Question about GE Profile JTP18 Electric Single Oven
Can I clean an GE Profile TruTemp oven with soap and Water without ruining it?
  • 612 Answers
Yes, soap and water is fine. You can use any mild soap. Just do not clean with oven cleaner.
Please rate solution
Posted on Sep 05, 2009
White residue left after using self cleaning feature - I can't remove it with soap and water and elbow grease. What would work? This looks awful!!!
The residue your seeing is the remains of whatever was left in the oven when you decided to creamate in. Grease, food, etc was basically turned to has and then powder coated into the metal. Bit of advice for the future though, avoid using self clean mode not only for the scenario you have, but for your bank account as well. The temperatures the oven reaches in self clean exceed that of which the oven cavity can handle letting heat pass upward, usually damaging the lock mechanism for sure, as well as the control board and touchpad.
Apr 23, 2012 | GE Profile JT952 Electric Double Oven
I have a glass top stove that tenants NEVER cleaned. The two front burners are black. I have tried CeramaBryte Whink Cooktop, Baking soda, Scotchbrite type scrubbing pads, razor blades, and mixing all of...
If you have tried all of the above.... BEFORE you go to the acid attemp that I do not think is a good idea.... Go to the local auto parts store and buy some engine degreser. Then give that a try. It is amazing how when you encounter a mega mess stove / oven that it will do the job most of the time. You will just have to use soap and water to do the final cleaning.
Feb 14, 2010 | GE Profile JTP18 Electric Single Oven
After self-clean cycle oven door won't unlock
your lach might have given out on self clean. change it
Feb 12, 2010 | GE Profile JTP18 Electric Single Oven
If I DO NOT want to use the self cleaning feature is there any other safe way, including using soap and water, to clean the oven without ruining it? (I don't want to use the self cleaning feature)
  1. Oven door : Wash the door and window with soap and water and rinse with clear water. Use glass cleaner only if sprayed on a cloth first. Do not use abrasive pads, powdered cleaners, or steel wool on glass and enamel, or the surfaces will be scratched.
  2. surface burner : To absorb a spill when it is hot, pour salt on it and wipe it up when the oven has cooled. A mildly abrasive baking soda and water paste can be used in the oven, too.
  3. Racks:Remove oven racks and clean them in warm, soapy water. Stubborn messes can be cleaned by using mild abrasive cleansers or a soap filled scouring pad. Rinse and dry the racks before returning them to the oven.
  4. Metal trim:Metal trim can be cleaned with glass cleaners or mild cleansers, soap and water. Abrasives or cleaners made for oven interiors should not be used.
Thanks
Smith.
Sep 05, 2009 | GE Profile JTP18 Electric Single Oven
Can I clean a TruTemp oven with soap and water without ruining it?
Yes you could clean it.
Check few details :-
t the bottom of this post you will find the web address for your ranges manual and the self clean system is in side this manual.
How to self clean
If your model has a door latch, never force the latch handle. Forcing the handle will damage the door lock mechanism.
The oven door must be closed and all controls set correctly for the cycle to work properly.
Before a Clean Cycle
For the first self-clean cycle, we recommend
venting your kitchen with an open window
or using a ventilation fan or hood.
Remove any broiler pan, broiler grid, all
cookware, probe and any aluminum foil
from the oven—they cannot withstand the
high cleaning temperatures.
NOTE:
If your oven is equipped with nickel oven
shelves, remove them before you begin
the self-clean cycle.
If your oven is equipped with gray
porcelain-coated oven shelves, they may
be left in the oven during the self-clean
cycle.
Soil on the front frame of the range and
outside the gasket on the door will need to
be cleaned by hand. Clean these areas with
hot water, soap-filled scouring pads or
cleansers such as Soft Scrub®. Rinse well
with clean water and dry.
Do not clean the gasket. The fiberglass
material of the oven door gasket cannot
withstand abrasion. It is essential for the
gasket to remain intact. If you notice it
becoming worn or frayed, replace it.
Wipe up any heavy spillovers on the oven
bottom.
Make sure the oven light bulb cover is in
place and the oven light is off.
IMPORTANT: The health of some birds
is extremely sensitive to the fumes given
off during the self-cleaning cycle of any
range. Move birds to another well ventilated
room.
NOTE: Use caution when opening the upper
oven after the self-clean cycle has ended.
The oven may still be hot.
How to Set the Upper Oven for Cleaning
On models with Gas/Control Lockout,
touch and hold the Gas/Control Lockout
pad for 3 seconds to turn it off.
NOTE: The surface burners must be turned
off prior to the self-clean start time.
If your model has a latch, latch the door.
Touch the Self Clean pad.
Using the number pads, enter the
desired clean time, if a time other than
4 hours is needed.
Clean cycle time is normally 4 hours. You can
change the clean time to any time between
3 hours and 5 hours, depending on how dirty
your oven is.
Touch the Start pad.
On models without a door latch, the door
locks automatically. The display will show
the clean time remaining. It will not be
possible to open the oven door until the
temperature drops below the lock
temperature and the LOCKED DOOR
light goes off.
The oven shuts off automatically when the
clean cycle is complete.
When the LOCKED DOOR light is off,
slide the latch handle to the left as far
as it will go and open the door. If your
range does not have a latch, the door
will unlock automatically.
The words LOCK DOOR will flash and
the oven control will signal if you set
the clean cycle and forget to close the
oven door or forget to latch the door
on models with a latch.
To stop a clean cycle, touch the Clear/Off
pad. When the LOCKED DOOR light goes
off, indicating the oven has cooled below
the locking temperature, unlatch the door
(on models with a latch) and open the door
How to Delay the Start of Cleaning
Make sure the clock shows the correct time
of day.
the door.
desired clean time.
Touch the Delay Start pad. The earliest
start time you can set will appear in the
display.
Using the number pads, enter the time
of day you want the clean cycle
to start.
locks automatically. The display will show the
start time. It will not be possible to open the
oven door until the temperature drops below
the lock temperature and the LOCKED DOOR
light goes off.
The words LOCK DOOR will flash and the
oven control will signal if you set the clean
cycle and forget to close the oven door or
forget to latch the door on models with
a latch.
pad
(on models with a latch) and open the door.
After a Clean Cycle
You may notice some white ash in the oven.
Wipe it up with a damp cloth after the
oven cools.
If white spots remain, remove them with a
soap-filled scouring pad and rinse thoroughly
with a vinegar and water mixture.
These deposits are usually a salt residue
that cannot be removed by the clean cycle.
If the oven is not clean after one clean cycle,
repeat the cycle.
You cannot set the oven for cooking until
the oven is cool enough for the door to
unlock.
While the oven is self-cleaning, you can
touch the Clock pad to display the time
of day. To return to the clean countdown,
touch the Cooking Time pad.
If the shelves become hard to slide, apply a
small amount of vegetable oil or cooking oil
to a paper towel and wipe the edges of the
oven shelves with the paper towel.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
I have a GE JTP18 Trutemp. It seems to be taking
sounds like a stuck relay on the control board ... can you tell if the bake or broil element is glowing during this time?
Jul 19, 2009 | GE Profile JTP18 Electric Single Oven
F7 E6 won't go away on my Ge Trutemp oven
Call GE answer center 1-800-626-2000 ask for tech help.
Have Model # off your data plate ready.
May 09, 2009 | GE JKS05 Electric Single Oven
Oven does not heat. Broiler and stove work. NO gas smell.
could be the oven thermostat, get a plumber/heating engineer out, but make sure you can trust him, cause he could try and say u need a new cooker when it MIGHT only be a new oven thermostat.
Feb 02, 2009 | GE Ovens
GE Profile Advantium oven (stainless steel)
spray a little oven cleaner on a wet rag and wipe. Rinse really well afterwards. Do not spray directly in oven. It could get in the holes.
Jun 10, 2008 | GE Profile Advantium SCB2001KSS Stainless...
GE Profile JTP18 Electric Single Oven Logo
78 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
