Question about Compaq Computers & Internet
Computer has no ip address after I restored it please help daughter is riving me crazy.
    Scholar:
  • 96 Answers
First thing you want to do, is to make sure all the network cables are plugged into the correct devices such as your router, modem and the computer. if all is running well (everything is blinking with lights) go to your computer, open the control panel, select network connections and open it. Right click on the Local Area Connection and right click on it and select repair. Wait for about 2 mins. After that restart your PC. Try to get on the internet. If you are still not able too, you will need to go to the command prompt, you can do this by selecting start then run, type in 'cmd' and enter. You will see a windows that pops open, it should see somthing like c:\Documents and settings\john> or somthing like this. type in 'ipconfig /all' you will hopfully see a ip address and alot of other information. the ones you will need to look at is to see if your dhcp is enabled if it is then this will give you a auto ip address if it is not, you will need to get a static address from your isp. You will try to see if you can communicate with the IP address by typing in 'ping ' then the ip address. for example 'ping 192.168.1.23' if you have not packets lost, then that is a good thing. then try to ping your gateway, this will be your router ip address. you can find this ip 'Default Gateway' if you are able to ping this, you should be able to go online fine. computer has no ip address - 570081d.tif
If you are still not able to fix this please let me know and i will be more then happy to help. keiffertech@techie.com
Posted on Sep 05, 2009
Someone has changed my IP address hacked into in my router
I am not that much clear whether you can change your Ip adress, but any queries regarding Ip-detais can be solved here, http://www.ip-details.com/
Jul 06, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Tip
Error: 169.x.x.x IP Address
<p><b>Information:</b><br /> <p><span>This article outlines methods of resolving issues with a 169.x.x.x IP address. <span>This address results from a built in feature of windows called automatic private IP address(APIPA). When your computer is unable to find a DHCP server the APIPA service will assign itself a 169.x.x.x IP address. According to Microsoft, the APIPA service checks for a DHCP server every five minutes. </span></span><br /> <p><span><span><b>Workaround:</b></span></span><br /> <p><span><span><b>Releasing the IP address</b></span></span><br /> <p><span><span>1. Click on Start and click Run.<br />2. Inside Run, type ipconfig /release to release the IP address.<br />3. Then after the IP address is released, type ipconfig /renew</span></span><br /> <p><span><span><b>Disabling the Ethernet Adapter</b></span></span><br /> <p><span><span>1. Click on Start and right click on My Computer. Then click on Manage.<br />2. Click on Device Manager and then Network Adapters<br />3. Under Network Adapters, right click on your Ethernet adapter and select Disable. <br />4. Wait approximately 5 seconds and right click on it and click Re-enable. <br />5. This restarts the DHCP client and tries to obtain an IP address from the Network.</span></span><br /> <p><span><span><b>Check the Ethernet cable</b></span></span><br /> <p><span><span>Sometimes a bad Ethernet cable can cause your system to receive a 169 IP address, try changing out the cable for a new one.</span></span><br /> <p><span><span><b>Disable antivirus and firewall applications</b></span></span><br /> <p><span><span>Disable/uninstall any external firewall, antivirus, or spyware programs (eg. Norton Internet Security, McAfee Security Center, Trend Micro 2007, Webroot).</span></span><br /> <p><span><span><b>Restarting the QoS packet scheduler Protocol</b></span></span><br /> <p><span><span>1. Click on Start and click Control Panel.<br />2. In Control Panel, double click on Network Connections and then Local Area Connection.<br />3. Click on Properties and uncheck QoS Packet Scheduler. <br />4. Click Ok and repeat the process. <br /></span></span><br /> <p><span><span><b>Restarting the DHCP service</b></span></span><br /> <p><span><span>1. Click Start and select Run. <br />2. Type services.msc in Run and click Ok.<br />3. Find DHCP service and right click on it. Click on Stop.<br />4. Reboot the computer.<br />5. When the computer boots up, click Start and select Run<br />6. Inside Run, type the following: netsh int ip reset log.txt<br />7. Click Ok.</span></span><br /> <p><span><span><b>System Restore</b></span></span><br /> <p><span><span>1. Open Start and click on Programs and then Accessories.<br />2. Then click on System Tools.<br />3. Click on System Restore and select a restore point when you were not experiencing this problem.<br />4. Restore your system.</span></span>
on Mar 15, 2011 | Computers & Internet
Tip
Resolving 169.x.x.x IP address problems
This article outlines methods of resolving issues with a 169.x.x.x IP address. This address results from a built in feature of windows called automatic private IP address(APIPA). When your computer is unable to find a DHCP server the APIPA service will assign itself a 169.x.x.x IP address. According to Microsoft, the APIPA service checks for a DHCP server every five minutes.
7. Click Ok.
System Restore
on Jun 14, 2010 | Computers & Internet
When I type in the ip address in my browser.....it doesn't open anything. it takes forever then eventually says error. PLEASE HELP!! Trying to find my WPA key so I can connect to XBOX Live. Been trying...
Which IP address are you typing in? The router will have a specific address. Its not your Internet IP address. Go to the Belkin website as the default IP should be th same for all belkin routers.
Jan 06, 2010 | Belkin (F5D8231-4) Wireless Router...
WHAT IS THE IP ADD FOR SATELLITE L25-S119, MODEL PSL2XU-00J00D
go to internet connection, right click on lan and select properties and go to tcp/ip and restore to default (automatic)
Dec 30, 2009 | Toshiba Satellite L25-S119 Notebook
Tip
Resolving 169.x.x.x IP address problems.
Information:
Workaround:
7. Click Ok.
System Restore
on Mar 29, 2010 | Computers & Internet
Every time my daughter uses her laptop, my pc says
Either unplug the router from power source for 10 seconds and plug back in to reset.
Or you may have an ip address on the pc itself that is conflicting with your daughter's ip address. Dynamic ip address are set so they don't interfere with each other. We use 4 different pc's on one router in our home.
You can change the ip address of your computer by going to start menu, then run, then type ipconfig /release, then type ipconfig /renew and it will give you a new one.
Or you can access the software and settings of the router itself by opening up an internet page, go to address bar and type 192.168.1.1 and hit enter.
It should bring you inside your router so you can check and switch any settings.
Nov 17, 2009 | NetGear WGR614 Wireless Router
IP address Problem with Dell Studio 1525
Most probably its the problem with the autonet ip address where the computer picks a bad ip address. If your internet service provider has DHCP enabled you cannot put the manual IP address. If its a new problem try system restore, uninstalling and reinstalling networkdrivers. resetting winsock.(search google)
Mar 30, 2009 | Dell Inspiron 6000 Notebook
Bought ipod touch for my granddaughter for xmas. I think she was in a hurry to set it up and made a mistake either on her email address or password. When she tries to download free games, it asks for...
The iPod is prompting your daughter for her iTunes Store Account details. To create a new account. Open iTunes on your computer, from the menu select "Store" and click "Create Account". You don't need to do anything to the iPod.
Jan 02, 2009 | Apple iPod touch
Please Help! My IP is driving me crazy!
modem only transmits signal.
router talks to your provider and gets IP address from them, depending on your subscription, you may have a static or dynamic IP.
your computer gets internal (home network) IP from the router, you don't have to worry about that since it is the router's IP address that is seen on the internet (router splits / shares a single internet connection in home networks).
about wireless connection from computers/wi-fi gadgets to the router, must configure the router with the ff:
wireless network name (aka SSID)
security type (WPA/WEP) and password/passphrase/security key
channel (1-12)
the above info must be then set to the connecting computers/gadgets
about wired connection: a working ethernet cable (looks like a phone cord but fatter) and a working computer/gadget ethernet port.
Wii will work - check Wii's website for connectivity options / instructions.
Dec 18, 2008 | NetGear WGR614 Router
Computers & Internet Logo
152 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
