Question about JVC KD-NX5000 Car Video Player
Head unit position wrong
My head units face just changed positions without me touching anything and i do not know how to change the position back to flat
There is a button on the bottom left used to eject the cd. Push and hold this button until it beeps or you see tilt1 - tilt4 release and push to get the next position. Do this until you get it where you want it.
Posted on Oct 05, 2009
  • 733 Answers
Go to jvc website and download the instruction manual.
Posted on Sep 05, 2009
How do i change from trimmer to edger?
I know that on Black and Decker there is a button down on the head near where the shaft enters that when depressed will allow the operator to rotate the head to a new position 90 degrees away from start position. On my Craftsman, the joint between the power unit and the driven unit there is a little pushbutton that allows the head to be oriented in four different directions.
Jul 08, 2011 | Homelite Consumer Products 4.0 Amp, 13 In....
Don't have a manual, just need to know how to change ink and toner cartridges:)
Step 1
housing beneath. If done correctly, the print cartridge carrier should move into the loading position near the center of the unit.
Step 2
Push down on the colored cartridge lever at the front of the carrier to unlock and pop up the cartridge lid.
Step 3
Pull the spent cartridge from the printer.
Step 4
Pick up your new cartridge. Pull the sticker and tape gently from the back and bottom to reveal the gold metal electrical contacts.
Step 5
Insert the new cartridge into the print cartridge carrier with the electrical contacts facing down. Press the cartridge gently but firmly into the carrier so that the contacts on the cartridge touch the contacts in the carrier.
Step 6
Close the cartridge lid over the new cartridge until it clicks into place.
Step 7
Lift the scanner unit up slightly so that the scanner support arm unlocks. While holding the unit up with one hand, push the support back into its storage slot with your other hand and carefully lower the unit back into its original position on your printer.
Step 8
Press the third button down from the top on your control panel---marked by an arrow pointing from a scanner icon to a computer icon---for three seconds to print out a print alignment page. When finished, follow the on-screen instructions.
  • Step 2 Push down on the colored cartridge lever at the front of the carrier to unlock and pop up the cartridge lid.
  • Step 3 Pull the spent cartridge from the printer.
  • Step 4 Pick up your new cartridge. Pull the sticker and tape gently from the back and bottom to reveal the gold metal electrical contacts.
  • Step 5 Insert the new cartridge into the print cartridge carrier with the electrical contacts facing down. Press the cartridge gently but firmly into the carrier so that the contacts on the cartridge touch the contacts in the carrier.
  • Step 6 Close the cartridge lid over the new cartridge until it clicks into place.
  • Step 7 Lift the scanner unit up slightly so that the scanner support arm unlocks. While holding the unit up with one hand, push the support back into its storage slot with your other hand and carefully lower the unit back into its original position on your printer.
  • Step 8 Press the third button down from the top on your control panel---marked by an arrow pointing from a scanner icon to a computer icon---for three seconds to print out a print alignment page. When finished, follow the on-screen instructions.
  • Read more: How To Change the Ink Cartridge in a Lexmark X2470 | eHow.com http://www.ehow.com/how_6646584_change-ink-cartridge-lexmark-x2470.html#ixzz0wg8UCkTs
    Aug 15, 2010 | Lexmark X2470 All-In-One InkJet Printer
    Canon PIXMA iP4600 - error 6A80
    Hello someone else here had this problem, this is what he posted: "Same problem with a Canon MP540 fresh from the box. Turned out to be the print head unit was not returning fully to the home position ie extreme right. My Fix : When the scanning unit cover is raised the print head unit moves left for access, look in the vacated area to the right, in particular the small black sponge where the head normally parks. I found a small spring jammed in beside the sponge, removed it and all is well. Don't know what the spring was meant to do but everything is working fine without it.On the MP540 the head unit now glows red, presumably meaning all is well... "
    Jun 14, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
    Pin code for garmin nuvi 260
    Find out where your "friend" did the code. If you don't know what it is, then you have to go back to that exact location where they did it and it will automatically unlock it for you. Then you can follow the instructions below:
    Answer: If you can remember the PIN Code previously set on your device you will be able to change the Pin on your device easily. You can change the PIN on the unit by doing the following:
    Zumo's, Street Pilot Cxx, Nuvi 3xx, 6xx
    1. Turn your device on
    2. Touch the Spanner symbol
    3. Touch System
    4. Touch On/Off next to Garmin Lock
    Within this section you can add or change a PIN.
    All Nuvi's excluding 3xx and 6xx
    2. Touch Tools
    3. Touch Settings
    4. Touch Security
    5. Touch On/Off under Garmin Lock
    When the Garmin security lock is set it locates the units current GPS location.
    If you are trying to change the Garmin Lock and are not within the same location to where the Garmin Lock was set you will need to revert back to this GPS position.
    Once at this position you will not be prompted to enter the PIN Code when starting the device up and can change the code as you please.
    Mar 31, 2009 | Garmin nuvi 260W GPS Receiver
    Child put in random code and locked nuvi 260 gps
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you can remember the PIN Code previously set on your device you will be able to change the Pin on your device easily. You can change the PIN on the unit by doing the following:
    2. Touch Tools
    3. Touch Settings
    4. Touch Security
    Mar 14, 2009 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
    Wron catridge
    Try to reseat the print head:
    Reseating the print head is seldomly needed to be done.
    1. Press the Open Button (1) to open the Paper Output Tray (2).
    2. Raise the Scanning Unit until it stops.
      1. Pull and hold the Scanning Unit Lever towards you, then raise the Scanning Unit.
      2. The Print Head Holder moves to the middle.
    3. Open the Inner Cover 1.
    4. Open the Inner Cover 2.
      CAUTION:
      a. Do not try to manually move or stop the Print Head Holder.
      b. Do not touch any metal parts.
    5. Press the ink tank's tab (1), then remove it from the slot (2).
      IMPORTANT:
      Handle ink tanks carefully to avoid staining clothing or the surrounding area.
    6. Lift up the lock lever and take out the print head.
    7. Again, place the print head back in position and press down the lock lever.
    8. Insert the ink tank into the empty slot on the print head. Press down gently on the ink tank until an audible click is heard. Make sure the ink tank is in the correct slot.
      IMPORTANT:
      a. Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
      b. If the ink tank is inserted in the wrong slot, perform two head refreshings.
    9. Close the Inner Cover 2.
    10. Close the Inner Cover 1.
    11. Pull the Scanning Unit Lever towards you to close the Scanning Unit.
    12. Align the print head position after the print head is installed. You can align the print head position either automatically or manually. When automatic alignment does not work well, align the print head position manually.
    Automatically Aligning The Print Head Position:
    1. Load A4-or letter-size plain paper in the paper support tray. Auto alignment cannot be performed when the Feed Switch is set to [CASSETTE].
    2. Press <Menu> repeatedly until [MAINTENANCE] appears.
    3. Press left or right arrow to select [AUTO HEAD ALIGN].
    4. Press <OK>. The print head position alignment pattern prints.
    5. Check the printed pattern. If the printed pattern matches the illustration, the print head position alignment is complete.
    Manually Aligning The Print Head Position:
    1. Load A4- or letter-size plain paper in the paper support or cassette.
    2. Select the paper source with <Feed Switch> button.
    3. Press <Menu> repeatedly until [MAINTENANCE] appears.
    4. Use left or right arrow to select [ALIGN PRINT HEAD].
    5. Press <OK>. A horizontal pattern is printed.
    6. Beginning from column A on the printout, enter checkmarks in the patterns that have the most solid image.
      (1): Bad example (Least solid box)
      (2): Good example (Most solid box)
    7. Press left or right arrow to select the pattern number that you checked in column A on the printout in step 6.
      (A): Column
      (0): Select pattern number with most solid image
    8. Press <OK>.
    9. Repeat steps 7 and 8 to adjust columns B to L. When all the horizontal patterns are adjusted, you will be prompted to print a vertical pattern [PRINT VERT. PATTERN].
    10. Press left arrow. A vertical pattern is printed.
    11. Beginning from column M on the printout, enter checkmarks in the patterns that have the most solid image.
    12. Press left or right arrow to select the pattern number that you checked in column M on the printout in step 11.
    13. Press <OK>.
    14. Repeat steps 12 and 13 to adjust column N.
    Jan 16, 2009 | Canon PIXMA MP780 All-In-One InkJet...
    The carriage of the embroidery unit is not move automatically to the embroidering standby position.
    Is the need in upright position ?
    or have you fitted the embroidery hoop correctly.
    If all else fails switch off and start up again - should then automatically go to correct position.
    May 16, 2008 | Singer CE-200 Quantum Futura Computerized...
    "Locked Door" flashes after interrupting self clean
    Robert, see if you can get it back home by using the test funtion. Kill the power to the oven. Turn it back on and on the control press and hold the cooking time and delay start pads together. While hold these keys, press the number 8 pad. The words test should appear in the display. Now press and hold the self clean pad and it should cycle the cam through the whole process. Here is what you should see. 1 test (unit is in unlocked position 0 test (moving toward latched pos. 2 test (latched position 0 test (moving toward unlocked pos. 1 test (unit is in unlocked pos. Press cancel to exit the test. See if this gets you going again, let me know, Catriver
    Aug 24, 2007 | GE JBP60 Electric Kitchen Range
    JVC KD-NX5000 Car Video Player Logo
    74 people viewed this question
    Top JVC Car Audio & Video Experts
    xxxxxx xxx
    Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
