Question about Kenmore Heating & Cooling
I was shooting arrows and hit the air conditiner by accident, gass was leaking out for a few mins and it stoped. i was wondering if this going to harm me or my family without it being treated. i hit this kinda coil thing. i found out the gas is freon and oil. will it cause perminate lung damage? i didnt breaTH that much of it, is it really nessecary for it to be treated?
  • 612 Answers
It is harmless, I repair A/C's all day and have for 30 years. You and your family will be just fine. Although it will hurt your wallet. Costly target. If the coil is copper it's not to bad but if it is aluminum inside, you will have to replace the whole condenser. Not sure about your area but around here. You can figure around $1500.00 per ton. (BTU)
Please rate solution
Posted on Sep 05, 2009
Why is it failing?
open gas cap and see if it will run again. m,any times the gas tank vents clog and the engine can't draw gas after a few minutes.
another thought is the oil mixture.. 50:1 with oil made for air cooled engines....not boat engine oil
Apr 02, 2014 | Husqvarna 150BT 50CC Gas Leaf Backpack...
Coolant leaking out of temperature coolant sensor
You have to bleed it.there is air trapped. What i did is opened up the peekock .and filled the radiator up until water stoped spuing out.
Dec 04, 2017 | 2006 Ford Explorer
Accidently hit wrong language. How can I correct this?
Do this whilst it is disconnect from a PC
Whilst it shows a map display touch the screen once.
Select the icon that looks like a spanner / wrench
Use the rght arrow on the display until you see a bunch of flags. (if you shoot past it just keep going until it comes ound again)
Touch that and select the correct the correct flag / language.
Nov 18, 2009 | Tomtom One XL GPS Receiver
The lower oven door locked shut. Accidently pushed wrong button & lower oven locked and I can not get it to open.
stop pushing all the buttons. Turn the power off for a few min. It should un lock when power is back. If not set clock, set oven into clean cycle, wate a few min then hit cancle. wate till door unlocks. If nothing happens make sure you dident hit the child lock button. It looks like a pad lock on touch pannel. push and hold it to unlock. Re try clean cycle. let it lock then wate ,then cancle .
Nov 03, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Um hi i was shooting arrows and i hit the air conditioner by accident and gass was starting to come out then after a few miniutes it stoped. i found it i hit some kinda coil and freon and oil came out i...
one question at a time
Is it harmfull?
If inhaled Yes. habe you helped destroy the environement YES!
Definitely bad for the lungs.
Probably not premanent, depend on hpow much you inhaled.
Is repairimg nesseceary?
How else will it ever work if its not repaired
Sep 05, 2009 | Heating & Cooling
I have a window unit and ?water keeps leaking in. I do i prevent this
You need to tilt the air conditiner back, so water will run to back of unit and drain outside or to be used by condenser fan, if, it has a slinger on it.
Jul 29, 2009 | Heating & Cooling
Front air bag did not deploy on 1992 Buick Park Avenue
front air bags only go off when hit in front endthey go off at 15 miles a hour
Mar 11, 2009 | 1992 Buick Park Avenue
Fridge is cold but always runs.
CHECK THE DOOR GASKETS ON THE FREEZER AND FRIG.,IT SOUNDS LIKE THERE IS A AIR LEAK SOMEWHERE,LET ME KNOW-MIKE
Nov 01, 2008 | Refrigerators
Magicolor 2300 language
hit menu, press the side arrow ( either side) it will cycle through the languages , when it comes to english... might read like Angalish.. leave it . hit select and your done , wait a few min before hitting menu again.
Sep 18, 2008 | Konica Minolta magicolor 2300DL Laser...
Heating & Cooling Logo
27 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
