Question about Air Tools & Compressors
Ingersol Rand P260 WD compressor manual needed?
Need electrical schematics diagram for Ingersol Rand P260WD compressor.
2 Suggested Answers
compman66
  • 169 Answers
SOURCE: oil dripping out of bell housing on a ingersol
Would guess that the front shaft seal is at fault on the air end. if it is losing a lot at the time you shut the compressor down would confirm it. if so you will have to remove the air end and replace the seal, not a job for an amateur.
Posted on Jan 23, 2010
Testimonial: "Thank you..Shame i didn't read before as i've already started the task and cant get the lump off of the shaft that the donut bolts too"
Ingersol rand 80 gal 5 hp manual
follow the link
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Compressed%20Air/Air%20Compressors/Reciprocating%20Compressor/SCD-877.pdf
Sep 07, 2014 | Ingersoll Rand SS5L5 Ir Electric...
I am looking for a service manual for a INGERSOL RAND P130SD machine
Doosan have now taken over all Ingersoll Rand Portable Air Compressors, if you contact them they are normally very helpful.
Nov 18, 2011 | Ingersoll Air Tools & Compressors
I have just bought an old ingersol rand T30 A2955 it has a knocking noise I would like to investigate it further but would like to have a manual handy before I strip it down do you know were to get one...
T30 compressors have changed very little over the years. You can use practically any t30 parts list for an aid in looking at how things line-up.
The link below is pretty much what you will find. Your local ingersol rand repair center will have parts and service manual for your unit. Easy way to look into interior of the pump without tearing many gaskets is to remove cylinder at the base of the pump. Quite heavy so you will need a lift of some sort. Good luck with your repair.
http://www.irtechpubs.com/ir_pdfs/Compressed%20Air/Air%20Compressors/Reciprocating%20Compressor/SCD-749.PDF
May 30, 2011 | Air Tools & Compressors
I have a new ingersol rand 80 gal 7.5hp air compressor 230volt single phase and was wondering what size breaker it needs to be put on
Your owners manual spec sheet should give you that answer. However since that unit at max loads should pull 32 to 35 amps I recommend 1.5 times max amps. So approximately a 50 amp breaker. This all based on standard wire size and length of wire run. Also when checking your voltage at load you should be showing 235 to 240 volts.
Jan 09, 2011 | Ingersoll Rand - Rand Type - 30...
My ingersol rand compressor shuts down on low unload sump
check minimum pressure check valve on top of separator cover.
Jun 30, 2010 | Ingersoll Rand - Rand - Ir 2545K10FP Type...
Oil dripping out of bell housing on a ingersol rand p260 1997 model ( suspect compressor oil) not engine oil
Jan 19, 2010 | Ingersoll Air Tools & Compressors
I have a Ingersoll Rand P185 WJD air compressor and I need to know the type and quantity of oil to use.
Do not use 30 wt oil. It will wreak the oil/air seperator filter. Use Ingersoll Rand Pro-Tec fluid. It will hold approx 3 gallons.
Nov 03, 2009 | Ingersoll Rand Air Compressor Maintenance...
My rotary screw air compressor model SSREP100H
It's just too hot. Blow out the radiator weekly. There is an oil temp switch that might need replaced but the radiator is the most common problem with screw compressors. You can check the settings in the control panel, where you turn it on and off. It should be set for a high temp of 185°.
Aug 08, 2009 | Ingersoll Rand - Rand Type - 30...
Air Tools & Compressors Logo
520 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
