Question about Optoma Projector Lamp for EP771, TX771, DX607
DX607. Connect Power cord. Turn on switch. Wait while self diagnostics completes. Green Power light on constant. Amber Lamp light on constant. Press Power button on unit or on remote. Watch projection on wall as it boots up. Finishes boot up fine. No errors. Now Power light and lamp indicators sequentially light, then go off. Cycle repeats forever. Is there a way to reset the unit to factory defaults? Also menu button cannot bring up a screen. Probably because indicator lamp is not on solid.
  • 2 more comments
  • tpaterik Sep 05, 2009
    It looks like there is a filter on the same end as the door access to the lamp.
    I cannot see how to access it. I do know that when the lamp shuts off the fans stay running. I can hear them and feel the air blowing.
    I have opened up the case. I have blown out the internals with compressed air. I found no filters.
    I will reassmble tomorrow.
    OK.
    I blew it out with compressed air. Let it cool over night.
    Powered it back on.
    Ballast UART error. Green flashes 5 times followed by Amber flashing 3 times.
    Where is the ballast? Is it a replacable plug in module, or is it soldered in?
    Is there a reair manual for this? I searched the Internet last night and found nothing.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. This error comes when either the projector is overheating due to cooling fan not working or due to uncleaned filters. And, in worst it can be an old lamp, which can cause this issue. Please clean the filters and also blow off any dirt using canned air. After this is done try unplugging the unit from power socket and then check after an hour or so. Also check if the cooling fans are working and vents are not blocked.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 05, 2009
  • Rylee Smith
    Rylee Smith Sep 05, 2009
    Hi
    Please check the no. of times the power LED and ready LED are flashing
    ERROR CODE MESSAGE POWER LED/FLASHES READY LED/FLASHES
    Lamp usage task created error 2 1
    Environment usage task created error 2 2
    Thermal break status error 3 0
    T1 temperature over temperature 3 1
    T1 sensor status fail 4 1
    Lamp lit error 5 1
    Ballast SCI error 5 2
    Ballast UART error 5 3
  • Rylee Smith
    Unfortunately I was unable to find service manual in my database however, the only solution now will be replacing the lamp as that is the only issue.
    Thanks
    Rylee
Amber light on then a while turns green but wont boot
1) Switch the system on. Can you tell me if the power button is flashing amber or a solid amber? Please also tell me if you notice any diagnostics LEDs staying lit - these are labelled 1,2,3 and 4 and are near the front headphone sockets
2) Please remove all peripherals at the back of the system and switch the system on. Does this affect the power button LED or diagnostic LEDs
3) Have you added any components to the system e.g. video cards, sound cards etc...
4) Please open the system and remove the following components:
a) Power and data cables from hard drives and optical drivesb) Any PCI/PCI-Express expansion cardsc) All memory from the systemd) The system fan
5) With the above removed, please reconnect the power cord to the back of the system and switch the system on. Please make a note of what happens with the power button LED and the diagnostic LEDs
6) If there are no changes to the power button LED or diagnostic LEDs, please remove the power cord from the back of the system and remove the following components:
a) I/O panel cableb) CMOS battery
7) With the I/O panel cable and CMOS battery removed, please connect the power cord to the back of the system. The system should automatically try to switch on. Do you hear any beeps from the system? If so, can you tell us exactly what you hear?
If you need any assistance with removing these components, please see the User Manual here: http://support.euro.dell.com/support/edocs/systems/op380/en/index.htm
Please keep us updated on how you get on!
May 21, 2014 | Dell OptiPlex 380 MT Desktop Computer...
Dell 2300mp
Replacing the lamp module requires special considerations:
  1. Turn off the projector.
  2. Wait 30 minutes for the projector to cool down and then unplug it.
  3. On the bottom of the projector, loosen the two screws on the lamp cover and then remove the cover.
  4. Loosen the two screws on the lamp module and pull out the module.
  5. Insert the new lamp module and tighten the two screws.
  6. Install the cover and tighten the two screws.
  7. Turn on the projector. If the lamp does not turn on after the warm-up period, try reinstalling the lamp again.
  8. Press enter on the projector or on the remote control to open the on-screen menu.
  9. Press the up (c00589410.gif ) or down (c00589411.gif ) arrow to select Setup and then press the right (c00589412.gif ) arrow.
  10. Press the up (c00589410.gif ) or down (c00589411.gif ) arrow to select Reset lamp hours and then press enter .
Jun 18, 2008 | Dell 2300MP Multimedia Projector
The projector turns on but won't project any light through the lens.
If this is a NEC VT series projector, Change the lamp. When if it continues to blink amber and not project and image after installing a new lamp check the lamp cover to see if the micro switch tab on the lamp cover broke off. Some models have a built in lens cover. If the cover is not slid over to open completely the light may not turn on.
May 19, 2014 | NEC VT800 LCD Projector
When I power on the desktop the power button LED turns to steady amber and the fans race constantly at high speed. The system does not seem to complete POST or boot into the O/S. I changed the CMOS Battery...
Can you check at the back of the computer to see what the diagnostic lights are indicating 4 led's (eg yygg - yellow yellow green green) - post the result and i may be able to provide a soltuion
Sep 24, 2013 | Intel K83v0 Dell Motherboard Inspiron 560...
Tv shutdown
check your lamp door interlock switch.
Jul 31, 2010 | Mitsubishi WD-65733 65" HDTV
When I start the Dell Dimension 4600, it says "Enter password." But when I type the password, the cursor won't move, and no asterisks appear for each character of the password. After repeated attempts, the...
First thing I would do is to reset your CMOS by:
1) Power down.
2) Remove power cord.
3) Push power button in and hold for 15 seconds.
4) Open the case.
5) ground you self to the case for a second. (touch bare metal)
6) Remove the battery for 30 seconds.
7) Replace battery.
8) Double check all your connections and cards if any.
9) Close the case.
10) Connect power and power up.
Your diagnostic lights indicate "Other Failure". (The one on the right is amber, correct?) That could be anything. Here is a reference for your diagnostic lights:
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/adtshoot.htm#1112886
Try resetting the CMOS first and comment back.
BTW, this will remove your password too, so you will have to go into the BIOS and reset. You will probably get a "Configuration change" message when you first boot up. Press F1 to go in and then do a Save & Exit.
Thanks for using Fixya.
Dec 12, 2009 | Dell Dimension 4600 PC Desktop
I have an IP3000 printer and each time it is turned on it goes into error mode (the on light blinks amber 5 times then turns green for about 1 second then it flashes amber again
I. Make sure the printer is off but is plugged in
II. Hold down [RESUME] (Triangle pointed down) and hold down [POWER]
and wait 5 seconds or so.
Release [RESUME] but Continue to hold [POWER]. Double click [RESUME].
then Release [POWER].
Press [RESUME], than [POWER]. This should cause the printer to print a
simple diagnostic that'll list it's ROM number and list CDR SENSOR=OK
in red for the last line.
Press [RESUME] twice then [POWER]] to print off the second diagnostic.
Press [POWER] by it self to exit service mode and return to being a
printer.
Nov 02, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Turning of oil service light on OBD II
My recommendation is definitely in the certified sevis because if you make a wrong conection wires can spoil the main computer
Jun 25, 2008 | 1996 BMW 318
Black screen on start up
yep
unplug the system
open the case
look for a battery and take it out
take out the memory (rams)
wait ten minutes
press power button 5 times
put everything back in
and boot it
Jan 12, 2008 | Dell OptiPlex GX270 PC Desktop
Optoma  Projector Lamp for EP771, TX771, DX607 Logo
229 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
