Question about Panasonic CT-36SX12 36" TV
Tv will not turn on
My Panasonic CT-36SX12 Tv will not turn on! I came home one day and tried to turn it on and nothing! I pushed the on button on the set and nothing! What could it be and is it fixable?
  • 6 more comments
  • teedoff1980 Dec 08, 2007
    If I open the TV where would the 6.3a slo-blow fuse be? I would like to check if it before calling the repairman. Is it easy to change? Panasonic CT-36SX12
    I went to Radio Shack to buy my open 6.3 slow-blow 125v fuse and they didn't have it. But they did have a 6.3 slow-blow 250v fuse. Will this fuse work or do I have to look for the 125v fuse?
  • teedoff1980 Dec 09, 2007
    Premtech thank you very much for your troubleshooting information! The fuse was the cause of the problem and you save me from buying another TV. It only cost me $2.85 for a new fuse!! Thanks again for all your help!!!!
  • TomTom7 Dec 14, 2007
    Read this thread and it was my problem too. Solved it quick, TV's working, wife's happy again. Thanks Premtach!
  • gpee10 Jun 08, 2008
    Had the same problem and corrected it with a new fuse just like you sad. Thank you!
    Now my screen looks green with no red tint and the adjustment don't work?
    What can this be?
    Thanks again!
    I had the same problen today and now no red tint after replacing the fuse?
  • gpee10 Jun 09, 2008
    Had the same problem with Panasonic CT-36SL14. Solved it the same way. Thx!!
  • Anonymous Jan 26, 2009
    i have a 27 inch sanyo . it comes on, you can hear the stations, but the screen won't open. it's black with a line running across.
  • 934 Answers
This set has a common problem with th main fuse opening for no other apparent reason... One of the few exceptions to my corner-stone statement that a fuse is never the cause only a symptom..
Don't replace it though with the same type grade, use a 6.3a slo-blow gma type - available at Radio Shack... Try that and if everything works you're back in business.. If not we nee to find a cause...
Bill
Posted on Dec 08, 2007
  • 1 more comment
  • William Rayburn
    William Rayburn Dec 08, 2007
    Follow the electric cord to where it connects to the board. Will be a small glass main fuse near there..
    Bill
  • William Rayburn
    William Rayburn Dec 09, 2007
    That will be just fine!!
  • William Rayburn
    No problem, glad to have helped!!
    Bill
Posted on Mar 25, 2008
I have 36" Panasonic CT-36SX12 TAU series. I had it repaired less than 3 years ago .and the same problem happened again As soon as turned the TV off it wouldn't turn back on .I was told this was the...
I would check the remote control by taking it out of the room first. If that is not the problem, it is likely to be a dry joint in the power supply that is "arcing" and causing this problem.
Re soldering the heavy components on the power supply board may fix it.
WATCH OUT FOR CHARGED UP CAPACITORS - THEY ARE LETHAL WHEN CHARGED!
Oct 16, 2010 | Panasonic CT-36SX12 36" TV
How to unblock v chip in panasonic panasonic CT 27SL15 TV
Push the power button and the action button on the tv set until it shuts itself off and this will reset your tv. You cannot use the remote to reset...must use the actual tv buttons on the television set.
Jun 17, 2009 | Televison & Video
Panasonic CT-32g19j
check The B+ of your tv. If no b+ Check the input AC voltage. If Ac i/p are ok but no B+ Volt maybe your IC in power supply has problem.
Jun 01, 2009 | Panasonic CT-32SL14 32" TV
No Power
all sets must have rated fuse for protection. some units now use what is called a PICO-FUSE.this type of fuse is soldered into the pc board. usually marked with location i.d. F301,F901,F400. etc. these fuses look like resistors or in-line coils. check continuity w/ohm meter. if new fuse blows as soon as you plug in tv, suspect bridge diode ciruit or main filter cap(large ripple filter by main fuse. if new fuse blows when you try to turn on, suspect 130v regulator or high voltage short(horizontal-output, flyback transformer) good luck!
Feb 20, 2009 | Televison & Video
Panasonic television
I had the same problem, however mine was a 32inch. It is a blown fuse. It is not the power cord. What you need to do is find out what fuse voltage you need. Hope this advice helps. I have a panasonic model CT-32SX12C.
Aug 20, 2008 | Panasonic CT-36SX12 36" TV
I used your advice today about replacing the fuse Thank you!
Gonna need a little more info than that - - - I get nearly 3000 emails a day and I'm not sure what page we're on...
Bill
Jun 08, 2008 | Panasonic CT-36SX12 36" TV
TV DOESNT TURN ON ,I SWITCH PLUGS ,I TRIED TO TURN THE TV ON FROM THE TELEVISION ,CAN YOU PLEASE HELP.
Possible blown fuse or worse. If you attempt to change the fuse use the same amps that is in it.
Mar 09, 2008 | Panasonic CT-36SX12 36" TV
Checking the 6.3a slo-blow fuse
if you open your tv , you have to put back the board, there are 2  clips
one on left other in the right that keep the board to the case of tv( you have to disconnect  the cable AC before open the tv)
you can see the fuse easely ( if  i remember good there is only one
fuse about near the switch on /off
Dec 08, 2007 | Panasonic CT-36SX12 36" TV
PANASONIC CT-36SX12 IT FLASHED ON, TURNED OFF, AND NOW DOESN'T WORK AT ALL
If you're lucky, the main fuse just opened up. It takes a 6.3 Amp slow blow type. Otherwise, it could be a defective voltage regulator and related parts in the power supply I would guess.
Feb 11, 2007 | Panasonic CT-36SX12 36" TV
TV Stuck in Demo mode
In the tv and with the set turned on press and hold the ACTION and CHANNEL UP buttons at the same time for more than 5 secons.Let Us know how it goes.
Oct 16, 2006 | Panasonic CT-34WX54 34" TV
Panasonic CT-36SX12 36" TV Logo
1,526 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
