Question about Linksys Wireless-G WRT54G Router
When I go into other rooms I can't connect to router
    President:
  • 1,015 Answers
How is the signal strength? Check and make sure the antennas are not loose. Is your house the old style concrete? Sometimes thick block or concrete walls are tough for the wireless signal to get through. They do make larger antennas or signal boosters for wireless routers. You may need to install one of these to boost signal strength. Also is it wireless B,G,or N? Wireless B has a very weak signal while wireless N has a very strong signal. Sometimes the router settings can be changed to adjust the signal strength and may be set too low also.
Posted on Sep 05, 2009
Hi, I'm having problems connecting to the router (Virgin) to my bedroom from lost of signal strength, so i brought Sitecom Wireless Range Extender 300N to boast the signal. I've installed the Range...
1. did you first try to connect to the router via wire directly with it in the same room? then set up the wireless to work in the same room too.
2. once you've done that and it worked then move it to your bedroom. If it doesn't work there it could be that there is something inbetween the two rooms that is blocking the signal...ie a furnace can do that
3. if it won't work try relocating the router to another location. Try a different location in the same room first
but as i said , first get it set up and running in the same room so you know for sure it works.
Mar 21, 2011 | Computers & Internet
Is it possible to Wirelessly connect Router to a Router? We have a Router (outside the house) by which we connect to the internet inside the house. The problem is is that the internet connection is not...
1.Yes you can connect router to router.
2.Buy ruckus 802.11n.It got MIMO antenna.I hope it will work for u.You can use single router to access internet from all room
Feb 04, 2011 | Computers & Internet
A friends iof my gave me this router, but I don't know how to install it so that i can use it with my laptop in my living room. my internet is connect to my computer in my room. My main internet is in...
You have a few options. If you already have a router, set this one up as an Wireless Access point. It pulls signals from the main router and you can connect to this one. BUT your signal could be weak depending on the distance, walls etc. If you can make a cable run, use it as a switch. (Extend your ports, and as a wireless point. Go to Cisco Linksys and download the manual.It is not difficult. Use the main router as a your DHCP and this one as a wireless point. You will need to set up the SSID and security (Securty is optional, but I would do it). Give it a SSID different then your main one and you can setup your device to connect to the one with the strongest signal (Most do this by default.
Dec 18, 2010 | Linksys Wireless-G Broadband Router
Something is blocking wireless signal, i live in flat so in one room there is wireless router and in other room signal is very poor sometimes it's not connecting. i tryed 3 diffrent routers the last one is...
There are several likely causes, if the building has plaster walls it may have metal lath behind it blocking the signal.(this is fairly likely the cause) If there are high-power microwave transmitters within 2 or 3 km, can cause spotty interfering. Neighbors with a wireless router close to your wall can as well.
If you can move the router to a position across from the door between the rooms, you can test by connecting (wireless) your laptop near the router, then walk it into the other room (stay where you can see the router). If the laptop stays connected move across the room to a point where you did not have a signal previously, if you are still connected leave the laptop there and move the router back to its original location and recheck the laptops connection, if it is gone, it is your wall...
Apr 23, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Connecting router to PC and Playstaion 3
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 26, 2009 | Linksys WRT610N IEEE 802.3/3u IEEE...
Trying to create a bridge with two routers
You do not need a bridge if you are using a wireless adaptor on your pc in the other room. Just set up the Belkin Plus router to the WEP security settings you want and make sure the pc wireless usb adaptor has the same settings as the router. You should be good to go. Good Luck.
Jul 15, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Airport card only works in same room as router
Do you have a cordless phone in the apartment?
how many rooms do you have and in which room is the signal low? What router do you have?
Intermittent Connectivity:
NOTE: Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
  • Placement of the router:
  • Router mfg'ssuggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router
Having default wireless settings on the router may cause conflict with other routers within your network range. change the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 20, 2009 | Apple iBook G3 Clamshell (M2453B) Mac...
Moving desktop across room where there is no cable connection.
you can buy a cheap USB wifi adapter and connect the desktop wirelessly just like your laptop, this should do the trick.
or you can buy an access point to extend the range of the wireless network, you should not be moving the router itself this way.
Feb 13, 2009 | D-Link AirPlus DI-524 Wireless Router
Laptop
the internet cable should be connected to the "Internet" or "WAN" port on the router. Your PC should be connected to one of the regular ports on the back of the router and your laptop can be connected just like the pc, or it can connect wirelessly.
Then you should be able to see the internet from your laptop.
Jan 20, 2008 | Belkin (F5D7231-4) Wireless Router
Linksys Wireless-G WRT54G Router Logo
454 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
