Question about Vacuums
Need an owner's manual for the Shark Roadster Euro-Pro vacuum sweeper Model UV208R in order to change the belt
Agent Don
  • 310 Answers
SOURCE: Changing A Belt on Vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=656349
Generic problem for all Vacuums
Changing a Belt on Vacuum
Posted by cnjk on Jun 08, 2008
Can you give me directions on changing a shark Euro-Pro UV219CS vacuum belt?
Thank you.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The Shark vacuum cleaner belt is a side driven belt and you need to remove the bottom plate and remove the belt and place the new belt on the pulley side of the brushroll and make sure the ends are the same, insert the brushroll and then use a belt puller or screwdriver with a bend on the end and then stretch the belt onto the motor pulley and the track it in a straight line, replace the bottom plate. If you need further assistance please fee free to contact your local vacuum cleaner dealer in your area. So feel free to contact your local vacuum cleaner dealer with questions. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.sharkvac.com/ Customer Tech Support 1-800-798-7398
These are the other brands that use the same tech support line
Shark / Euro-Pro / Infinity / Bravetti / and Fantom
http://www.fantom.com/ Customer Tech Support 1-800-798-7398
Hours are Monday thru Saturday from 9:00 AM to 6:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 11, 2008
reddevil6
  • 1673 Answers
SOURCE: Shark Euro Pro upright vacuum V1310RS
Most vacuums you either remove the bottom plate, or the top cover comes off. If no screws on the top cover, then turn vac. over and remove the screws on the bottom. Then you should be able to get to the brush roll and belt.
Posted on Feb 17, 2008
dodge_is
  • 42 Answers
SOURCE: Shark euro-pro x upright vacuum that shuts down every 15 minutes
These are prone to overheating. The manufacturer put a foam 'filter' wrap around the electric motor. This filter wrap insulates the motor, trapping heat inside, which causes overheating. The motor is very similar in form and function to the one in the Hoover Windtunnel, but the Windtunnel has no filter wrap. It doesn't overheat, and functions fine without it. There is a filter on the intake anyway. It's a redundant filter, and I have removed mine. It works fine now.
If you take the filter out yourself, you will need a special screwdriver for one of the motor cover screws. I guess they don't want the consumers opening it up.
I suggest taking it to a vacuum repair shop and explaining to them the problem, and asking them to remove the filter wrap from the motor.
Posted on Feb 23, 2010
dodge_is
  • 42 Answers
SOURCE: I need a belt for my Shark Pursuit Euro-Pro X
I am unsure of the part number, but they have them for about $5 after shipping here:
http://www.totalvac.com/accessory/parts/sharkbelt.html
SOURCE: Shark Pursuit Euro-pro X vacuum cleaner, 12 amp, upright model
This vacum cleaner is equipped for auto shut off when it gets hot , It gets hot when it gets clogged either the little sponge filter is to dirty or the the round white filter in the dust collecting container.
But if they are both clean then it is clogged in the line probably with lot of carpet fiber, in that case you ned to take the dust container out and possibly the assembly from bottom like when you change the belt, then take of the Handle where the flex hose is attached, then you gonna need a wire hanger bend a long shape close to the shape of the hose line from handle to where it curved around in the bottom opening where it collects the dust behind the spin brush the just stick the hanger from the handle side cause the clog is probably in the lower side then just push the clogs out . Be care full not to puncture the flex hose with hanger. Its probably a good idea to bent the tip of the hanger so that it wont poke hole in the flex hose.
That's what happened with mine I spend hours and hours and days to figure it out. I could have just through it away, but it just kind a pissed me off and the War was on as stubborn as i am, but finally I won and I got the satisfaction of the sweet victory.
Waste lot of time though but it just one of those things. It never messed with me again.
But that is what's wrong with it. Good luck it a good vacum though very power full.
Posted on Apr 17, 2011
How do you change a belt on the shark Euro Pro Roadster model
https://www.hunker.com/12172999/how-to-change-the-belt-on-a-shark-vacuum-cleaner
Above, Click an x to get rid of the ad to see the info.
https://www.youtube.com/watch?v=Jr5xSpomTYc
And here is the manual:
https://www.manualslib.com/manual/783661/Shark-Uv208.html
Jun 14, 2017 | Shark Vacuums
I have a shark cordless sweeper model # V1900W 7.2 I need a new charger for it can't locate one ? were can i find one store ect'
The info gripfitter gave you is incorrect - that is not the right charger # - it is not a typical charger - Shark told me the charger for model #1900W is 1078FK and cost $12.95 you have to call to order it they do not have that part online 1-800-798-7398
Jan 26, 2011 | Euro-Pro S3325 Handheld Steam Vacuum
I need an owners manual for the navigator shark vac NV22LCO 31
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the
Shark Manuals that you need.
heatman101
Sep 23, 2010 | Euro-Pro NV22 Shark Navigator Bagless...
Need new brush ( power beater bar) and belts
You're in luck! We carry both the belts, as well as the roller brush for your Shark Infinity model that you listed this repair under.
Here are links to both parts you are requesting:
Euro-Pro Shark Infinity NV30, NV31 Bagless Upright Roller Brush Assembly
Belt Set For Shark Infinity Bagless Uprights, Models NV30, NV31
After you receive the parts, here's a link to the manual that will walk you through, step by step on how to replace both items if you have any questions, or need help:
Shark Infinity Bagless Upright Owners Manual
Hopefully this was able to answer your questions. Please feel free to reply to this email or just give me a call if you have any further questions. If this helped, please be so kind and rate the repair, or leave some feedback for me.
Chris Jones
GoVacuum.com
May 22, 2010 | Euro-Pro NV31 Infinity Vacuum
The belt broke on my my SHARK Model V15Z and Euro Pro hasn't responded to my request for a new belt w/ directions as how to effect repairs.
Well it's actually not so bad once you realize where they hid the screws. Gently pull outwards on either side of the housing that surrounds the brush and vacuum.There are no screws for this piece it simply snaps off and on. Once this piece is removed you'll see two phillips type screws on the side where the removable hose attaches. Remove the two screws and pull off the molded section they keep in place. The brush will now come off revealing the rotor that the belts slips over. The belt is placed over the rotor and the brush cylinder in a figure eight. Reassemble and your ready to go. Now if Shark will only help customers locate a replacement belt you may find this info useful.....
Feb 28, 2009 | Euro-Pro Cordless Bagless Upright Sweeper...
Can I buy replacement batteries for Shark Cordless Sweeper
I need a replacement battery for my Shark Stick sweeper model V1911 N. Can't find it on their web site. I guess it is old. Murnieruth
Nov 25, 2008 | Euro-Pro Shark Professional Upright Vacuum...
Vacuums Logo
824 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
