Question about Canon PowerShot SD1000 Digital Camera
How do i eliminate wind noise when recording video outside with my sd 1000
    Problem Solver:
  • 16 Answers
Most professional recording mikes have a foam cover to reduce the wind noise. Maybe a small piece of material like that might help reduce wind noise if it is over where the mike(s) are.
I have a CD-1000 Sony camera I want to sell, but have to transfer slides to CD first on it.
Posted on Sep 13, 2009
How to eliminate virus in my zoom q3hd
Have the memory card SD/HC checked by any antivirus software.
Format and clear if necessary.
Rest assured. There CANNOT be any virus in your Zoom Q3HD.
Apr 27, 2014 | Zoom Q3HD 1080p Handy Video Recorder
Back ground noise
You cannot remove the background noise of already recorded material unless you have special software for that purpose. It is available, but costly. To eliminate some background noise, you may in the future, try to muffle the microphone by turning down the volume and recording by moving the device closer to the sound sources. Some folks put a wind sock over the recorder, as you may have noticed during TV News recordings on street events or at a studio. Try a wool or thick sock over the recorder and see if that helps.
Apr 15, 2014 | Olympus VN-711PC Digital Voice Recorder...
I recorded videos at a concert with the new nikon coolpix L810 and the sound on the video is horrible.What is causing the noise in my video? sounds like wind is blowing or a crackling noise
The problem is the microphone on the camera. The mic on the camera is for recording sound in more normal environments. The sound level on a typical concert is much higher than normal, and the mic on the camera just doesn't have what it takes to record sound at those levels.
One possible solution is to record the sound with a dedicated audio recording device, and combine the video and audio in your video editing software.
Jul 02, 2012 | Nikon Coolpix L810 16.1-Megapixel Digital...
Where is the microphone?
The microphone is located on the front of the camera, just behind the flash pop-up button. As far as I can tell there's no way to turn it off, but you can easily strip the audio out and replace it using video editing software on a computer.
That's probably the best way to eliminate wind noise as well. Remember that the camera is primarily an image recording device. Leave the sound recording to a device better suited for it, with a microphone shielded by a wind screen. Or record the sound in a studio. But then we're getting into real money, the way "real" filmmakers work.
Jun 13, 2012 | Fuji FinePix S9500 Zoom Digital Camera
Static noise when playing back recording, sounds like the wind
This camera has a single Mic - make sure your finger isn't over it though -- try making a recording in a closed room - no wind noise - is there still static ??
Go through settings and see what choices there are -- like outdoor , indoor . close to subject etc.
My CAM had a close up and background button - which was a sensitivity setting - and the background setting picked up EVERY sound from miles around and filled the tape with noise. The close up setting only picked up sound from bout 2 - 3 meters.
Do you also have an external plug for a Mic ? this would also check whether it's the camera mic or recording that is at fault ??
Ray
Mar 07, 2011 | Samsung SC-X105L Memory Card Camcorder
At high speeds, I here a high pitched squeal coming from the passenger side dashboard. Its like the wind is reflrcting off something and it makes this annoying sound. Can you help me figure this out.
I'd check the passenger side mirror first, make sure it is tight to the window frame, no gaps. It causes a wind noise or whistle. It could be from the outside of the truck, try to pin point. Does noise go away with either window down? Does noise get louder turning in one direction (wheel bearing)? Does it get worse then seem better (could be tire noise)? Eliminate fan motor, and radio. Does it get worse with vehicle speed or just engine speed?
Jan 27, 2011 | 2004 Ford Explorer
The sound recording is noisy
try setting the options on the sound recording lower and try to find the wind audio correction selection. that should work.
~good luck
Jul 14, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
My lifecam problem
What it sounds like is that you are getting feedback from your speakers. Turn down the sound or try a set of headphones to see if that eliminates the problem.
Hope this helps. Bud
Jan 24, 2009 | Microsoft LifeCam VX-1000 Webcam
Wind noise on vhs
Hi Claire
Wind noise is very common when recording outside.
Firstly, make sure the microphone you use is uni-directional. This means it will work in the same way that a television antenna does, in that it will pick up sound from the direction it points in, but sounds from other directions will be attenuated. These mics are often used by broadcasters and those in noisy situations, football matches etc.
Secondly, make sure your microphone is fitted with a good foam wind cover. If it already has one, fit a thicker one. This is the single most important thing you can do to cut down on wind noise. You can always get yourself some foam and wrap it around the microphone, right over the top, and tie it with a piece of string.
It sounds a bit wacky, but even pro broadcasters do this from time to time.
Finally, consider using an extension mic cable and positioning it closer to the signal source. Be careful though. If the neighbours are that bad, make sure you are not on your own.
Good luck and best wishes
Helen
Apr 04, 2008 | Televison & Video
Noise during video recording
Turn off Continuous AF (auto focus) to prevent recording camera noise during video capture. When you turn off Continuous AF, you may notice a narrower area of focus or depth of field, especially if you zoomed to a telephoto position before recording. Turn the Mode dial to Video, then press the Menu button. Highlight the Continuous AF menu, then press the OK button. Highlight Off, then press the OK button. (On is the default.) Press the Menu button to turn off the menu screen. This setting remains until you change it, change the Mode dial, or turn off the camera.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Canon PowerShot SD1000 Digital Camera Logo
324 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
