Question about HP Pavilion dv6000z Notebook
Laptop monitor problem
Laptop monitor will not display. Computer is running. I can see the LEDs and can hear the fan and hard drive. Tried viewing the display with an external monitor but could not get a display by pressing fn f4 keys. Any suggestions?
  • 928 Answers
Try a system restore to a time that you it worked. Actually it sounds like a video card problem.
Posted on Sep 05, 2009
When we turned on the laptop only black screen is coming nothing is displaying
Hi Pavan,
If the LEDs glow to indicate that power is available, the sound of a fan or spinning hard drive can be heard, but no colors, images, or text are displayed on the LCD display.
The cause of this problem may be the failure of a hardware component, or an error in the instruction being sent from the BIOS to a hardware component.
DO THIS FIRST - Perform a hard reset
If a PC suddenly fails to boot properly, you should perform a hard reset as the first procedure.
1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds .
3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
Actions to take after performing hard reset
If no error message is displayed:
1. Connect an external monitor
2. Test for memory module problems
3. Test the hard drive
G'Luck.
May 02, 2014 | Compaq Presario Notebook
Hp pavilion black video
This is a RAM problem. It can happen when you open your computer and tamper with it or just mishandling such as dropping laptop
May 26, 2012 | HP Pavilion Computers & Internet
No disiplay on the screen of the laptop and on the external monitor
No display on either? Does it sound like the computer completed the boot cycle? Do you hear fans running and the hard drive spinning?
What happens when you hit the power button? Do you hear any beeps or see any blinking lights? Does anything post to the screen during the boot cycle?
If the boot cycle completed and you see no display on either monitor, then your video card is bad.
Apr 09, 2012 | Acer Extensa 5630-6806 Notebook
Acer laptop no disiplay
What will i do to my hp mini notebook it has a power but it cannot booth
Perform a Hard Reset Do these actions first to clear all temporary setting before troubleshooting the problem.Disconnect all peripheral devices and remove all USB devices and media cards.Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain residual charge.Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.Perform each recommended corrective action and then attempt to restart the computer.Symptom 1: LED lights do not glow, display is black, no fan or drive sounds are heard, and computer does not startIf LEDs do not glow or blink when AC power adapter is attached and power button is pressed, there is no power available to the notebook Check AC adapter wiring and power connection to the notebook Connect a different AC power adapter and remove battery, then restart notebook.Connect a different battery and disconnect AC power adapter, then restart notebook Symptom 2: LEDs blink or computer beeps but does not start Blinking LEDs or beep tones indicate a hardware failure during the pre-start up testing Count number of blinking LEDs or beeping tones to help with diagnostics testing Symptom 3: LEDs glow, fan noise may be heard briefly, display remains black, and computer fails to startup or boot Usually occurs if a component is installed incorrectly, or there is a device conflict or failure Connect an external monitor to check if the problem is the built-in LCD display or graphics card Remove all CD/DVDs, SD cards, USB devices, peripherals and do a Hard Reset If memory or hard drive components were replaced, reinstall original component Remove memory modules and replace one-at-a-time Remove and reseat hard drive If possible, turn on power, press F10 to enter BIOS mode, and run Memory Test and Hard Drive Test On newer notebooks, turn on power, press Esc to enter UEFI mode, and run Memory Test and Hard Drive Test If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Repair Computer option, or enter Safe Mode and run Memory Diagnostics If all other methods fail , but computer can boot to BIOS, use recovery disk to recover the computer to original condition Symptom 4: Computer may display an error message on a black screen during startup or boot Search www.microsoft.com for terms in error message Search www.hp.com for terms in error message
  • If possible, turn on power, press F10 to enter BIOS mode, do the corrective actions listed under Symptom 3 to run memory and hard drive tests.
  • Symptom 5: Computer displays a blue screen or continually re-starts After an error message is displayed, you can usually bypass the error and continue to run the notebook in Safe mode to install an updated BIOS or driver.
    • Search www.microsoft.com for terms in error message.
    • Search www.hp.com for terms in error message.
    • If possible, turn on power, press F10 to enter BIOS mode, and run diagnostic Memory test and Hard Drive test .
    • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and do one or more of the following:
      • Select Disable automatic restart on system failure to view error message.
      • Run Repair Your Computer .
      • Run Last Known Good Configuration .
      • Select Boot into Safe Mode and then select Run a Microsoft system restore .
      • Select Boot into Safe Mode and then select Uninstall recently installed programs .
      • Select Boot into Safe Mode and then run Windows Update .
    Symptom 6: Computer displays the Windows logo screen and stops responding If no error message displays, turn on power, press F8 to enter Windows Advanced boot options ,and select Disable auto-restart to view error message.
    • If possible, turn on power, press F10 to enter BIOS mode, and select Restore the BIOS defaults (F9) .
    • If possible, turn on power, press F10 to enter BIOS mode, and run Hard Drive Test .
    • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Last Known Good Configuration (Advanced) . .
    • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Boot into Safe Mode and then Uninstall recently installed programs .
    Update Computer After Resolving A Problem When the computer starts into Windows normally, you should install the latest updates and patches to prevent other start-up problems.
    Oct 09, 2011 | HP Mini 1000 Netbook
    I have a HP pavilon ze 5000 laptop and ther is no display on monitor. The leds' on front light up but cap lock and others do not. I have tryed anexternal monitor and nothing. I here the fans running...
    Sorry to say something in the laptop has died or is faulty.
    It may be the memory. Check in the place where the memory is installed and make sure it still clipped right in place.
    Does the computer give a single beep when it is started? That is important as if it does not then the motherboard is not 'posting' and is likely damaged some way.
    Jun 20, 2010 | HP Compaq Presario 2500 HP Pavilion ZE...
    ACER ASPIRE 3690-2940
    check the display on the external monitor by connecting it through the vga port of the laptop, check whether the display is coming or not, if coming then its the problem of your screen
    Oct 14, 2008 | Acer Aspire 5100-5022 Notebook
    PROBLEM WITH MY SATELLITE M35X-S111
    Check to see if your Display is bad or Video is bad..
    To Do This....
    Plug an External Monitor into the laptop serial port..Boot the laptop and use the function key plus F5 to boot to external screen... If you see your PC running on the external screen it is a Video card/chip problem.....
    Do your lights run ..the Power Light/Battery light/ hard drive light??? Do you hear the hard drive spinning??
    May 19, 2008 | Toshiba Satellite M35X-S111 Notebook
    Inspiron 1100 monitor
    Any of the system LEDs come on when you turn it on? Can you hear the hard drive spin up? What was the original problem that lead you to clean the laptop fan? Please post the answers and any other pertinent information and we?ll start up.
    Mar 07, 2007 | Dell Inspiron 1100 Notebook
    HP Pavilion dv6000z Notebook Logo
    Top HP Computers & Internet Experts
    Tony
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
