Question about Sharp AL-1641CS Laser Digital Copier
Eror code h4
I have an error code h4 what is that
  • 32 Answers
It means you have a problem with fixing unit! i gues the problem is in the termistor witch controls the temperature of the unit!
Posted on Sep 05, 2009
Gree air conditiones H4 error code
Not answer my question is what is the solution for wall mounted unit Model number 18cith1 has error H4 this error meaning here mention system protection.
Apr 30, 2014 | Heating & Cooling
PROBLEM WITH SHARP-CALL FOR SERVICE EROR h4-00
The H4-00 code relates to the fusing temperature being to low. This could be a heat lamp or thermistor failure. call your local service engineer to come and take a look.
Apr 29, 2013 | Sharp Office Equipment & Supplies
I have eror code h4-21 in my copier
Hi Kosar,
This error in copiers are usually because of temperature troubles at the chip-set level. This means we might have to change a lot of hardware like the thermister, heater lamp, PCU PWB ...
I would recommend you calling up the hardware vendor and have it fixed.
All the best
Cheers!
Apr 18, 2013 | Sharp Office Equipment & Supplies
Sharp ar 5516 printers error h5. h4
hi,I have error code L h on my coppier sharp 5516. your help please.
Aug 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
Digital Copier AR 5316E error code H4 indicating
An H4 code denotes a low temperature or temperature sensor failure problem with the fuser (the device that provides heat and pressure to bond the toner to paper). There may be a peice of paper or part of a peice jammed up inside the fuser that's blocking the sensor, or the fuser is defective and needs to be replaced.
Sep 18, 2009 | Office Equipment & Supplies
EROR- NOT RESPOND
h4 errors usually accur due to a problem with the fuser it may be it over heated or the thermistor has a build up of toner on it causing irregular temp reading check to see if it is heating up by turning it on and feel the heat from the fuser unit at the back.
Jun 15, 2009 | Sharp AR-5316 Advanced Digital Imager...
I have a sharp copier, model AR-285, H4-01
H4 error pertains to lamp errors.
that would either be the copy lamp or the heater lamp.
check both lamps.
with heater lamps,it's usually caused by either a broken heater lamp or a dirty thermostat on the heater roller assembly.
Jun 09, 2009 | Sharp Office Equipment & Supplies
Eror Code (H4-00) on a Sharp AR-162
H4-00 indicates a heating/temperature problem in the fuser. The fuser never reached its desired temp to come to ready. Could be a bad thermostat or thermistor. Check fuser for any debris or excessive gunk build-up and clean what you can. The error can be cleared with SIM 14 in service mode.
Mar 19, 2009 | Sharp AR-M162E Black and White Copier
Eror code on sharp copier AR-M276
UNRELATED PROBLEMS.
H4 = MAIN HEATER LAMP ABNORMAL LOW TEMP. THE FINAL UNIT BEFORE PAPER EXITS. HAS TO BE HOT. LAMP OR THERMO-FUSE? CHECK CONTINUITY LAMP WIRE IN THROUGH WHOLE PATH TO OTHER LAMP WIRE OUT.
E1-15 = IMC board Page Memory error/SRAM
error. MEMORY FULL? Mfr. says "Print Buffer Page Memory or Work SRAM abnormality"
SORRY NO MORE.
Jun 24, 2008 | Office Equipment & Supplies
Sharp AL-1641CS Laser Digital Copier Logo
143 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
