell foam which insulates the defrost heat fins from coming in contact with the plastic back panel. It took a service call from a local repairman two times to unplug the line. We peeled off the foil lining which was the source of the plug.
This solution stopped the "door open"/"instant freeze" cycle sound. My fridge is about 6 years old.
Hope this helps. Best wishes!
Jul 23, 2014 | Kenmore 22 cu. ft. TRIO French Door Bottom...
How do I take KENMORE ELITE TRIO 596.75533400 out of demo mode?
Try pressing ultra ice and home while the refrigerator door is opened,or ultra ice and the refrigerator pad with the freezer opened. Hold for five seconds. Hope that works.
Jun 12, 2014 | Kenmore 22 cu. ft. TRIO French Door Bottom...
The light is remain lite and the plastic cover is malted.
The switch at the bottom of the door is bad, not turning the light off when the door is closed
Mar 01, 2012 | Kenmore Elite 78722 78729 Bottom Freezer...
Our Kenmore Elite french door bottom freezer, automatic icemaker, no water/ice dispenser on the door - is leaking quite a bit - had to mop up the floor three times today. first time it's happened since...
Check for cracks in the water supply tube from the house plumbing valve to the ice maker. Could also be the valve itself.
Turn off valve for a day to diagnose which.
Oct 21, 2017 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Kenmore/Elite Model 795.7756,7757 Trio: Bottom Freezer Door won't close. The latch or hook at the bottom corner of each side will not hook in.
We have a kenmore elite refrigerator modle number- 795 7756,7757 and it has been making a humming noise very constant now after two weeks, what could it be?
Sep 18, 2010 | Kenmore 77554 / 77543 Bottom Freezer...
Kenmore elite bottom freezer icing up
if it has an ice maker fix or adjust the over flow for the ice try.
Jun 18, 2009 | Zanussi ZEBF250W Bottom Freezer...
Freezer door not sealing
replace the seals and / or have the hinge adjusted
May 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
162 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
