Question about Toshiba 120GB USB 2.0 Portable External 120 GB Hard Drive
Pc doesnt detect/read portable HDD, but a USB connection appears on the task bar
  • 3,153 Answers
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especialy true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
Posted on Sep 05, 2009
    President:
  • 1,015 Answers
Is the portable hard drive USB 2.0 and you have it connected to a USB 1.0 port? Is it brand new? sometimes brand new drives have not been formatted yet and will not be recognized untill it is formatted. Go into my computer and see if it is there. Are there any drivers that came with it and are required to be installed? Does your pc have the proper USB 2.0 drivers installed? And lastly does it do it on every usb connection on your computer?
My iomega external hdd has its lights on but cant be detected and does not seem to read anymore
i had the same problem. you have to be patient. open my computer through the start menu. unplug the hdd wait 15 secs and plug back in. if it still doesnt read try another port. and if it still doesnt work your hdd has a malfunction and you may need a new one
Feb 01, 2011 | Iomega 250GB USB2.0/FW 250 GB USB 2.0 Hard...
I have a Iomega LPHD120-U, it was working fine but in the middle of a program a msg saying content lost popped up and since then the hadr drive doesnt open up. on connection it the green light appears for...
You might try opening it up and seeing if you can pull the HDD and put it in your PC as an auxiliary drive. If it works, the interface or power supply was bad.
If it's intermittent, get all the data off it ASAP, because you'll probably not going to get much use out of it.
Apr 07, 2017 | Iomega 1TB Desktop USB 2.0 Hard Drive
Instruction Manual for USB Portable Optical Drive
1. connect USB cable to the USB port on PC
2. check "my computer" to see if USB drive is showing
3. the task bar will indicate if you have a new installed device and show that it is active. If not then you may have an issue with the contoller board on the USB device.
Oct 04, 2010 | Computers & Internet
My portable HD detect pc, but no driver found and cpould'nt open
If it shows up in my computer then just double click on it as you would the C drive or dvd or cd it should put the driver in already if it is showing remove safely sometimes it will require a reboot after it is installed
Jul 07, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
I HAVE A PHILIPS MP3 PLAYER, WHEN I CONNECT IT TO MY PC,VIA USB PORT, THE PC DOES NOT RECOGNISE IT. I ALSO HAVE A SONY MP3, WHICH MY PC RECOGNISES IT, NO PROBLEM
ur philips mp3 player memory is infected by virus thats why it cant be detected by ur pc same prblm happens with pen drives as well.
Follow These steps connect mp3 player and restart ur pc this will help in detection.
if this doesnt work then use usb virus scan utility
this is the link:
http://www.softpedia.com/get/PORTABLE-SOFTWARE/Antivirus---Antispyware/Windows-Portable-Applications-McAfee-VirusScan-USB.shtml
Mar 30, 2010 | Creative Labs ZEN Vision:M Digital Media...
External HDD not detected
have you try with the other usb cable and the usb port.
Jan 20, 2010 | Western Digital 320GB MyBook External USB...
My new portable hdd is not getting detected on my xp
Your USB ports may be version 1.1
You need a USB "Y" cable.
The USB Y cable uses two USB ports on your laptop and the third plugs into the external HDD.
Check RadioShack or maybe the vendor has a USB Y cable.
This will work!
Sep 08, 2009 | Computers & Internet
Western Digital External HDD not appearing in My Computer
It could be that the OS is not assigning a drive letter to your removable drive. To do this, go to disk management and assign one.
Assuming OS is Win 2000/XP/Vista
Right-click My Computer then Manage
Click on Disk Management
Right-click the removable drive and click on Change Drive Letter
Assign a drive letter and click OK
Your drive should now show up on My Computer
Hope this helps.
Jun 20, 2009 | Western Digital Passport 320GB External...
Ihave purchased a SeagateFreeagent 500 gb USB external HDD.It was working very well till I tried to create partitions by using Paragan Disk Management software. In the middle of formatting the partition...
After plugging ur HDD, verify the device is detected or not in Device manager and Try Partitioning Again GUI mode (means in XP).. or follow the steps..
1- Go to Computer Management, Click Disk Management
2 - You will find you External HDD in the Right side
3 - Just Right Click the Drive, if it asks Initialize HDD, just Initialize and Create Partition as u like.
Have Fun
- Rajkumar
Mar 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Toshiba 120GB USB 2.0 Portable External 120 GB Hard Drive Logo
596 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
