Now my tri color refill also prompt cartridge problem..argghhhh...a lot of things nd to print
I just refilled the black cartridge, I left the color-cartridge inside (if I don't it complains that there is no cartridge or one, that is not compatible. It won't print as long as there isn't any...
your problem is with your cartridges.. there are canon printers which can operate with only the colored cartridge is installed. in your case, the black cartridge is the one that i suspect that has a problem.. try to replace your black cartridge. Hope to be of help.
Oct 17, 2013 | Canon PIXMA iP1600 Printer
My colors are not printing right....things are
which means the cartridge do not have the equal amount of colors in it . refilling the cartridge will solve your problem .
Jul 04, 2010 | Brother MFC-290C Printer
I have a Lexmark X4650 I refilled the cartridge and now I cannot get the printer to recognize the cartridge it prints black only and tells me Color is low . any suggestions on how to bypass this prob get...
I own a Cartridge World ink refilling store and I can't refill the Lexmark 36 and 37 cartridges. Your printer deactivates the electronics on this cartridge when the ink levels get low. Your printer needs a black and a color cartridge with functioning electronics to print. I NEVER recommend Lexmark printers. They are poorly made, don't accept refills easily, and have the most expensive ink across manufacturers and it is designed to clog your cartridge unless you use it quickly. If you keep this machine you are stuck buying Lexmark brand ink (the return program cartridges are a little cheaper though).
Dec 24, 2009 | Lexmark X4650 InkJet Printer
Ink cartridge refill
You can't refill these cartridges yourself. Sure you can get ink and inject it in, but your printer remembers the serial number of each cartridge and how many pages you've printed with it. Because it remembers this information it turns off the cartridge electronics to prevent the use of refills. I would try to get refills for the black but not the color cartridge. I own a Cartridge World ink refilling store and we have a high return rate on the color cartridges. It seems the printers are extremely finicky about color refills. If you get a black refill and your printer won't print with it, exchange it for another one because you happened to get a cartridge with the same serial number as the last one you had. I recommend Cartridge World refills, then Office Depot brand refills.
Nov 19, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Ip1600 refilled Canon color catridge not recognized
I have not had good luck with refills, or off brand ink. The factory stuff does not give you this grief. The Canon is a good unit, give it the good stuff. Do not use 'clean cartrige' too much or you will get the waste tray full, and that's the end of your machine.
Apr 25, 2009 | Canon PIXMA iP1600 Printer
The yellow light blinks and it won't print
I also started having problems with my HP 870Cse when I began using refilled cartridges and had ink leakage (cartridge contacts corrupted). Check for this problem. If so, remove cartridges and gently clean the spillage. Then try using HP brand cartridges and see if this doesn't remedy the problem.
Jan 21, 2009 | HP Deskjet 870cse Printer
I think my ink cartridges need re-filled or replaced. Are they refillable?
Yes they are refillable. All you need to do is buy some refilling kit and an ink bottle that is compatible with your printer.
Dec 18, 2008 | HP Photosmart C4280 Aio Printer
Colors won't print
hi,i think the problem of ur printer cartridges i is'nt refill....u try to refill it....or clean up ur cartridges.
Aug 19, 2008 | Epson Stylus CX3810 All-In-One InkJet...
Color cartridge wont print
The color cartridge is defective. Sometimes, when the printer detects a refilled cartridge, it "marks" the cartridge as defective hence the refilled cartridge will not work on any printer.
Jul 21, 2008 | HP PSC 750 All-In-One InkJet Printer
Printer will not start on time
Upon a prompt from the printer, I removed the color cartridge which had run out of ink. Strangely enough, this solved the problem. I can now print anything in black and I will have the color cartridge replaced or refilled.
Leslie lupien
Apr 06, 2008 | HP PhotoSmart 7760 InkJet Printer
21 people viewed this question
k24674
jasbo
jasbo
