Question about Jenn-Air JED8430 Electric Cooktop
Use 30 amp or 50 amp electrict cord
Do i use 30 amp or 50 amp electrict cord to connect
    Problem Solver:
  • 16 Answers
I would use the 50amp better to be to big then to small
Posted on Sep 05, 2009
I have a maytag hardtop electrict stove F9 pops up when I try to turn oven on
Did you try to unplug it and let sit for a while then plug it back in.
Feb 18, 2013 | Maytag Stove / Oven / Range Cooktop -...
I need the wiring diagram and plug/receptacle specs for kenmore electric cooktp 42732
I believe that if you look on the name plate for the unit , it says that you will need a 30 amp, 220 volt supply circuit . This would be a two pole , 30 amp breaker , a run of # 10-3 cable with ground, and a junction box at the stove top location to make the splices. If you are going to use a plug connection, then a 30 amp 4 wire dryer outlet will give you the connection you need .
Apr 07, 2010 | Kenmore 30 in.42731 / 42739 / 42734 /...
How many amps is the electric cooktop
The usual amperage rating for a cook top is 30 amps. There should be a manufacturers label that states the amperage of the unit. It may be on the back or on the edge of the unit.
Jan 05, 2010 | Maytag 30 in. CSE9000 Electric Cooktop
How to wire a jenn air cooktop JEC9530ADB
the new cooktops and ovens now have a 4th wire used for separating the ground and neutral. some new homes and remodeled homes have a 4th wire run from the circuit panel to the unit.
you dont have this but it is ok to just hook up the white and green/ground wires together. then red to red and black to black. it will work properly and thats all you have to do.
Dec 29, 2008 | Jenn-Air JED8430 Electric Cooktop
Chef Electric Hotplates
Never...ever change the fuse rating upward on an existing circuit to accomodate a new appliance. The fuse is a protective device designed to limit current to the level the wiring can safely handle. There is a strong possibility of fire at some point!!!!
If you are rewiring, most places require up to 30 amps for cooktop wiring anyway. Use #10 copper wire for that purpose. If you are doing this yourself, make all connections tight and install all grounds.
Jun 14, 2008 | Cooktops
GE electric cooktop
Try looking at the junction box that it is connected to. Maybe one or more of the wires have burned off or come loose from the wire nuts. How many amps is the breaker? Most electric codes require separate circuits (Breakers) for each appliance. First turn off the breaker. There should be an outlet box of some kind on the wall or behind the cabinet. Follow the wire from the cooktop and see where it goes. Open it up and check if any wires are burnt or loose. If it was installed wrong I would change it. Most cooktops shouldn't be fused at more than 30 amps. Single ovens the same, double ovens up to 45 amps. The problem is if they used an old range outlet with 6 gauge wire and tried to connect both appliances to the same wire. This is hard to do without it coming loose.
Jun 10, 2008 | GE 30 in. JP326 Electric Cooktop
Cooktop WIring
To complying with changed Codes (effective in 2002 ) regarding stoves, ovens and dryers. You will need a 120/240 volt 4 wire 40 amp and 50 amp circuit. This
Decades ago it was permitted to use a 3 wire system (having two 120 volt hots (Black and Red) and 1 combination ground/neutral wire) (green and white) to serve stoves, cooktops, ovens and dryers.
The Code change now requires all stoves and dryers in NEW construction to have the 4 wire set-up (now having two 120 volt hots, 1 white neutral and one green or bare wire ground).
Existing wiring is grand-fathered under the Code change.....I advise you to change the feed wiring over to the the 4 wire set-up...
because - as with ALL Code changes in the past...it will eventually become mandatory for all stoves, ovens and dryers as the grand-father clause drops off. By complying now...
BUT the wiring will need to change to 8/3 with ground. (having 4 wires inside one outer jacket).This is the primary reason for the Code change....to provide a greater margin of safety to the user.
I can NOT recommend the 3 wire hook-up...the 4 wire provides a seperate ground and neutral -
which makes the chance of a user shock when touching the metal frame (from an internal fault in the oven) much less likely then the old 3 wire set-up....
which did NOT have the seperate ground and neutral.
Krazytech
Apr 05, 2008 | Whirlpool 30 in.GJC3055 Electric Cooktop
Jenn-Air JED8430 Electric Cooktop Logo
173 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
