Question about Zenith P42W34P 42 in. EDTV-Ready Plasma Television
VERTICAL LINE ON SAMSUNG HLN617W WHEN USING ANALOG INPUTS OK WITH COMPOSITE INPUTS AND COMPUTER
I GET VERTICAL LINES ON SCREEN ABOUT 1 IN. APART WHEN USING THE ANTENA AND S-VIDEO AND RCA INPUTS. WHEN USING THE COMPOSITE AND COMPUTER INPUTS THE PICTURE IS FINE. THE TV IS A SAMSUNG HLN617W. IT WAS SUGESTED TO REPLACE THE DMD BOARD. THE BOARD COST APPROX 900 DOLLARS. IS THERE A PARTICULAR COMPONENT ON THE BOARD WHICH CAN BE REPLACED TO FIX THIS PROBLEM OR MAYBE THERE IS SOMETHING OTHER THAN THE DMD BOARD CAUSING THE PROBLEM? PLEASE HELP!
  • 934 Answers
Nope, nope and nope... It's likely the DMD board and unless you have some SMT (surface mount technology) equipment just laying around you're not repairing that board too easily... You could however remove it and send it in to PTS for rebuild at about half the cost of a new replacement..
Bill
Posted on Dec 08, 2007
Samsung plasma tv has vertical lines
The most cost effective thing to do is just replace the TV. The cost to repair will be close to the cost of a new LED flat screen, they are very cheap now.
Aug 21, 2016 | Samsung PN51F8500 51" Full HD 3D Smart...
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
More results from www.cnet.com
Jan 03, 2016 | Samsung Televison & Video
Why is my samsung hln617w tv all inputs give no signal
main pcb approx $72.00 at
http://www.shopjimmy.com/samsung-bp94-00434a-main-analog-board.htm
however thay are out of stock. Be sure this part # is a match to your complete model# B4 trying to order, this site lists the various models this pt# fits.ALSO considering the age, they may not be able to get anymore of these.I recommend calling to confirm.
As for firmware updates, that info can be found at Samsung web site:
http://www.samsung.com/us/support/contact
under product support. you might also check at the Samsung web site for the Main PCB. expect it to be much higher & please have your complete Model & Serial numbers available when you contact anyone.
Apr 29, 2014 | Samsung HLN617W 61" Rear Projection HDTV
I have a DX-L26-10A that has problem with the A/V inputs. The picture is fuzzy. All the other inputs on the TV have a good picture. Both A/V1 and A/V2 are fuzzy.
AV1 and AV2 are Composite signals. What this means is that the Image signal and the Image color are combined into a single feed... or a composite or signal and color. Other than using CH3 from the cable box, this is the poorest performer in regards to signal quality. Additionally, the signal only has 480 lines of resolution and your TV has 720.
What all this means is that 480 lines of poor image quality are being blown up (think magnified) to fill 720 lines of resolution on the screen. What you end up with is a blurry image when compared to other inputs (ie: HDMI, COMPOSITE). The Dynex TV does not have some of the more advanced video processing of other manufactures. It will perform the image doubling, a bit of filtering, but not much more.
I suspect you TV is fine. A transition to an HD display can be shocking to some. After all, the VCR looked better on the old analog TV (not a joke, it did).
I hope this was helpful, best wishes.
Mar 06, 2011 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
Samsung hl-r7178w has green video and vert. lines on all analog inputs, hdmi input is good and menu screen is good
Hi,sounds like It could be the DMD board.This is how the DMD board works: http://electronics.howstuffworks.com/dlp1.htm Basically when that Dmd chips starts to fail that's what you'll get color discoloration vertical lines, white spots.You will need to replace the dmd only you can find it on ebay,samsung,or shopjimmy.com God bless you!
Oct 05, 2009 | Samsung Televison & Video
I want to connect an external DVD player (Samsung DVD-1080P9) to my Sony DAV-S500 system
yes u can connect an externel dvd player to your sony dav s 500...
you have
composite video input X 1 and
analog input X 1.
so you can connect the RC output pins of externel dvd player to the input of composite video and analog left and right audio inputs to the SONY DAV S500.
ANY QUIERIES MAIL TO ME
kanny_amancha@yahoo.com
kanny-sounds.blogspot.com
Jul 11, 2009 | Sony DAV-S500 System
Digital or not????
You can get the owner's manual at;
http://www.bottomlinelcds.com/manuals/PLTV-32CM-owners-manual.pdf
You need a converter box.
Specifications
General
Dimensions
33.07"W × 25.83"H × 9.09"D
Weight 45.54lbs
Panel Type Active Matrix TFT LCD
Screen Size 32" widescreen (16:9)
Color Range 24 bits (16.7 million colors)
Max. Resolution 1366 × 768
Pixel Pitch 0.51075mm (H) × 0.51075mm (V)
Sync Range Horizontal: 30–80kHz
Vertical: 50–85Hz
Contrast Ratio 800:1
Brightness 500 cd/m2
Viewing Angle Vertical: +/–85°
Horizontal: +/–85°
Response Time 16ms typical
Inputs 2 × progressive scan component video (RCA)
3 × composite video (RCA)
1 × S-Video
6 × stereo audio (RCA)
1 × SVGA (15-pin D-Sub)
1 × stereo audio line in, 0 dBV nominal (1/8" TRS)
Outputs 1 x composite video (RCA)
1 × stereo audio (RCA)
1 × subwoofer (RCA)
1 × headphone (1/8" TRS)
Video Formats Supported SDTV: 480i
EDTV: 480p
HDTV: 720p, 1080i
TV Tuner NTSC-M, CATV, 181 channels
TV Audio Mono, Stereo, SAP
Parental Controls V-Chip (TV PG, MPAA)
Picture-In-Picture PIP, PBP
Closed Captioning CC1–4, TEXT1–4
Speakers 2 × 10W
Plug and Play Compliance VESA DDC1, DDC2B
Power Supply 100–240VAC, 50–60Hz
Power Consumption Operation: 232W
Standby: <3W
Storage Temperature 0 to 60°C
Operating Temperature 5 to 35°C
Apr 08, 2009 | Protron PLTV-32 Television
Green Plaid then Vertical Lines, Failure of hard controls, Analog Board?
You are absolutely correct, When anyone complains of vertical lines or bars, the next step is to see if it happens on only digital inputs ( digital board ) , only analog inputs ( analog board ) , or both ( DMD board ) .
Analog board can be purchased at www.partstore.com ,
Jun 04, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung WS32Z429T
This looks like it could be a problem with leakage of the 60Hz vertical scan frequency into the picture this is also called 60Hz hum. What usually causes this is poor filtering on the power supply or decoupling capcitors in the vertical section have begun to malfunction. This problem is easy to fix if you have the equipment to isolate the problem, I would suggest that you take this set to a TV repair shop to have it analyzed and repaired.
Sep 22, 2007 | Samsung WS32Z308P 32" TV
Zenith P42W34P 42 in. EDTV-Ready Plasma Television Logo
110 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
