Question about Whirlpool Duet GHW9150P Front Load Washer
How to remove bearing from rear tub? - Whirlpool Duet GHW9150P Front Load Washer
    Problem Solver:
  • 4 Answers
Take everything apart and knock out the seal and bearings similar to removing bearing from the front wheel of an American car. The trick is, where do you find a replacement seal 50 mm ID X 100 mm OD X 13.5 mm wide.
Posted on Sep 16, 2009
  • 30 Answers
BIG JOB!!!!
You have to completely remove the entire tub assembly to change this out.
This is the biggest and time consuming jobs to do on front load washers.
No easy way to do but to pull the entire unit apart.
Posted on Sep 05, 2009
Solution #2 is right on. I just completed this job and found that you have to replace the outer tub assembly (rear half has the bearings already pressed in place). You have to take most of the washer apart to get it out. It's a several hour job and it helps A LOT if you have two people.
Posted on Sep 17, 2009
Tub is wearing down internal ruber and making loud thumping noise during spin cycle
3 Suggested Answers
fridgetech
  • 473 Answers
SOURCE: The inner tub is out of balance and rubbing against the outer tub
The rear bearing is part of the back half of the outer tub. In some cases the basket will need replaced also if the shaft is scored. This is a big job. In most cases whirlpool will warranty the parts for 10 years but not the labor. Will need to check in your owners manual. Hope this helps
Posted on Dec 02, 2008
aborcass
  • 2651 Answers
SOURCE: change rear tub bearing
the nner tub and outer tub (rear section) need to be replaced,the bearing is mounted in rear section of tub, the entire unit is removed fromthe machine from the rear of machine in order to relpace. new pulley, nut, as well. not and easy job, and can be very costly paying for those parts.
Posted on Dec 04, 2008
Water leaking from bearing at back of drum
you better get at this soon,the lip-seal is gone from the outer tub and now water has penetrated the bearings behind this lip-seal,the longer you wait the harder it will be to remove these bearings and if its a plastic outer tub you can destroy this tub when removing the old bearings,the inner tub needs to be removed,the rear access needs to be open the motor pulley removed,the c-clip that secures the outer bearing needs removing then the inner tub can come out the front to access these bearings for replacement
Mar 24, 2011 | Indesit W 123 Front Load Washer
The drum inside my ge wbvh6240fww washer is loose. I can move it around with my hands. During spin cycles it sounds like a tornado, and the room fills with smoke from where the drum rubs. The belt is fine,...
There is one bearing in rear tub/bearing is part of rear tub...To repair that unit you will need a rear tub/inner basket with spindal and possible a front tub if it damaged..If i was you I would price the parts b/c you may not want to repair it as it can be costly .....Good luck
Jan 31, 2011 | GE WBVH6240F Front Load Washer
Maytag washer MAV551EEWW top load with loose tub
If the tub seal lets go water will weep into the tub bearing. This will rust the basket shaft and normally wreck the tub bearing. Once the bearings starts to get worn enough it usually gets very noisy. The tub bearing is pressed onto the outer back half of the tub shell assembly. Normally need to replace the inner basket/shaft assembly  and the outer shell with the tub bearing.
Sometimes the inner basket support will crack, this can give an clicking or banging noise as well.
Pictures of this job...
A sure indication was the brown junk/gookus leaking out if the rear bearing area and the belt has spewed it around in the drum that the rear bearing and seal was bad...
Picture1 - Picture2
The whole outer shell and basket come out to do this repair....what bad bearing and rusted shaft looked like...
Picture1 - Picture2 - Picture3
I had to remove the back panel. Undo the pump hose & water level hose, remove the 2 shocks, remove the motor, undo the front boot from the outer panel and remove the 2 springs to lift the whole assembly out from the back to work on it.
Picture1 ( boot pushed inside ) Help page1 - Help page2
May 07, 2009 | Washing Machines
I moved my washer cause of relocating and now when on spin cycle it makes a howling noise, what can i do to fix the problem, its a front loader gallery series??
Picture1 - Picture2
May 05, 2009 | Frigidaire Washing Machines
Change rear tub bearing
Dec 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Replace bearing
You can try a puller but typically it is recommended to replace the entire rear outer tub half (which comes with the bearings already pressed into it). You will also need the tub seal that goes between the front and rear tub halves. Hope this helps.
Dec 02, 2008 | LG WM-1832C Front Load Washer
Bearing failure
you have to pull entire tub assy out of mach,removing all hoses,motor,wiring shocks and springs.then you remove all the bolts going around the middle of front and rear tub.the bearings and seals are pressed into the rear tub and are not removable for separate replacement.rear tub and basket have to be replaced together and is quite expensive to buy these parts..good luck
Sep 24, 2008 | Kenmore 44102 Front Load Washer
Whirlpool Sport Duet: Purchased back in August 2006 the Spin Dry Cycle used to be very quiet - In the last month the cycle "sound effects" resemble the warm up of a commercial jet...
To test for bearing failure, open the door, pull back the door seal then grab the plastic outer tub with one hand and the inner basket with the other hand. If you can lift on the basket and wiggle up and down, the tub bearing is bad.
The tub bearing is contained in the rear half of the outer tub. To replace the rear half of the outer tub requires total disassembly of the machine. The top, console, door seal, front panel, rear panel drain hose, pressure hose etc. all have to be removed. Then..the entire outer tub has to be removed and split apart. The basket will need to be removed and the rear half of the tub replaced,,,It is a very time consuming job, if you are mechanically inclined, you can do it, if not, consider a professional. Cost to repair by a professional will run around $450.00. Outer tub cost is around $300.00.
If you need further assistance, let me know
Regards,
reg501
Jul 05, 2008 | Whirlpool Washing Machines
How to Remove the bearing outer race from the shell of the washing machine tub
bearing on most can not be removed there molded in the outer tub comes with the rear half of the tub already installed
Feb 26, 2008 | Kenmore 43052 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
638 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
