Question about Poulan Garden
Poulan 42" 14.5 HP Hydrostatic transmission. I let the clutch out and it barely goes. I put the top of my foot under the petal and it goes fine. Did I loose a spring? And if so, Where do I get one and where does it go? Thank you!!
  • 62 Answers
Try some grease but you probably did lose a spring you can get one at tractor supply or any lawn mower repair shop
Posted on Oct 27, 2009
LT1050 hydrostatic drive slipping will travel but willnot pull hill 345 hrs on unit.what do i look for?
Try this. When you try to go up the hill put your left foot under the Clutch/brake pedal and lift up. Does it speed up at all?
If it does your engine to transmission belt probably needs to be replaced. The hours you have on the tractor are about right for this normal maintenance repair.
Mar 22, 2017 | Garden
Whinning noise when acceration. Engine accelarates fine but there is also a whinning noise
check alt bearing,open hood & listen while running,turn off engine and remove drive belt then start engine to see if noise goes away.
Jul 10, 2014 | 2008 Jeep Compass
How to fill hydrostatic transmission fluid on Poulan Pro
How do I check the transmission
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Fill Hydrostatic Transmission in Lawn Tractor
http://husqvarna.custhelp.com/app/answers/detail/a_id/387/~/maintenance---what-type-of-oil-is-used-in-the-hydrostatic-transmissions%3F
Craftsman Hydrostatic Transmission Fluid Change
Jul 28, 2012 | Poulan Garden
I have Poulan Por 54 inch deck,25 hp Kohler hydrostatic. After I mow on unlevel ground for about 30 min. Transmission makes noise jerks and won't go till it cools off. Will changing the fluid help
couldn't hurt to try but some cheaper mowers don't have a drain plug look on a parts break down on sears parts online but check the belt tension first
Apr 13, 2012 | Garden
What kind of fluid goes in the hydrostatic drive ? The mower goes fine in forward and reverse when first started. As the mower heats up it has trouble pulling itself. After about an hour it will barely...
Hi Jeff,
Use hydrostatic fluid. Consult your owner's manual for information. Do not use hydraulic transmission fluid.
If you do not have your owner's manual, you can find one on www.managemylife.com Just go to that site, click on manuals and enter your make and model number.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
May 09, 2011 | Briggs & Stratton Garden
Put a new top belt wont start we found a small soring but dont no where it goes went and started ok before belt went on . when turn key is like flat battery but had on charger not that help please
Hi
The belt goes on the top of the variable pulley and the transaxel pulley. There is a belt tentioner (flat Pulley) You need to remove the pulley and look on the bracket side closest to the clutch/break petal for a small hole for the spring. Put the spring hook in the hole through the top of the bracket, let it hang. Replace the pulley. Now remove the rear tire and rim on the left side of the mower. Clutch/ break is the left side. If you look where the tire use to be toward the front you will see the hole where the other end of the spring goes. The flat pulley goes toward the flat side of the belt.Pull the spring with a vice grip place the other hook in the hole.
Hope this helps
Terry
Jan 15, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
The mower will stall when I lift my foot off the brake.
If you have a gear transmission,you have some safety switches. One under the seat. One on the clutch -brake pedal. These switches work together to prevent accidental injury. One may have disconnected or a wire frayed. If one switch has failed it will shut the mower off.
Apr 23, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
MTD 42 inch hydrostatic drive lawnmower
1...first and foremost check the fluid level and top off with mobil 1 full synthetic 20w50 oil,
2...check the the engine pulley for wear
3...check idler arm spring tention.
inside yout transmission is a center pump section and swash plates and a set of 6-8 pistons , if dirt is allowed into the transmission it causes severe wear to these parts
my recomendation would be to dissasemble the transmission and inspect the pump center section and swash plates for wear....look for tiny scratches on the bearing surfaces, if it is worn then replace parts as needed. these worn parts will cause the transmission to "growl" or as you say "grind"
Nov 24, 2009 | Mtd Garden
Hydrostatic drive is weak
Try pulling back on the left foot pedal. This manually adjusts the drive belt tension and is a sign that the engine pulley has worn to the point the belt looses traction. A local repairman told me this last week and mine works fine now although in the very near future I'll need to replace the pully. Good luck
Sep 17, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Clutch pedal not returning to position
Under the dash look to see if there is a spring attached to the petal or maybe under the hood. Or you might have something getting in the was of the petal arm. Good Luck and PEACE
Jun 13, 2008 | 1987 Ford F 150
Garden Logo
269 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
