Question about Mitsubishi WS-55809 55" Rear Projection Television
Flashing green light when i hit power button
When I press the power button on my Mitsubishi WS-65908, green light flashes 2 times and hear click on the back of the TV. The screen does not turn on.
  • trangcpham Sep 05, 2009
    yes! two blinks ,a pause and two blinks !
  • SD Tech
    SD Tech May 11, 2010
    engage the diagnostic check for this set(ws55809) by holding on the front of the set MENU and INPUT(device) for 5 seconds and release both buttons--set should blink a two digit error code---let me know what it is and I will tell you what it means---for example: two blinks, a pause and two blinks etc. SD TECH
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
2 blinks and two blinks is short protection for this model---most likely one or both of the fuses for the convergence chips are bad--FAo4 and FA05--set detects this and no voltage to the convergence chips and shuts down instantly---this model uses 2 STK-392-570 convergence chips--both with the fuses and any of the blue resistors in front of the chips(they are blue in color and marked 3.9 ohm) that are bad need to be replaced and the set adjusted. I can send you photos of a simular board if you want to know what the fuses look like and the resistors All these parts are located on the middle board(set has 3 main boards) I have detailed instructions for a step by step start to finish repair of this set--if you are able to do the repair yourself you can buy both chips (and the fuses etc) On Ebay--a pair of chips for this set costs about 14 dollars plus shipping.
If you cannot do this repair yourself--look in your area for someone who has done this before--almost any good tech can do it in your home in a hour---some shops charge 300-400 for this kind of repair--I have done hundreds of them here for 200-250 total. If a shop tells you it has "to go to shop" keep looking----now is the slow time of year for TV repair shops--The other person who suggested here it is a problem on the DM board did not read your post --he is speaking about a DLP set made--does not apply to your set--200-250 is a good investment and you cannot replace a set like this for that kind of money--once the chips are replaced the set should not have a convergence problem for 5-8 years.
If you have any questions or need the instructions : etower.766@netzero.net
I do this here for free so if this has helped you take a minute and give me a vote here.
unlike some other people here--i know what I am talking about
regards, SD TECH
Posted on Sep 05, 2009
  • Mitsubishi Master
  • 3,459 Answers
Common problem. Its several caps, pico fuses, etc on the DM board. You can get them yourself or get a complete kit with instructions from www.TvrRepairKits.com
Mitsubishi WS-65908 will not stay on
Its a color convergence problem from description:
If green light comes on for a few seconds and goes off:
On the front of the set (not the remote) press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and release both.
Watch power light: it will blink a two digit error code, in your case I suspect it will be 2 blinks, 2 blinks and repeat several times.
Let me know error code and I will help.
Apr 16, 2012 | Televison & Video
Mitsubishi Medallion does this
hi there,
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Mitsubishi is very prone to bad solder.
`jack
May 26, 2008 | Mitsubishi WS-55411 55" Rear Projection...
The green light on the front panel is flashing but
Try website Tvrepairworld.com to buy a refurbish DM power board for the replacement.U know soldreing?Buy capacitors for the replament.
May 14, 2010 | Mitsubishi WS-55511 55" Rear Projection...
65 INCH-MITSUBISHI TV WS-65908 WILL NOT POWER UP
same problem with mine.. i usaually hit the reset button if it continues you need to get it service. when i called for service i stik had warranty and they replaced a capaciter.. it would of cost atleast $500. GOOD LUCK
Jan 26, 2010 | Mitsubishi WS-65613 65" Rear Projection...
Stays on for 2 seconds and switches off
A 2-2 code on that unit means over current shutdown. 95% of the time that code indicates defective convergence output IC's.
Jun 09, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Press power button green light comes on.But no picture no sound,
I have had my WS-65511 fail like this, first at 4 years, second 2 weeks later, then 3rd time yesterday (4/14/2009). In past, the tech replaced a thermal sensor p/n 299P313010A (but Mitsubishi says that part is not for WS-65511 and that it does not have a thermal sensor - go figure). It is a white rectangle with about 30 pins in 2 rows and is soldered onto a board in the TV. List price is about $25. Might be your problem.
Apr 04, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Tv won't come on. It has a flashing green light on by the power button.
the tv is not come on.it has a flashing green light on.tv model hd 1080.
Oct 19, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi turns on for 3 seconds then shuts off..after power surge
try holding in the menu and input buttons together on the front panel for about 8 seconds to see if the self diagnosis feature will blink a two digt code then let me know what happens
Jun 05, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Mitsubishi Medallion HD 1080 model ws-48413
my mitsubishi medallion tv wont power on.
all I get is a blinking light. How can this be fixed
May 08, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
79 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
