Question about Intel D101GGC Motherboard
I have D101GGC motherboard. I had Nvidia 6200 Geforce graphic card earlier but removed it now and installed VGA drivers. When I restarted the computer it was very slow and in the task manager ''Image name SYSTEM Username SYSTEM'' process was using 99 CPU. So I uninstalled the drivers and restarted it, still the SYSTEM process is using 99 CPU.(System process not system idle process)
    President:
  • 1,015 Answers
Did you fully remove the Nvidia software? Sometimes you need to remove the software for the card because it is trying to load when windows starts and cannot find the card. You can also try and disable the agp or pci-express slot in the bios and see if that helps. Also make sure that the onboard video can run the directX version you have installed on your system. If the Nvidia card runs on directX 9 and the onboard video can only run directX 8 and directx 9 is running on your PC then that will definently cause an issue.
Posted on Sep 05, 2009
Nvidia geforce g210
1.5.1 Graphics Subsystem
The board contains two separate, mutually exclusive graphics options. Either the integrated
graphics processor (contained within the ATI Radeon Xpress 200 Northbridge) is used, or a PCI
Express x16 add-in card can be used. When a PCI Express x16 add-in card is installed, the ATI
Radeon Xpress 200 Northbridge graphics controller is disabled.
http://downloadmirror.intel.com/15113/eng/D101GGC_TechProdSpec.pdf
Mar 06, 2014 | Intel Computers & Internet
Setup dual-boot disks, one loads VGA instead of GeForce 6200
You should enter Bios setup when restarting and check that it says AGP or PCI for video display. You can then go to Start then Run and type in msconfig. Go through the list for the startup menu and make sure that NVIDIA is displayed with a checkmark.
When you installed the new driver, also make sure that you disabled the default VGA driver too. You may have to check that out. If both are running there will be conflict. Any questions, please don't hesitate.
Nov 18, 2007 | XFX GeForce 6200 Graphic Card
NVIDIA GeForce 6200 and Intel(R) 82865G Graphics Controller
Due to the fact that you are using the Integrated Graphics of the motherboard, by plugging the monitor into the I/O area on the back of the computer; AND cannot use the graphics card when plugged into it;
{Input/Output area}
1) It sounds like you opened the computer, physically installed the graphics card, and plugged the monitor into the graphics card.
IF, the above is correct; OR,
If you physically installed the graphics card, plugged the monitor into the graphics card, and THEN installed the drivers off of an installation CD, or from Nvidia Support;
you have a Driver Conflict.
Explanation;
When a device is installed on a computer, (In this case a graphics card), Windows 'breaks it's neck' to find matching Drivers.
If THE drivers are not there, Windows will match up one of it's Thousands, of generic drivers.
This Will NOT DO. A Driver conflict results;
Windows: "Which drivers do I use?
These or THESE?"
Also;
Drivers for the Nvidia GeForce 6200 graphics card MUST be installed.
Drivers are small pieces of software, that allow the Operating System to 'communicate' with a device.
{Windows XP and Windows 7 are two examples of an O/S}
A) Unplug the computer from power. (Computer off, 'natch)
B) FOLLOW Anti-Static Precautions
C) Remove the graphics card, plug the monitor into the I/O area at the back of the computer.
D) Press the Power On button in, and hold it in for a count of Five seconds. Count '1001, 1002, 1003, 1004, 1005'. Release the Power On button. Do this procedure two more times.
What you are doing is clearing CMOS Error Codes, and resetting BIOS Setup parameters back to the factory default settings.
Leave the cover off, plug the computer back into power.
WAIT 1 minute. Turn the computer on.
When Windows loads install the installation disk, and follow the instructions. (Install the drivers, and the tools), OR
Download AND install the drivers from Nvidia Support,
http://www.nvidia.com/object/winxp-285.58-whql-driver.html
If you need help downloading or installing, post in a Comment. Even if it is something you do not understand.
Primer:
The Nvidia GeForce 6200 graphics/video card, is part of the Nvidia GeForce 6 Series,
http://en.wikipedia.org/wiki/GeForce_6_Series
http://en.wikipedia.org/wiki/Comparison_of_Nvidia_graphics_processing_units#GeForce_6_.286xxx.29_series
The GPU is Nvidia codename - NV44
[ GPU = Graphics Processing Unit,
http://en.wikipedia.org/wiki/GPU ]
How graphics cards work,
http://computer.howstuffworks.com/graphics-card.htm
How 3D graphics work,
http://computer.howstuffworks.com/3dgraphics.htm
For additional questions please post in a Comment.
If I am way off base, and/or if this does not fix the problem, state in a Comment.
The intent is to help you, not gather points, or frills.
Regards,
joecoolvette
Dec 27, 2011 | Nvidia GeForce 6800 GT, (256 MB) Graphic...
I recently bought a Nvidia GeForce 6200 256Mb AGP card to replace a 5200 card so my daughter can run her school assistance programs. its my old computer and I never had any problems with the old card...
Sounds like a Driver Conflict.
Still have the old 5200 drivers in there?
Did you install the drivers for the 6200, BEFORE you physically put the graphics card in? (Not shouting)
Let's say you did remove the 5200 drivers, before you installed the 6200 graphics card.
BUT,
If you physically install the 6200 graphics card, BEFORE you have installed the drivers, Windows 'sees' a new device, and hurries up to match one of it's generic drivers.
(Windows has thousands of drivers!)
Now you come along, and install THE drivers for the 6200. Windows has a drivers conflict.
Windows: "Which drivers do I use? These, or THESE?"
Makes for a garbled graphics display as you've described.
If the above is true, start over.
Go to Add/Remove Programs, and Remove the Nvidia software. All of it that has Nvidia next to it.
(THIS, is provided of course, that the computer HAS Integrated Graphics, and does not just use a graphics card. You will be plugging the monitor, into the VGA port in the I/O area, on the back of the computer temporarily, if this is true, and this computer has Integrated Graphics)
(Start>Control Panel>Add/Remove Programs) If there is more than one Nvidia program listed, Do No restart the computer each time you remove one. Do Not restart. Read on)
After all Nvidia software has been removed, close Add/Remove Programs, close Control Panel, and return to the desktop screen.
Shut the computer down normally. (Start>Turn Off Computer>Shut Down)
Press the Power On button in, and hold it in. Hold it in for a count of 5 seconds. (Count, 1001,..1002,..1003,..1004,..1005) Let go of the Power On button. Do this procedure Two more times.
What you are doing is clearing any CMOS Error Codes, and resetting BIOS back to the factory default settings.
Open the case. TOUCH the metal frame of the case to relieve your body of Static electricity. Remove the 6200 card. Plug the monitor into the back of the computer into the VGA port. Leave the case open, you'll be going back in there.
Plug the computer into power. WAIT 1 minute, then turn it on. After Windows has fully loaded, install the GeForce 6200 drivers from that CD disk. Do Not restart.
Shut down normally.
Unplug from power. Touch that metal frame again. Install the GeForce 6200 card. Close the case. Plug the monitor into the GeForce 6200. (You did plug the monitor into the 6200 the first time, right, and not the VGA port?)
Plug the computer back into power. WAIT 1 minute. Turn the computer on. Go to Start>Nvidia>Nvidia control panel, and set the settings.
Aug 15, 2009 | Nvidia GeForce 6200 AGP Graphic Card
Disply Problem
its a driver problem, my bud had the same probs with a older nVidia but gives same BSOD msg. just up date the drivers or reinstall them. http://www.nvidia.com/object/winxp_186.08_beta.html all picked out for ya just C&P it. oh and after downloading new drivers uninstall the old drivers in the add/remove, restart and turn off the found new hardware wiz then install new drivers and restart again. sad to say that the BSOD was only hapaning cuz my buds card was dieing. hope that yours lives =D
Jun 09, 2009 | XFX GeForce 6200 Graphic Card
Problem with my GeForce 6200a graphic card
the driver cause this so go to the below link and download the driver, befour installation go to ur contro panel and remove ur old driver then restart,
then install the new driver and reboot again,
this should solve the problem
link :
http://www.nvidia.com/content/DriverDownload/download_confirmation.asp?kw=&url=http://us.download.nvidia.com/Windows/181.22/181.22_geforce_winxp_32bit_english_whql.exe
Feb 01, 2009 | EliteGroup Computers & Internet
Vedio controller GeForce 6200
XFX GeForce 6200, Graphic Card
driver dowunload
Aug 16, 2008 | XFX GeForce 6200 Graphic Card
Intel D101GGC Motherboard PCI Express compatibility issues........
i'm using NVIDIA GEFORCE 8600 GT on my d101ggc board and its working fine
Jun 30, 2008 | Intel D101GGC Motherboard
Intel D101GGC Motherboard Logo
168 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
