Question about Acer Aspire One PC Notebook
No internet when on battery power - Acer Aspire One PC Notebook
    President:
  • 1,015 Answers
Sometimes laptops are setup in the power managment settings to turn off the wireless when disconnected from the power to conserve battery life. Check the power management settings to see if this setting has been activated. If there is nothing there go into the control panel and check to see if there are advanced power management settings or wireless settings causing the issue.
Posted on Sep 05, 2009
Dell latitude laptop D600 blinks orenge battery light 4 times then green and did not turn on
take the battery and the power cable out ,then hold on to power button on your laptop for 75 seconds ,then power it up without the battery ,you have a bad battery
Nov 08, 2017 | Dell Computers & Internet
Google play store will not open
Sounds like you do not have an internet connection. Do you have internet service? If you do, turn your phone off and take out the battery, hold down the power button for 30 seconds, reinstall the battery power it up and you should then have an internet connection if you have service for internet/data on your phone
Jul 23, 2014 | Samsung Galaxy Note II N7100 Unlocked...
Losing time settings
When it lose time settings? When you gets connected with internet or power off your PC?
If it is case of power off your PC, then it's all about your CMOS battery of your motherboard. It looks like a small button type battery. Generally it supplies power to PC clock when your PC is turned off or power off. BIOS settings also gets power form this battery. You have to change it if this is the reason. It takes little price.
To change CMOS battery please read:
http://www.computerhope.com/issues/ch000239.htm
If it happens in case of When connected with Internet, It changes date and time automatically if internet time zone selected with "automatically synchronize with an Internet time server".
To deactivate it like windows xp ( go to control panel, select date and time properties, select Internet Time tab and unmarked "Automatically synchronize with an internet time server" check box.
Click apply and ok to save changes. Now your date and time will not be changed.
Jun 25, 2012 | Lenovo ThinkCentre Computers & Internet
My computer won't turn on i can get to the internet because it has an internet button but the main part of the computer won't turn on
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Aug 19, 2011 | Sony Computers & Internet
I cant get on the internet from my modem can u help me
Has the cable company provisioned your modem? IE - are you paying them for internet service, or are you just hoping that since you own the modem that all you have to do is hook it up and it'll work?
If you have paid the cable company for internet, and they have set up the provisioning for your modem, you may need to reset it.
Off the top of my head I am trying to recall if that unit has a battery in it.
If it does, to reset it, you need to remove the battery and unplug it.
Make sure the modem is connected to everything but power
insert the battery (if it has one) and reconnect the power
If you still don't have internet, call the cable internet service provider.
Feb 24, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Where is the battery that powers the Internet time/ date?
The motherboard BIOS battery keeps the motherboard setting and the date and time correct just like a watch battery. This BIOS battery is usually a 3 volt lithium battery, it is a coin size battery approx. 20mm in diameter most likely a CR2030 battery.
If you have a Internet time program that connects to the Internet, it will synchronize the computer's time with the Internet time.
Feb 13, 2011 | Acer AOpen AK77 Pro(A) (91.89A10.104)...
I-mate jama 101 battery charging -internet connection
hi , i hava i-mate jama 101 , when it off because of the low power ,i can't charge it only if i charge the battery with a universal charger???
Apr 09, 2010 | i-mate Jama 101 Smartphone
Message to change battery or connect AC
this means that your battery has very little remaining power. If you just charged the battery it means your battery is going bad. Replace the battery.
Aug 26, 2009 | Compaq Presario 2140US Notebook
Battery not charging.
I have the same problem at times. The life of laptop batteries is short if you are always connected to the internet. To save battery power / to increase the life of your battery overall and during each use, disable the internet when you are not using it.
Click on your "Local Area Connection Status", which is usually represented as an icon in the task bar menu at the bottom (blue bar) of your screen. Open that up and then click "disable" whenever you are not using the internet.
Unfortunately, at this point you might need a new battery though.
I hope this helps!
Sincerely, CBR2009
Aug 01, 2009 | HP Pavilion dv6000z Notebook
Problem with cable internet connection
you must have the wireless adapter and the lan adapter set to turn off when you are on battery power to reserve the battery, click on the battery icon in the taskbar and check the power settings or use empower Acer Epower management and turn them both on.
Sep 24, 2008 | Acer Aspire 5570-2758 Notebook
Acer Aspire One  PC Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
