Question about HP Pavilion F1503 15" LCD Flat Panel Monitor
HP Pavillion F1503 screen has gone dark...background is very, very faint, barely able to see/read it. What is the problem? If it is a ''backlight'', then what exact is a backlight, what does it do, is it simple to install a new one and where do I obtain one?
    Problem Solver:
  • 16 Answers
Most of the time in this situation, the problem is due to the backlight going out. However, there are some instances where the inverter cable is bad.
The backlight is the part of the LCD which illuminates the screen. Think of an LCD as having multiple layers. One layer has the image itself on a semi-transparent layer and then behind that layer rests the backlight (usually a florescent bulb) which shines through all other layers to make the image glow and illuminate.
More info can be found here:
http://en.wikipedia.org/wiki/Backlight
As far as replacing the backlight, I always replace the whole LCD itself, which includes the backlight.
Otherwise, you risk ordering the backlight and finding out that it was the connection from the backlight to the LCD that was causing the problem (very possible) and then you would have to order the LCD anyway.
Posted on Sep 05, 2009
I have an hp pavillion dv1000 it works fine but the screen is very faint i can barely make out the icons... i tried pushing fn f7 which is supposed to make it brighter and nothing happened... any...
the backlight may be going or has gone out, is it plugged in or running on batteries? when plugged in it should be bright with a battery is usually dies down so as not to use alot of energy.
If that does not help, try function key and making it darker, I know that sounds weird but sometimes it gets stuck in a weird loop, My dell laptop does it all the time.
Sep 10, 2010 | HP Pavilion dv1000 Notebook
My HP Pavillion DV6000 laptop starts up fine and after a few minutes the screen turns black. I can still see the desktop image in the background but barely. If I reboot the screen looks normal again but...
That means your backlight is going out. The fact that it's happening intermittently like that suggests that you have a faulty screen inverter (a small circuit behind the screen that converts DC power to AC, in order to light the florescent backlight).
I suggest replacing it. Here are some on abay for pretty cheap:
http://shop.ebay.com/i.html?_trkparms=65%253A12%257C66%253A2%257C39%253A1%257C72%253A2608&_nkw=Pavilion+dv4000+inverter&_ipg=&_sticky=1&_trksid=p3286.c0.m14&_sop=15&_sc=1
Mar 24, 2010 | HP Pavilion dv4000 Notebook
My monitor does not work
Turn the screen of the laptop to catch some light from the window or a lamp
Can you see the Window screen very faintly in the background, if you can the backlight or the inverter has gone
If yoyu cant it is screen itself
Feb 18, 2010 | HP Pavilion dv9000z Notebook
HP Pavillion DV9700 Display does not work (it is dark)
its a hardware issue the proble may be on the cable that gives display to the screen or your screen has gone
Jun 13, 2009 | HP Pavilion dv9700t Notebook PC
Dell inspiron 5150 dark screen, faint image in background
If it showed a pinkish tint on the screen before it went out it could be the backlite. If you can see a faint screen when you turn the room lights out it chuld be the inverter. Inverters are cheap ... a used one for around $8 on ebay. Try that first. Make sure that you buy the EXACT model that is presently in your laptop.
Jan 14, 2009 | Dell Inspiron 5150 Notebook
Hp pavilion f1503
If you can see a very faint image in the background on the the monitor it is a invertor or backlight issue, try resoldering the coils on the monitors mainboard, This is a common issue with this model
Nov 07, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Pavillion dv2000 no video
yes hp makes **** pc's theese days but it might be the screen connector or the screen itself or it can be the video adapter maybe the chipset.
Oct 29, 2008 | HP Computers & Internet
Screen dim to black
This will be a problem with either the screen inverter or screen backlight. You will need to take it to a shop for diagnosis, in order to find out which one it is. If it turns out to be the backlight, then the entire screen will have to be replaced. They are considered a sealed unit, and the backlight can't be changed out.
Jul 24, 2008 | HP Pavillion ZV6000 Notebook
Laptop screen very dark very,very,difficult t read.Laptop has t0 be lnked to an ouside monitor
You have lost the lcd backlight, probably the backlight power supply, this is very common. What type of laptop is it?
Jul 16, 2008 | Intel Motherboard
Display problem
When the screen goes dark shine a flashlight in the lower right hand corner where the Start button typically is located. If you can see faint images then you have a backlight problem. If you don't see anything then try connecting a spare monitor in its place. If that works then you have some other type of problem involving your LCD monitor. In both cases unless you have the experience and tools to safely work on fairly delicate electronics this is not a repair job for the typical consumer.
Feb 09, 2007 | HP Pavilion F1503 15" LCD Flat Panel...
HP Pavilion F1503 15" LCD Flat Panel Monitor Logo
1,325 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
