Question about Tools & Hardware - Others
I am looking for instruction manual for mini metal lathe and milling machine combi-218 manufactured by Gate machinery UK
I'm looking for a owners manual for a ML618 wood lathe. I'm looking to see if it has more than one Chuck?
Most wood lathes, like most metalworking lathes, have a spindle that is threaded to accept a variety of fairly standard accessories including chucks and faceplates of various sizes and types to accommodate different types of work.
Any lathe that does not accept a variety of such accessories would be a complete waste of time.
Obtaining a manual for much imported machinery is almost impossible to obtain but most imported machines are close copies of industry standard machines and so generic information such as can be obtained from almost any supplier or experienced user is all that is required.
Oct 19, 2015 | Tools & Hardware - Others
Tip
Delta Machinery Reference
If you're looking for information for Delta machinery like their old bandsaws you may find the following links useful:
Delta Schematics and Parts:http://www.toolpartsdirect.com/delta/delta-52.html
Delta Schematics and Manuals:http://owwm.com/mfgIndex/detail.aspx?id=1141&tab=3&sort=2&th=false&fl=
TopTip: Use the Sort By function to find the type of machine you are searching for. e.g. bandsaw, lathe, etc.
Another great reference is AceTools who supply parts but also have schematics for most of these machines.
Find the listing at: http://www.acetoolrepair.com/saw/bandsaw.html?manufacturer=568
on Jul 31, 2010 | Saws
Have a Craftsman 15in. to a 17in not sure, drill press and have lost the chuck a #2 taper. Can buy one at Harbor freight For their Mini Lathe,can you tell me if it will work?
#2 taper should be the same on all machines .... for peace of mind ask the shop if you can return it,, if it does not fit ,,, i think it should as i have used tapered chucks from drill to lathe on many occoations,,, pete
Oct 04, 2013 | Craftsman sears 15" 1/2 Heavy Duty Drill...
What are the requirements for a sheet metal fabrication company?
You need many different metal cutting equipment for your metal fabrication. Some of them are laser cutting machines, band saws, drill presses, belt grinders, lathes, shop presses, and sheet metal fabrication. Metal fabrication equipment is used to build metal structures by cutting, bending and assembling processes.Visit: https://metalscut4u.com
Aug 30, 2013 | Central Machinery 18 Sheet Metal...
Minnapolis moline water pump repair diagram
you need to go to engineads as they have guy's that love building hose old engine part's as do i. but if you do not have a metal lathe and or milling machine to this kind of workjlelandthomas
Apr 06, 2012 | Cars & Trucks
Owners manual for a dashin p-4 bench lath
Come on,
If you need an owners manual for ANY lathe, you have no business operating it in the first place.
Don't hurt yourself or others.
Dec 27, 2011 | Tools & Hardware - Others
What is diffrent between lathe machin & cnc machin
A Lathe machine turns a piece to be worked on usually along its longest axis. An operator or machinist manually moves a cutter or other tool against the rotating piece to remove and/or polish the material to a more refined state. Instead of manually, a Lathe can be controlled by computer with the speed of rotation and positioning of the cutter or other tool being done according to a program or set of numeric data in which case the Lathe would then be a CNC machine. A CNC machine can refer to any computer controlled machine which uses a set of numeric data to determine its operation which can be cutting, drilling, milling, etc.
For a more comprehensive description go to Wekipedia for Lathe at http://en.wikipedia.org/wiki/Lathe
and for CNC at http://en.wikipedia.org/wiki/Numerical_control
Jan 31, 2011 | Computers & Internet
Looking for info/ manual for a wool lathe
look under cwl12d clarke wood lathe manual. this has all the instructions that are almost the same as the nwl37-2 i have a nwl37-2 and this manual shows what should be there.
Jan 22, 2009 | Powermatic 1352001 3520B 20x35" Wood...
Tools & Hardware - Others Logo
61 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
