Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
How do I get on Xbox Live with my rangemax router
  • 733 Answers
If your'e talking about through the xbox 360, then ou need to go through the xbox setup, and depending wether you have a hard wired 360 or a wireless 360 that will determine how you continue the setup.
Posted on Sep 05, 2009
Netgear password for wi-fi , for xbox live and ipod
Wifi password can be obtain by accessing the Netgear WPN824 router using a computer connected to it.
How to access the router
Go to http://www.routerlogin.net
username: admin
password: password
-Click wireless settings
- security encryption options would display the WIFI password.
- its the KEY1
Jan 01, 2011 | NetGear RangeMax WPN824 Router
The NAT on my Netgear Dual Band WNDR 3300 is set to strict and is causing issues with XBOX Live, how do I change this setting to moderate, or below? I went to the website where you change the settings of...
PS3 and Xbox ( NON BELKIN)
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And also make sure that UPnP is Enabled
Aug 24, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
Linking the netgear wndr 3300 to xbox 360 and laptop
configure ur netgear accordinglt... usually netgears are 192.168.1.1 or 192.168.0.1 with username admin and password as password.
make sure u reset ur router first and then reconfigure it with this
Jan 10, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
NetGear WNDR3300 RangeMax Xbox Live Failure
Follow the below steps to configure settings on the router:
1. Open the browser (Internet Explorer, Mozilla Firefox or Safari) on a computer connected to the router.
2. Access the router, usually with http://192.168.1.1 or http://www.routerlogin.com.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on Wireless Settings (under Setup) from the left menu.
5. Select security options as WPA-PSK. Enter a Password in the passphrase box. Apply the settings.
Scan for the wireless network on the XBOX and connect to your network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Oct 27, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
NetGear NETGEAR WNDR3300 RangeMax Dual Band router
The Netgear wireless router wireless settings need to be configured and the the wireless card in the computer and XBox needs to be configured with the Netgear wireless settings.
Follow these steps. : -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL
3. Enter the router setup login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WAP2
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Oct 11, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
How to hook up a netgear rangemax wireless router WPN824
  • connect it based on the manual
  • Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
    • set first the routers access page
    • type www.routelogin.com
    • type username: admin, password: password
    • on basic settings: select no internet login: set the router mac address to set to computer mac address, apply
    • click: wireless settings under set-up: change: SSID: <your name>, region: US, mode: g&B, channel: 11, no password first, click apply
    • goto xbox system-network- then look for the ssid of your router and connect, if you encounter any problem call xbox live support
Aug 05, 2009 | NetGear RangeMax WPN824 Wireless Router
When I secure my wirless network xbox live wont connect
If your xbox is also connecting wirelessly, you have to input also the wireless security key on your xbox to be able to connect.
Jun 29, 2009 | NetGear RangeMax WPN824 Wireless Router...
PROBLEMS SYNCING MY ROUTER TO MY XBOX. PLEASE HELP!
Ok plug everything in and Reset the router and modem wait a few minutes and try again.
Verify that that DATA cable at the Xbox's location works with a PC could be a simple bad data jack or patch cord. Do you get a connection failure like this? MTU failure?
The MTU(Maximum Transmission Unit) failure when testing the xbox's connection can be do to a few things because Xbox live requires a minimum MTU setting of 1364. Sharing a slower internet connection with other PC's in the house can cause this error, The incorrect MTU setting in your routers programming can cause this error, The lack of firmware updates to your router can cause this error, an older modem from your service provider can cause this. Old or worn network cables and jacks and or RG(coax) cables if you have cable internet could cause this. Your Router or gateway could be incompatible with Xbox live.
Try a direct connection to the Xbox without a router and reset your modem before doing it. If your able to connect then you know its the router. If not you know its the modem or cables or jacks or even your Xbox if you havent tested it elsewhere.
You can tell your ISP to mail you the newest updated modem... sometimes they will have a guy just drop one off.
This is trial and error.
May 08, 2008 | NetGear RangeMax WPN824 Wireless Router...
NAT set to strict, can not play on xbox live. How do I set it to open?
Reinstalled software that came withrouter and went thourgh the reconnection steps.
Now the NAT is set to open.
Mar 27, 2008 | NetGear RangeMax WPN824 Router
NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
125 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
