Question about Dacor DMT2420 1200 Watts Microwave Oven
E-wave KOT-152UB glass tray and turning ring melted
I believe that my wife set the Ewave microwave oven to cook rather than setting the timer. The plastic tray support ring caught fire and the glass tray melted over the spot where the plastic ring burned. The glass tray had a spot about 2" in diameter that was glowing red. What happened here?
  • JGEH Mar 03, 2008
    ATTEMPTING TO LOCATE PARTS SUPPLIER FOR E-WAVE KOT-152B DOOR, PART #351171222B. CANNOT LOCATE THROUGH DAEWOO SITE. CAN ANYONE HELP?
    THANK YOU
    GEORGE.HIGGINS42@VERIZON.NET
  • Anonymous Apr 01, 2014
    NEED TO KNOW WHERE TO BUY IT
  • 833 Answers
Sounds like some metal is involved somehow. If the unit otherwise works, replace the damaged parts. Test with a cup filled with water.
Posted on Dec 19, 2007
What is the Serial Number for the EWAVE KOT- 17sb? It does not display it in the information panel.
Hello, Marisel -
Do you mean the Daewoo KOT-170SB microwave oven, instead?
The manual for the KOT-170SB microwave I found online (PDF format):
pdfstream.manualsonline.com/1/1d0dd7b3-990b-4256-9519-fa2dc1e7c2bf.pdf
shows a "data plate" on an interior wall of the microwave (page 7.)
That may be where the serial number (S/N) for the microwave is printed.
If not, there may be a label or tag at the back of the microwave oven where the serial number (S/N) is printed. Or, there may a label on the back of the microwave oven, look on the bottom.
Best wishes.
Feb 08, 2018 | In Microwave Ovens
Glass tray turntable makes noises when heating food
Hi, the rollers on the support mechanism has residue, try cleaning the rollers and the track it follows, should resolve the sound problem
Jan 05, 2015 | LG LMH2016ST 2.0 cu. ft. Over-the-Range...
Burns my popcorn constantly. is there a different setting i can put it on?
HELLO.
Solution to your microwave problem is given as below.
* 1 Set your Daewoo microwave on a countertop near an electrical outlet and plug it in. Open the door and place the circular roller guide in the center of the oven cavity, then place the glass cooking tray over it.
* 2 Set your food on a microwave-safe dish and then put the dish on the cooking tray and close the door. Make sure that it latches properly.
* 3 Turn the upper knob to select a power level. Power levels include "Defrost," "Med-High," or "High." If your Daewoo has a touch pad, touch the "Microwave" button once to set the highest power level. Touch it consecutive times to lower the power level.
* 4 Turn the lower knob to set the cooking time. For cooking times less than two minutes, turn the knob up past the two-minute mark, then back to the correct time. For touch pad models, enter in the cooking time with the numerical keys and then press "Start."
* 5 Open the door at any time to stop the cooking and check the temperature of your food. Shut the door to automatically continue cooking, or turn the timer knob to the right to add more time. For touch pads, press the "Stop/Clear" button, then key in a new cooking time and press "Start."
* 6 Open the door when the timer reaches the "Off" position and take out your food.
Thanks.
Sep 24, 2011 | Daewoo KOC-925T Microwave Oven
What is the cu ft, wattage, size, conventional oven yes or no, all the specs ect of the Kenmore mircorwave model #721.80833500
From the factory manual here:
SPECIFICATIONS
Rated Power Consumption ..............1700W maximum (Microwave oven+Cook top lamps+Ventilation fan)
Microwave Output ...........1100W (IEC60705)
Frequency ....2,450 MHz ±50 MHz
Power Supply .................120 VAC, 60 Hz
Rated Current ................14.5 Amp. (Microwave oven+Cook top lamps+Ventilation fan)
Magnetron Cooling .........Forced Air Cooling
Rectification .Rectification Voltage Double Half-Wave
Door Sealing ..................Choke System
Safety Devices ...............Magnetron Thermostat: Open at 145 °C ±5 °C
Close at 60 °C ±5 °C .....................Oven Thermostat: Open at 110 °C ±5 °C
Close at 0 °C ±5 °C ......................Fuse(20A)
Magnetron ......................2M282J (Toshiba)
Cook top Lamp ...............130 V, 35 W (Halogen)
Cavity Lamp ...................130 V, 35 W (Halogen)
Timer ..............................Digital,up to 99 min.(in each cooking stage)
Tray ..............Tempered Safety Glass
Overall Dimensions ........2915/16"(W)x167/16"(H)x153/8"(D)
Oven Cavity Size ...........231/2"(W)x10"(H)x141/2"(D)
Effective Capacity of Oven Cavity ....2.0 Cu.ft.
Accessories ..Owner 's Manual &Cooking Guide, Installation Manual,
Exhaust Adapter, Exhaust Damper, Mounting Kit and Filter,
Rotating Ring Assembly, Glass Tray, Metal Rack, Guide Tray.
Jul 09, 2011 | Kenmore 80809 Microwave Oven
The turntable on our Ewave KOT 170SW Microwave oven has quit rotating. Other than that the oven works fine. Any troubleshooting tips? If the turntable needs to be replaced, how big a job is it? I'm not...
i went to replace lite bulbs but didnt unplug it..removed cover and shorted out...now no lite and no turntable but does come on & heats food is it fixable.......ewave microwave kot-131uw....
Feb 28, 2011 | Kenmore 80412 Microwave Oven
Replace handle on Ewave microwave
you'll have to remove the molding and the handle clips in to place and also has to screws that hold it in place, after that reassemble the door outside trim.
Jan 19, 2010 | Microwave Ovens
How to replace the door handle on an Ewave KOT 170SW Microwave
Ewave KOT 170SW Microwave, it starts runs for a few mins. then stops. Shorter then time set for.
Dec 10, 2009 | Microwave Ovens
Ewave panel is on lock
As per the owner's manual:
The oven operation can be locked to prevent the microwave from accidentally being turned on. All oven functions can be locked.
To Set: Touch and hold the CANCEL/OFF Pad for three seconds. The Display shows “LOCKED” and the oven beeps.
To Cancel: Touch and hold the CANCEL/OFF Pad for three seconds. “LOCKED” disappears from the Display and the oven beeps.
If this does not work, then try a hard reset: Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If it still fails, you probably have a problem with the controller.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee. It may cost a little more if you need parts, such as a new keypad.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Aug 26, 2009 | Frigidaire Microwave Microwave Oven
Little plastic ring with wheels broke in several places
the purpose of the turntable is to more evenly cook the food. it shouldnt effect the mics ability to cook, just might take a little longer to thoroughly cook food
Apr 21, 2009 | Emerson MW8625W Microwave Oven
Dacor DMT2420 1200 Watts Microwave Oven Logo
777 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steven Clarke
Steven Clarke
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
