Question about LG Washing Machines
If your Lg Washer keeps on locking and you just had a repair guy come out how do you unlock it?
  • 30 Answers
It should not keep locking unless you hit the child lock or its running.
Call the repair guy back.
Posted on Sep 05, 2009
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
De error message on wash machine
For LG washers, the DE error indicates a problem with the door lock. If you just started the cycle and the error occurred, then the door couldn't lock properly. (The machine turns off and indicates the error so that the water won't flood your laundry area.) First check if there are any clothes between the door and the frame. If needed unplug the washer for 5 minutes. Then restart the machine try to open the door. If you pressed Pause, wait a minute or two. If the error occurs at the end of the cycle, it may not be unlocking properly.
The latch mechanism may have failed or the PTC sensor in the latch has failed. The entire latch would need to be replaced. Here's one: http://www.appliancepartspros.com/lg-door-lock-switch-6601er1004c-ap4441836.html . If the door locked failed with the door closed or the washer is under warranty, contact LG or a repair professional for service.
I hope this helps.
May 18, 2015 | LG WM2688H Front Load Washer
The code cl keeps coming up and the washer will not shut off
CL is child lock. Press and hold the child lock button(maybe a key icon) for three seconds to unlock
Mar 23, 2015 | LG WM2455 Front Load Washer
LG WM3431 door won't unlock
did you unplug it,leave it unplugged for 5 minutes and plug it back in,if it's to hard to get to plug flip the breaker and leave the power off for 5 minutes or longer when you power it up again the door should unlock.here's a link to check hope it helps
https://www.google.com/search?q=lg+front+load+washer+how+to+manually+open+a+locked+door&oq=lg+front+load+washer+how+to+manually+open+a+locked+door&aqs=chrome..69i57.21935j0j8&sourceid=chrome&ie=UTF-8#kpvalbx=1
Dec 29, 2017 | LG WM3431 Front Load Washer / Dryer
Hi my LG WD-14311RD washing machine refuses to unlock. Cannot open the door,just remains locked.
My model no is LG WD-14331 AD the door just remains locked cant open i think the handle inside plastic hv broken how to solve can u send some one come to repair or .
BR Chow
Jul 29, 2011 | LG WD14311RD Front Load Washer / Dryer
I have a lg wm3677hw washer dryer combo. the door lock has been acting odd. so i figured i would replace the door interlock. after replacing the interlock the door will not unlock. i hear it make 3...
  • Hi Chris,
    This is late for you, and probably you've done something already --- but.
    The door lock is easily replaced. It works with a little heater inside it that is supposed to delay the unlocking by pushing on a tiny lever that prevents the lock from sliding to unlock.
    The washer runs power through a resistor when the door is locked, and this heat keeps the bimetal strip (like in a thermostat for aquarium heater etc) bent, preventing the door from unlocking. When the washer turns off, the power to the heater/resistor is shut off, an when it cools off in a few moments, the bimetal strip relaxes and pulls the tiny lever out of the way.
    I expect there is a problem with the position or the flex of the bitmetal strip.
    If you don't have another switch handy right now, you can TEST the functionality by simply jumpering the two wires on the connector. This will bypass the lock altogether, but the latch will still work. When TESTING be careful not to let the door come open because at high speed that drum could grievously injure someone.
    ~scirocco
Bimetallic strip
How washing machine door lock works how to test interlocks
Sep 19, 2017 | LG WM-3677HW Front Load Washer / Dryer
Front loading lg washer
if you have the spin sense option, try enbaling that on the washer
Oct 25, 2008 | LG WM-2277HW Front Load Washer
Unlock code
Hi,can you give unlock code for LG KU990 Viewty
Jul 18, 2008 | LG KU990 Viewty
LG Shine unlock code
locking system is inbuilt in phone.
and no one other than service center change the lock code
if u want to unlock it then download its software from google and then by connecting through cable u can solve ur problem
Mar 10, 2008 | LG Shine KE970 Cellular Phone
Washing Machines Logo
19 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
