Question about Nakamichi Car Audio & Video
Need to know box size for nakamichi sp-80 for sealed or vented enclosure
    Scholar:
  • 136 Answers
Http://www.ajdesigner.com/speaker/ajvented.php
Posted on Sep 05, 2009
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 45 Answers
The following designs will assume you are using two drivers.need to know box size for nakamichi sp-80 for - 1d474796-6892-4dd6-9421-b94435ec4658.jpg
Here are links to my online repository where all response graphs are included as well as build sheets.
Here's a link to one of the designs including response graphs.
Here's the link to the other design with full graphs and build sheet.
Posted on Nov 20, 2013
What is the best enclosure for the diamond audio tdx12d2 subwoofer
Personally for a sealed box i would go with at least 1.2 cubic feet inside volume.
A 19" x 14" x 17" box will give you a volume of 1.6 cubic feet (most common).
You can do the math by H x W x D then divide that # by 1728 (for 12" speaker) to get your enclosure volume (cubic feet).
The best enclosure depends on what your looking for in bass response.
Jul 05, 2014 | Diamond Audio TDX-12D2 Car Subwoofer
What r the parametric specs for the ma audio hk15x2
Fo (Hz) : 29.581 QMS : 3.965 QES : .517 QTS : .457
VAS (liters) : 147.723 REVC (Parallel-Ohms) 1 SPL @ 1 watt/ 1 meter (dB) : 90.6 X-Max Linear peak-peak (mm) 70 LEVC @ 1kHz (mH) : 1.043 Enclosure Volume (Sealed) : minimum 2 cubic feet Fill Required % : 0 3dB down point (-3dB) : 43 maximum sealed: 2.5 cubic feet n fill required: 39 at 3 dB down point Enclosure Volume Ported Vented (cubic feet) : 5.0 Vented to Hz: 35 3dB down point (-3dB Hz) : 28 Square port area Sq/In : 80 Port Length : 13" Power Handling : 2000 Watt RMS & 4000 Watt Max. Make sure to use MDF for the enclosure and use 1 inch thickness and use braces as well. This is a beast of a sub woofer. So give it the proper power it needs and make sure that your box is very solid in construction. If installed correctly and given the right power, this sub woofer is bound to put a smile on your face and rattle your bones. I hit 142dB with only one of these subs and im sure if i gave it more power i could hit the 150dB range. DON'T FORGET TO GIVE IT THE POWER IT DESERVES. Have fun dreamsystems.
Feb 16, 2011 | MA Audio HK15X2 Car Subwoofer
What size should i make the enlcloser
If looking for LOUD, ported enclosure is the way to go.
If looking for accuracy, build sealed. You will need approx 2 cu ft
To tune this 2 cuft box around 50Hz, you need (1) 4" round port 5" long.
MTX recommends an enclosure of 2cuFt ea. You will only be able to use 1 subwoofer in this application.
Even a sealed enclosure is recommended 1.25cuFt.
You can shove 2 in the vented enclosure, but you may not be happy with the outcome
Dec 02, 2010 | Jensen XS-1010 Car Subwoofer
Hi i have a 15"w3-d4 jl audio sub,can anyone tell me what size antype box i should use ie sealed or ported and the box dimensions
I've had a look at the JLaudio website and they recommend 2 box designs, a ported and a sealed.
The sealed box needs a volume of:
2.125 ft3 or 60.2 litres.
To get this you would need to build the box to these dimensions:
22" x 16" x 14.75" or 559mm x 406mm x 375mm
The ported box needs a volume of:
3.50 ft3 or 99.1 litres.
24" x 19" x 18" or 610mm x 483mm x 457mm.
The port needs to be:
3.0" x 10.9" or 76mm x 277mm.
The enclosure recommendations listed above are external dimensions which assume the use of 3/4" (19mm) thick material. If you are using 5/8" (16mm) thick material, subtract 1/4" (6.5mm) from each dimension. Do not use any material with a thickness of less than 5/8" (16mm) as this may compromise the rigidity of the enclosure.
• All enclosure volumes listed above are net internal volumes! Driver displacement, port displacement and brace displacement must be added to obtain the final gross internal volume. All enclosure dimensions above have already taken this into acount.
• When using two subwoofers in a common enclosure simply double the required volume and, in the case of a ported enclosure, use two times the recommended port(s). Likewise, when using three subwoofers in a common enclosure simply triple the required volume and, in the case of a ported enclosure, use three times the recommended port(s).
• We recommend the use of this speaker in a bi-amplified system using high-quality satellite speakers and a high-quality amplifier. We do not recommend the use of this subwoofer with a passive crossover (coil), as this type of device will adversely affect performance.
As you can see it all depends on the space you have available, whilst the vented box will give you a more efficient bass responce especially with the low range frequencies.
If you to go and look at the information about your sub woofer and find out all the information about building or buying the correct enclosure then this is the link to the pdf file I found:
The enclosure info is on page 3:
JL AUDIO 15W3 Tech Specs and box info.
Warm regards
Mike
Oct 12, 2010 | Jl Audio 15W3-D4 Car Subwoofer
Should I use a vented box or a non vented box for my ALpha PSW412
Well, First you need to figure out a few things. How much room you have is one main consideration, If you go with a vented (ported) enclosure or band pass (see below) than you will need more room than with a seal enclosure, If you really have no room you can mount them " Free Air" which is mounted on a board and fired into the back seats, the Truck acts as the enclosure.
Now the type of bass you want is another consideration. The best enclosure for maximum bass is a bandpass box. It is 2 subs facing each other with one side fully enclosed and the other side ported. This is best for deep powerful bass but the enclosure can be rather large. Vented boxes are second best (In my opinion) they give you deeper bass and more power than the sealed boxes. Sealed boxes give you less power from your sub and are a little flatter. Some say that the bass is more accurate and tighter , depending on the type of music you play. Rock you would want a tighter bass(sealed) and hip hop or techno style you would want a deep bass(ported). Lastly you have the free air which gives you the least amount of bass and is usually rather flat sounding. If you have the room go for the band pass box, if room is an issue than go with a sealed and specifically design box for you vehicle. Alot of places design boxes for almost every car out there. Just make sure that have a well designed box, It makes a world of difference, than an improper box.
May 22, 2010 | Alphasonik PSW412 Car Subwoofer
What size enclosure does this require
from 0.80 to 1.25 for a seal box 1.5 cf for vented box with a port
Apr 01, 2010 | Lightning Audio P2.10.4 Car Subwoofer
I have a hollywood sound labs excursion 1080D and no manuel
Even though the 1080D is a discontinued model and not much support is available, I did find some information. It appears to be a good subwoofer.
  • 10" Dual 4 Ohm Subwoofer
  • 80oz. Magnet (160oz. Motor Structure)
  • Composite Non-Pressed Kevlar/Pulp Cone
  • "DWS" (Patent Pending) Double Wide Surround
  • 2" High Temperature Voice oil With Kapton Former
  • Designed for Small Vented and Sealed designs
  • Embossed Dustcap
  • 300W RMS / 600W Peak Power Handling
  • New "EdgeTech" (Patent Pending) terminal design
  • Custom stamped steel "Dragon Claw" Basket
  • The "Designed for "Small Vented and Sealed designs" description would seem to say that it should perform adequately in a truck box. One of the Atrend boxes, either the sealed 10TK at .80 CuFt or the vented 10TKV at .88 CuFt, or a DIY box of similar size should perform OK. You might wish to add some polyfil stuffing to the box. Polyfil, one trade name is "Acoustistuff", will make the enclosure seem larger.
    Hope this helps!
    Mar 26, 2009 | Car Audio & Video
    I am trying to find specifications and optimum enclosure volumes.
    visit the12volt.com, or i think that is what the url was. been a while but my buddy was an installer and he swore by the website.
    anyways just trying to be helpful
    Mar 12, 2009 | Phoenix Gold QXE-108 Car Subwoofer
    MTX 5500 SLEDGEHAMMER 12" ENCLOSURE
    According to MTX they need 1.25 cubic ft per sub sealed and 2 cubic feet vented. Most pre-fab boxes will work for those subs.
    Jan 06, 2009 | MTX Dual 12" Subwoofer Enclosure (Bs212s)
    What size enclosure (sealed)for Alpine 12"1242D(METAL Music)
  • 12" subwoofer with dual 4-ohm voice coils
  • Kevlar reinforced pulp cone with Santoprene™ rubber surround
  • cast aluminum frame with perimeter venting
  • frequency response: 25-500 Hz
  • power handling: 200-500 watts RMS (250 watts per coil)
  • peak power: 1,500 watts
  • sensitivity: 85 dB
  • top-mount depth: 7-5/8"
  • sealed box volume: 0.57-1.0 cu. ft.
  • ported box volume: 0.75-2.0 cu. ft.
  • For rock, i actually have 2 seperate 12's in slot port boxes i built facing forward. Facing forward reduces a little resonance and spl, but keeps alot of that annoying rattle off your tag lol
    Hope this helps :)
    Dec 10, 2008 | Alpine Type-R SWR-1242D Car Subwoofer
    Car Audio & Video Logo
    530 people viewed this question
    Top Nakamichi Car Audio & Video Experts
    Aaron Hackbarth
    Level 1 Expert
    Jaime Hernandez
    Mohamed Ismail
    Mohamed Ismail
    Are you a Nakamichi Car Audio and Video Expert? Answer questions, earn points and help others
